Question about Pool & Spa
My pump has started making a rumbling noise and is not moving much water. I disassemble the pump, removed the impeller and reassembled bu it still make the noise nd has about 1/3 normal flow. The pump is on an easy set 18" x 42" pool
    President:
  • 1,486 Answers
Bearing worn causing the impeller to shake.When it does this the the impellor is not close to the housing.causing it not to pump very well.Allso the noise you can hear is the impellor rubbing the casting by wobbling when spinning.Hope that was helpfull.Good luck.
Posted on Aug 01, 2009
The motor is making a whirring noise after starting.
If your Swimming Pool or Spa Pump Motor is humming and/or has very little or no water flow, please follow the following directions.
1) Remove the pump motor from the system. 2) Disassemble the front half of the Pump Pot Housing from the back half.
3) Check for any foreign obstructions which would jam the Impeller and remove it
4) Next, inspect the Pump Motor Impeller itself. (This is a high suspect part). See if there is any sign of wear or breakage. (This happens over time from debris in the water passing over the impeller). If so, your Impeller is damaged and requires replacement.
5) Next, remove the cover from the rear of the Pump Motor. Using a large standard blade, (straight), screwdriver or wrench... turn the main motor shaft. Listen for grinding and/or rumbling and feel for any restrictions while turning. If you hear or feel either, your bearings and/or brushes are damaged and need replacement.
If everything seems to be in good working order, then you need a new pump... not just replacement parts.
Jan 23, 2014 | Marathon Electric Marathon imPower...
Viron p300 pool pump. Why isn't it working?
3) Check for any foreign obstructions which would jam the Impeller and remove them.
4) Next, inspect the Pump Motor Impeller itself. (This is a high suspect part). See if there is any sign of wear or breakage. (This happens over time from debris in the water passing over the impeller). If so, your Impeller is damaged it requires replacement.
If everything seems to be in good working order, then you need a new start capacitor or your motor windings are fried and you need a new pump.
Jun 09, 2013 | Pool & Spa
Impeller
by Osko Pool n Spa If your Swimming Pool or Spa Pump Motor is humming and/or has very little or no water flow, please follow the following directions.
May 26, 2013 | Hayward Pool & Spa
We have taken apart the bottom of the dishwasher to be sure no food was clogging the exit. It is clear but the water still willnot drain
HI In most dishwashers, the water pump is located under the lower sprayer arm. This component pumps the water through the dishwasher. The pump has two impellers, top and bottom. These, as well as other components, can become clogged with food or detergent. Here's how to disassemble the pump:
Step 1: Remove the cap that holds the sprayer arm on.
Step 2: Remove the sprayer arm, the screen, the pump housing, a bolt, the upper impeller, the food disposer blade, a spacer plate, the impeller hood, a flat plate, an O-ring, and the lower impeller. Lay the parts out in order as you disassemble them so that you'll be able to reassemble them properly.
Step 3: Clean the parts thoroughly with a mild detergent solution. If any parts are worn, replace them with new ones made for the dishwasher.
Step 4: Replace any seals, such as the O-ring or other washers, with new ones.
Step 5: Reassemble the pump, keeping the parts in order.
To reach the water pump, remove the sprayer arm and screen and then the pump housing. Remove the bolt, and the pump components can be disassembled.
On some dishwashers, the lower impeller serves as a drain pump. This type of system usually has a reversible motor; machines with nonreversible motors have drain valves, as detailed previously. If your machine possesses this impeller pump system, and the water will not drain from the dishwasher, clean the lower pump impeller. This may solve the problem. Otherwise, call a professional service person.
Oct 13, 2008 | Dishwashers
Dryer stops and won't start again
hi
Oct 12, 2008 | LG DLE3777 Electric Dryer
Dishes not getting clean in GE Triton XL Dishwasher
HI
Oct 12, 2008 | Dishwashers
Maytag dishwashwer problem
hi try this In most dishwashers, the water pump is located under the lower sprayer arm. This component pumps the water through the dishwasher. The pump has two impellers, top and bottom. These, as well as other components, can become clogged with food or detergent. Here's how to disassemble the pump:
Sep 12, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Mine is a FDB635RFS4 model - issue is loud screeching noise
i recently had the same problem of a loud screeching noise. my unit was installed new in 1999 and has worked well up to this point.
when i disassembled the tub water filter i found the filter was heavily clogged (it is supposed to be self cleaning), and i also found glass shards from a broken wine glass. i further disassembled the plastic housing under the filter ( held in place by three torx drive screws ) which covers the pump impeller and holds the lower spray arm. while i did not find any blockage in the pump area, and no abnormal sound when i turned the impeller by hand, i did find that one of the pump impeller vanes has a small chip which probably makes the impeller unbalanced resulting in more than normal vibration. i cleaned the water filter and reassembled the parts and the original screeching noise is now gone.
Sep 03, 2008 | Frigidaire 24 in. FDB635RF Built-in...
DDW399D Dishwasher
Check and make sure that there is nothing blocking the pump inlet underneath the mesh removable filter. It should be making a whirring sound like it's trying to pull water in in a cycle. If it's not making that noise your pump is shot.
Oct 14, 2007 | Danby 22 in. DDW399 Free-standing...
Pool & Spa Logo
281 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
