Question about Kenmore 24032\24036 Top Load Washer
How do I replace the lid switch on a Kenmore Model 110.82681110, bought in 1987?
  • 672 Answers
If you allready have the new switch, you are ready to start. If you do not have the part, it is available at www.sears.com under the parts direct tab. you'll need your model number to search out you machine and then the switch.
I find it easiest to remove the entire main case to make this repair. Case removal is as follows:
Disconnect the power cord. 1. There are two screws, one at each front corner, holding the control panel in place, remove them. 2. Remove the two screws at the top, on the back of the control panel. Carefully roll the control panel over the back. 3. Unplug the wire that connects the control panel to the top. Stop here and take note as to how the case connects to the back panel. There is an aligner there that will be your hardest part to deal with later. This will help when reassembling. 4. OK, Put a slotted screw driver into the front of the clips, at the back corners on the top and push back to release them, once again take note to their positioning. 5. The outer case hooks under the front of the frame and the sides have a slot that goes over a pin near the back of the frame side. (Front under, sides on top of frame)Tilt the case up on back and pull forward. Congrats you are there. Replace the switch and reassemble reversing procedure. Good luck. Need help? I'm here. Just enter a comment and Fixya will send an email to me.
Posted on Aug 01, 2009
Thanks. It was easy following your directions. Switch was bad. I jumpered it while I wait for the part to come in the mail. Appreciate your quick response.
Posted on Aug 02, 2009
My Kenmore washer is not draining or rinsing
Check the lid down safety switch. On the lid there is a small spike that goes through a hole when the lid is down.
Under the hole is a switch that allows the timer to advance and the washer to spin only when the lid is down. Two screws hold the switch in place and the plastic switch will sometimes break and be hanging by the wires.
In other words, it is the timer. That is stopping the advance. You may have to replace the timer.
How to replace the timer in Kenmore top load washer
Aug 27, 2017 | Kenmore Washing Machines
My kenmore 90 series washer will not drain i have tried playing with the lid leaver any thing else i can do ,can i replace the leaver switch?
Yes you can replace the lid switch its fairly easy to do...this tip i wrote will help ya to replace the lid switch http://www.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
Series 90 is unfortunitly not a model number please reply with exact model number as found on a label on the rim of the tub inside of the lid and i will give you the part number for the lid switch.
GENE
Sep 12, 2011 | Kenmore 24032\24036 Top Load Washer
How do I replace lid switch in a Sears Kenmore 80 series, model 1
The following link explains step-by-step how to replace a lid switch on a Kenmore top loader:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions about this repair, please post back and let me know. I hope this helps you.
NOTE: Kenmore is manufactured by Whirlpool so these instructions will apply.
Apr 07, 2010 | Kenmore 24032\24036 Top Load Washer
I have a sears kenmore 80 series 110.24852300. The lid switch is broken. I bought a new switch. I cannot figure out how to get inside the machine to replace the lid switch. Please help.
There are videos at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing this part. It may be a different model but the replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available
Kenmore washer lid switch problem
Good day,
Common problem, Change the switch, and make sure if it is the model with a plunger for the switch mounted on the lid, that that be replaced as well.
Thank you for using FixYa
Dec 29, 2009 | Washing Machines
Kenmore Mod# 110.25842400 lid switch
The following link gives you step-by-step instructions on how to replace a lid switch on a Kenmore top loader:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you have any questions about this repair, please let me know. I hope this helps you.
Jul 15, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
We need to replace the switch that allows the spin cycle to work with the lid down. The back is one solid piece we dont know how to get to the timer to plug in the new switch we bought
What you are talking about is called the "lid switch". The following link explains how to replace one on a Kenmore top loader:
Make sure you check to see if the switch is simply loose. There should be some mounting screws holding it in place. In addition, there is usually a small plastic piece mounted on the washer lid on most Kenmores that activate the switch when the lid is closed. This is called a "lid strike". If the mounting screws are loose, or if the lid strike is broken or missing, the washer will exhibit the same symptoms as having a broken lid switch. For replacement parts, refer to searspartdirect.com and type in your complete model number (located along the washer lid opening). The parts you need will be listed under the "Top and Cabinet" heading.
I hope you find this information helpful. Let me know if you require additional assistance.
Sep 11, 2008 | Kenmore Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
179 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
