Question about Tissot T-Touch T33759851
Cannot figure out how to get the dial hands (hour/minute) TO match up with the digital...
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Invicta 6423 I can 't match the time on the hands and the digital watch
Press mode button until only digital seconds are displaying.
Hold both chrono buttons until you see the word sync on display
Press each chrono button until hour and minute hand is at 12:00
Press mode button
Aug 18, 2012 | Watches
How to syncronize time with clock chimes? Howard Miller banjo clock.
The hands on your clock are probably friction fit, meaning that they can be adjusted, possibly even without tools. The hour hand is usually a firm slip fit over a tube, meaning that it can be slid forward and backward an hour or more as long as you hold the minute hand steady to keep the hour shaft from turning.
The minute hand may be trickier to adjust. Sometimes, it, too, is a simple friction fit, and you can pop off the hand (remove the second hand and pull the minute hand straight up off its shaft) before setting it where it should go. Other times, however, the minute hand is on a keyed shaft and has to go on in one of two directions. It's still possible that someone could have assembled your clock incorrectly, however, making the minute hand 30 minutes out of sync with your chimes.
If neither of these ideas helps you, please describe better exactly how the time isn't matching up with the chimes. That will help us better understand the underlying issue.
May 09, 2011 | Watches
Utc Dial does not match Digital utc readout and I can't for the life of me figure out how to sync them
I finally figured this out... You must zero all the hands by setting the mode to CHR and pulling the stem to the second stop. Go through the process of setting the hour and second hand to zero. The secret is that zeroing the MINUTE hand also controls the UTC display zeroing. You will have to crank it until the UTC display reads 0:00 (24:00). Then go back and set the time and so on as usual.
May 11, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Need instructions for my sr927w accurist watch
QUICKSTART - SET THE TIME
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three
seconds. The hour and minute hand will retract to the 12
O’clock position.
3. Select the time zone on the digital display by pressing the
upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of
the digital display will start flashing. Press the
bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds
flashing on the lower half of the digital display. Press the lower
left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes
flashing. Press the lower left button to set the minutes to your
current time.
7. Press the upper right button. You will see the hours flashing.
Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H
flashing. Press the lower left button to switch between 12 hour
and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR
indicator points to CAL.
2. Press and hold the upper left button for three seconds. The
hour and minute hand will retract to the 12 O’clock position.
4. Pull the bottom right button out one click. You will see the
month flashing on the digital display. Press the lower left button
to change the month.
5. Press the upper right button and the date will begin flashing.
Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing.
Press the lower left button to change the year.
7. Push the lower right button back in.
SET THE ALARMS
indicator points to AL1, AL2 or AL3.
4. Pull the lower right button out one click. You will see ON or
OF flashing on the digital display. Press the lower left button to
turn the alarm on or off.
5. Press the upper right button. You will see the hours flashing.
Press the lower left button to change the hour.
flashing. Press the lower left button to change the minutes.
SET THE TIMEZONE
1. Setting the time zones allows you to add or remove cities on
the digital display or switch between daylight saving and
standard time. Begin by pressing the lower right button to move
the mode hand indicator to SET mode on the bottom dial.
2. If the hour or minute hands are obscuring the digital display,
press and hold the upper left button for three seconds. This will
cause the hour and minute hand to retract to the 12 O’clock
position.
3. Now pull the lower right button out one click. You will see the
digital display flashing. Press the upper left button to select
SET to display the city or OFF to not display the city. Press the
lower left button to turn summer time on or off. Summer time is
indicated on the lower part of the digital display. Daylight
savings time must be manually set for each city.
4. Pressing the upper right button will allow you to scroll
through all the cities. After setting, push the lower right button
back in.
USING THE TIMER
1. Press the lower right button to move the mode hand
indicator to TMR mode on the mode dial.
position.
3. Pull the lower right button out one click. You will see the
minutes flashing in the digital display. Change the minutes by
pressing the lower left button. Once you have set the minutes
on the timer, push the lower right button back in.
4. Pressing the upper right button starts and stops the timer.
5. Press the lower left button when the timer is stopped to reset
the timer to its initial preset time.
USING THE CHRONOGRAPH
1. To use the chronograph press the lower right button to move
the mode indicator hand to CHR mode on the mode dial.
