Question about IBM ThinkPad R50e Notebook
Thinkpad r50 does not start (repeated clicks could be heard from somewhere inside) unless I press on certain spot at the motherboard (on top of cpu fan). once I've managed it to boot up it hangs if being touched or shaken.
  • vynohradov_v Aug 03, 2009
    100% not hard drive failure. problem remains even without hard drive. it just doesn't power up until I press on certain spot on the motherboard. looks like bad contact on the MB. any ideas? could resoldering solve the problem?
  • IBM Master
  • 32,281 Answers
Any metalic sounds or clicking noise from the hard drive when booting up is an indication of a faulty hard drive, especially when Windows does not start up.
If it does start up but hangs easily then it has not failed completely. I suggest that you backup you data
To test the hard drive, remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port, it this computer cannot detect it as an external hard disk and cannot open the folders and files then it is faulty.
Replace the faulty hard drive in the Thinkpad and install Windows to get a working laptop.
Posted on Aug 02, 2009
Hello my laptop t41 power is not even flash but the adapter is working,am technician and i have troubleshoot allot.
I concur with what Diegotech stated.
To iterate further;
1) The DC Power Jack (DC IN), may have cracked solder joint/s on the motherboard connector, (Female), where the DC Power Jack plugs in.
Resolder
2) The DC Power Jack may be broken.
Center Pin mount, and/or body of DC Power Jack, and/or Outer Shell mount.
Replace DC Power Jack.
3) Wires from the DC Power jack plug to the female connector on the motherboard, may be bad.
Two examples, of a place to buy an IBM ThinkPad T41 DC Power Jack,
1) http://www.buy.com/prod/dc-power-jack-connector-socket-for-ibm-thinkpad-t40-t41-t42-r50-r51-r52/q/sellerid/23962916/loc/101/215782035.html
2) http://www.machinaelectronics.com/store/buypart/IBM_Thinkpad_T41/DC-P001
Past this point it's a bad DC sensor on the motherboard.
Replace motherboard.
IBM ThinkPad T41 Service Manual, (Free),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-ibmlenovo
On this page go down to the 8th line.
The one that starts with > ThinkPad T20.
Go across, and click on > T41
Takes approximately 2 seconds to see the first page, and additional time to fully download.
Page 142 for 14.1 inch LCD screen
Page 151 for 15 inch LCD screen
(PDF file page number box at top)
Dec 01, 2010 | IBM ThinkPad T41 Notebook
How do i get into safe mode on a thinkpad r50?
Please restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load)
A menu should appear. Select Safe Mode and press Enter
Let me know if it able to start in safe mode
Mar 10, 2010 | IBM ThinkPad R50e Notebook
Thermal sensing eror ibm r40
Sorry to say, unless you are a hands on kind of person and can fix it yourself, the thermal sensor is malfunctioning and the only fix is to have it repaired by an authorized dealer.*********** board and CPU have these installed in certain spots to monitor temperatures. I hope this helps and good luck!
Nov 04, 2009 | IBM ThinkPad R40 2722 Notebook
When stat thinkpad R50 beeps 2x and nothing
Two short beeps and no further activity mean you could have a motherboard problem or a memory (RAM) problem.
Reseat the RAM modules and reboot the laptop, if the laptop still doesn't work, remove the RAM module/s and insert them into a working laptop to test them, or take them to you friendly computer shop to have them tested.
If the RAM is OK then the fault is the motherboard. Replacing the motherboard may not be a cost effective solution.
May 14, 2009 | IBM ThinkPad T40 2373 Notebook
WHERE IS THE WIRELESS SWITCH ON THE THINKPAD R50?
Try pressing Fn + F5
That's the hotkey command for the R50
Let me know if this works.
Feb 28, 2009 | IBM ThinkPad T40 2373 Notebook
Requird Lan Driver of IBM Think PAD LAPTOP
Drivers for Vista are not available.
You can find all drivers for R50 clicking below:
IBM Thinkpad Driver Download models R50
Feb 25, 2009 | IBM ThinkPad T23 Notebook
Thinkpad r50
The Power On Password problem is near impossible to crack. It is designed to prevent unauthorized access to the Thinkpad and removing the BIOS battery will not remove the password because the password is stored on an EEPROM chip.
There are no backdoor passwords available, the only option is to ask the person who set the password.
OR
There is a way to hack into the Thinkpad to see and remove the password but it requires electronic skills, a program and a working computer.
For details on how to do this go to :-
http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/
Feb 04, 2009 | IBM ThinkPad R51 Notebook
HAVE A CD ROM TEAC CD-224E PART #1977047B-12 DO YOU KNOW WHAT IT WILL WORK IN
This slim CD Rom is compatible with the Cubid and Travla mini ITX cases.
