Question about Blaupunkt CDC-A01 10-Disc CD Changer
Cableing pulled out of multi pin plug
Need to know which colour wire goes to which pin number on the head unit plug for blaupunkt cdc a01 . plug into the stacker itself is fine . also need to know if stacker is compatible or can be adapted to a seville head unit
  • 1 more comment
  • soccer435962 Aug 12, 2009
    wires are out of the multi pin plug at the head unit end of the lead for the stacker
    sorry just colour codeing for the blaupunkt unit unit itself, car wireing is not an issue thanks
  • soccer435962 Aug 14, 2009
    sorry did post a reply , somewhere! just the lead from the stacker where it plugs into the head unit. no problems with the car wiring thankyou
    Guru:
  • 1,326 Answers
Try this link it should help
http://carradio.hit.bg/blau.htm
Posted on Aug 14, 2009
    President:
  • 1,723 Answers
Go here for manual, this will help
http://www.retrevo.com/support/Blaupunkt-CDC-A01-Car-Receivers-manual/id/550ci674/t/2/
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Aug 13, 2009
    Top Expert:
  • Blaupunkt Master
  • 80,637 Answers
Do you need the wire colors for the Blaupunkt? or for the car it is is in? if for the car what year, make, model of the car?
Posted on Aug 11, 2009
  • yadayada
    yadayada Aug 12, 2009
    U didn't answer the question
I need to know witch wires go into witch hole on a aiwa cdc-x927myuc head unit
on the wiring harness going into the back of the radio or the wiring harness going out to the car? ... if its the radio then you can buy one from on ebay for 6 bucks AIWA WIRE HARNESS CDC X407 CDC Z137 CDC X927M NEW AI 01
May 09, 2014 | Aiwa CDC-X207 CD Player
Car stereo wiring color codes for Proton Satria
want to know wiring colour codecs standard
Mar 26, 2009 | Car Audio & Video
Blaupunkt CD Changer CDC-A08 - Cartridge eject problem
I am waiting for a reply from the Authorised Blaupunkt Service Agent for a solution to this problem &
shall let you know when it is solved. As per my telcon with him it is an alignment problem of the
Cartridge carrier, but he will have to look at the Unit later, when he is free.
Mar 22, 2009 | Blaupunkt CDC-A08 10-Disc CD Changer
Connecting lead for Blaupunkt CDC-A03 changer
If you can find the installation instructions, you may be able to use individual spade connectors either male or female and connect direct.
BLAUPUNKT CDC A03 Operating And Installation Manual Page 9
Or try somewhere like Crutchfield
Blaupunkt CDC A03
Mar 02, 2018 | Blaupunkt CDC-A03 10-Disc CD Changer
Wiring diagram for cd player
that actually is not for a head set, tha tis for a remote, you plug in the remote that you can buy from an audio store and mount it on the dash....
Nov 26, 2008 | Clarion DB175MP CD Player
16 pin innerconnecting cable
i just went through that same problem, with the pins disengaging from the clip itself. if you reuse the same plug, it might come out again when its installed. my solution is just to get a new wire harness. i got my's for less then 20 bucks shipped to me.
Oct 13, 2008 | Eclipse (AVN7000) Car DVD Player
CD Changer Blaupunkt IDC A09
EBK zeewolde can get code out of serial number
coast 25 / 30 euro
i try to get code for cdc on my vistion radio cd
and try to use disconnect l / r output cdc and place mp3
signal to radio input when cdc turns
greets wilco1v @12move.nl
Aug 02, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC-A09 5 Disc Changer
Hi try unpluging both the cd and the head unit from power for 30 mkins or more. this should reset the system. plug the head unit in 1st then the cd.
regards
Mark
www.blueice-electronics.co.uk
Jul 23, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
What cd changer do I need for the Blaupunkt Sydney rcm 126W head-unit
where can I get a replacement display for my blaupunkt sydney rcm 126
Nov 26, 2007 | Blaupunkt CDC-A08 10-Disc CD Changer
Looking for a control pod.
I recently had a similar problem. In my case the left speaker had no sound. Finally traced the problem to a broken wire inside the control pod plug, which I destroyed by dissecting it. For those who have the experience, or know someone who does, purchase a new plug, which a Mini DIN 8 pin (RS-422 standard). It should be available at any good electronic parts store. Solder new plug on to cable, which requires a fine electronic soldering iron and a fair bit of skill (the wires are very fine).
Look at the plug (from the rear); you will see it comprises a top row of 3 pins equaly spaced; a middle row of 3 pins (there is room for 4 pins but one pin is missing just left of centre); a bottom row of 2 pins. I numbered these as follows:
8 o 7 o 6 o
5 o 4 o 3 o
2 o 1 o
The wire from the controller comprises 8 coloured cores and a bare core. The wiring of the eight cores are as follows:
DIN CORE PCB
pin 8 - brown 8
pin 7 - red 7
pin 6 - orange 6
pin 5 - yellow 5
pin 4 - green 4
pin 3 - blue 3
pin 2 - white 2
pin 1 - black 9
body clamp - bare wire - G
In case your coloured cores vary from mine I have also listed the pin each one goes to on the printed circuit board plug, which will let you identify the colours.
Oct 11, 2007 | Level 9 Sound Designs Monsoon Planar Media...
Blaupunkt CDC-A01 10-Disc CD Changer Logo
102 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