3 .To start or stop the chronograph press the upper right
button. If you press the lower left button it will display the split
time for 10 seconds.
4. When the chronograph is stopped press the lower left button
to reset back to zero.
SET THE TIME ZONE
the mode indicator hand to SET mode on the bottom dial.
savings time must be manually set for each city..
through all the cities. After setting, Push the lower right button
back in one click.
Hope this helps. =)
Oct 10, 2009 | Bulova Watch
When I pull out the stem 1 notch I can only change the 1 to 31 date setting. When I pull out the stem to second notch this changes the hour and minute hands. I cannot figure out how to change the 1 to 24...
Try turning the stem the opposite direction. The last watch I had with that feature required a clockwise turn to advance the time or date and a counter clockwise turn to change the day of the week.
Mar 14, 2009 | Watches
Setting instruction for Accurist world time wrist watch
Same just happened to me, performthe following:
The analogue hands are not precisely synchronised with
the digital time?
1. Press the lower right button to move the mode indicator
hand to CHR.
2. Pull the lower right button out one click. The hour, minute
and UTC hands will retract towards the straight up 12 O’clock
position. You will see UTC on the top half of the digital display.
3. Press the upper right button to advance the hands to the
straight up 24-hour position. Use the lower left button to go in
reverse.
4. Press the upper left button. You will see HR on the top half
of the digital display. Press the upper right button to advance
the hour and 24-hour hand clockwise until they both point
straight up at the 24-hour position. Use the lower left button to
move the hand anti-clockwise.
5. Press the upper left button. You will see MIN on the top half
the minute hand clockwise or the lower left button to move
anti-clockwise until it is pointing straight up at the 12 O’clock
position.
6. Push the lower right button back in one click.
The watch malfunctions in some way and the above
procedures do not work.
1. Press the lower right button until the mode indicator hand
points to TME.
2. Pull the lower right button out one click. Press the other
three buttons down simultaneously for three seconds and
release. You will see 8’s on the digital display.
3. Press the upper left button. You will see UTC on the top half
the hands of the top dial to the straight up 24-hour position.
Use the lower left button to go in reverse.
position.
Jul 06, 2008 | Watches
Tissot t touch, time problem
you need to calibrate it.
go to the '24h Cm' screen [T button, then touch centre screen few times]
hold down T button for 5secs
use + button to bring minute hand to 12 o clock position
use - button to bring hour hand to the same place
press centre of screen and it's done!
Phil
Jun 29, 2008 | Tissot T-Touch T33159851 Wrist Watch
Resetting stopwatch dials - Armani AR5331
Pull the crown to first position (where you set the date) then adjust the dials with buttons.
uhrmacher
Jan 10, 2008 | Giorgio Armani Classic AR5326 Wrist Watch
Citizen Skyhawk Time Adjustment Problem
It is possible to set the main analogue hour and minute hand 30 minutes out of phase with the digital readout, but doing so will also put the analogue UTC dial 30 minutes off. It can be done by using a variation of the proceedure for zeroing the watch hands as follows: 1. Rotate the crown in its normal opering position to set the watch in chronograph mode (mode dial pointing to "chr") 2. Pull out the crown to the second click. This should cause all the hands on the watch to return to zero. "HR" should appear on the left-hand digital display. This will allow you to move the hour hand by twisting the crown. Advance it to about half way between the 12 o'clock and 1 o'clock positions. 3. Press the top button. "MIN" should appear in the left-hand digital display. This allows you to adjust the minute hand. Twist the crown to advance it to the 6 o'clock, or 30 minute, position. Note that this will also move the minute hand on the small UTC dial to the 30 minute position. 4. Press the crown back into its normal position. 5. Reset the digital time and date according to a time zone that is in a one-hour offset from UTC. This is not a perfect solution. Your digital readings will show the correct time for all one-hour offset time zones while your analogue nads are 30 minutes out of phase. Your small UTC dial will also be 30 minutes out of phase with the digital UTC. Hope this helps.
May 28, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Jan 22, 2007 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Tissot T-Touch T33759851 Logo
132 people viewed this question
Top Tissot Watches Experts
Ansel Alberto
Ansel Alberto
Mohamed Ismail
Mohamed Ismail
Are you a Tissot Watch Expert? Answer questions, earn points and help others