This is also compatible with:
Portege 3440CT, Portege 3480CT, Portege 3490CT, Portege 4000, Portege 4000CT, Portege 4005, Portege 4010, Portege M100, Portege M200, Portege M205, Portege M205-S809, Portege M205-S810, ProLiant Content Delivery , ProLiant DL140, ProLiant DL320, ProLiant DL360, ProLiant DL380 G2, ProLiant DL380 G3, ProLiant DL560, ProLiant DL560 R01, ProLiant DL580, ProLiant DL585, ProLiant DL590, ProLiant DL590 R01, SAN Management, Satellite 1550CDS, Satellite 1555CDS, Satellite 1715XCDS, Satellite 1730-S101, Satellite 1730CDT, Satellite 1735-S101, Satellite 1800, Satellite 1800-S203, Satellite 1805, Satellite 1805-S203, Satellite 2060CDS, Satellite 2065CDS, Satellite 2100CDS, Satellite 2100CDT, Satellite 2105CDS, Satellite 2140CDS, Satellite 2140XCDS, Satellite 2180CDT, Satellite 2210CDT, Satellite 2210XCDS, Satellite 2215XCDS, Satellite 2230CDS, Satellite 2250CDT, Satellite 2250XCDS, Satellite 2255XCDS, Satellite 2510CDS, Satellite 2515CDS, Satellite 2520CDS, Satellite 2530CDS, Satellite 2535CDS, Satellite 2540CDS, Satellite 2540CDT, Satellite 2540XCDT, Satellite 2545CDS, Satellite 2545CDT, Satellite 2545XCDT, Satellite 2590CDS, Satellite 2590CDT, Satellite 2595CDS, Satellite 2595CDT, Satellite 4000CDS, Satellite 4000CDT, Satellite 4005CDS, Satellite 4005CDT, Satellite 4010CDS, Satellite 4010CDT, Satellite 4015CDS, Satellite 4015CDT, Satellite 4020CDT, Satellite 4025CDT, Satellite 4030CDS, Satellite 4030CDT, Satellite 4060CDT, Satellite 4060XCDT, Satellite 4070CDS, Satellite 4080XCDT, Satellite 4085XCDT, Satellite Pro 4600 (14.1), Satellite Pro 4600 (15), Satellite Pro 6000 (14.1), Satellite Pro 6000 (15), Satellite Pro 6100 (14.1), Satellite Pro 6100 (15) , Satellite Pro 6100 (15 SXGA), Satellite Pro 6100 (15 UXGA), Satellite Pro M10, Satellite Pro M10-S405, Satellite Pro M10-S406, Satellite Pro M10-S407, Satellite Pro M10-SP405 (14.1), Satellite Pro M10-SP405 (15), Satellite Pro M15-S405, Satellite Pro M15-S406, SUN FIRE V100, SUN FIRE V120, Tecra (14.1) , Tecra (14.1 SXGA) , Tecra 8000, Tecra 8000 (12.1), Tecra 8000 (12.1 STN), Tecra 8000 (13.3), Tecra 8000 (14.1), Tecra 8000 (14.1 PIII) , Tecra 8000STN, Tecra 8100, Tecra 8100 (13.3), Tecra 8100 (14.1), Tecra 8200, Tecra 9000, Tecra 9100, Tecra PE2100, Tecra S1 (14.1), Tecra S1 (15) , Tecra S1 (15 UXGA), Tecra TE2000, Tecra TE2100, ThinkPad 1300 1171 (12.1) , ThinkPad R50 1829 (14.1) , ThinkPad R50 1829 (15.0) , ThinkPad R50 1830 (14.1) , ThinkPad R50 1830 (15.0) , ThinkPad R50 1831 (14.1) , ThinkPad R50 1831 (15.0) , ThinkPad R50 1836 (14.1) , ThinkPad R50 1836 (15.0) , ThinkPad R50 1840 (14.1) , ThinkPad R50 1840 (15.0) , ThinkPad R50 1841 (14.1) , ThinkPad R50 1841 (15.0) , ThinkPad R50e 1834 (14.1) , ThinkPad R50e 1834 (15.0) , ThinkPad R50e 1842 (14.1) , ThinkPad R50e 1842 (15.0) , ThinkPad R50p 1832, ThinkPad R50p 1833, ThinkPad R51 1829 (14.1) , ThinkPad R51 1829 (15.0) , ThinkPad R51 1830 (14.1) , ThinkPad R51 1830 (15.0) , ThinkPad R51 1831 (14.1) , ThinkPad R51 1831 (15.0) , ThinkPad R51 1836 (14.1) , ThinkPad R51 1836 (15.0) , ThinkPad R51 1841 (14.1) , ThinkPad R51 1841 (15.0) , ThinkPad R51 2883 (14.1) , ThinkPad R51 2883 (15.0) , ThinkPad R51 2887 (14.1) , ThinkPad R51 2887 (15.0) , ThinkPad R51 2888 (14.1) , ThinkPad R51 2888 (15.0) , ThinkPad R51 2889 (14.1) , ThinkPad R51 2889 (15.0) , ThinkPad R51 2894 (14.1) , ThinkPad R51 2894 (15.0) , ThinkPad R51 2895 (14.1) , ThinkPad R51 2895 (15.0) , TRANSPORT NX
Mar 05, 2008 | Computers & Internet
Total failure of IBM Thinkpad R50 after connecting sony clie PDA
Your colleagues are correct, the problem with laptops is that the motherboard and powersupply are integrated,
if there is a seperate powerboard, usually the mains inlet runs through the mainboard itself to get to it. As it,s located under the touchpad. ( On certain Models )
What you,ve actually done is put an input current into your motherboard via the USB.
These are designed to output 5v pos And 5v negative. + 2 x Data transfer/signal in/out.
If you take this in for repair, you,ll be looking at £75+ Or $150+ Depending where you are. Just to Be Looked At.
For them to possibly charge you an additional £200+ Or $400 for a new motherboard.
Sorry for the Bad-News but i,d advise looking into buying a replacement laptop, and put it down to experience.
Mike @ Compurepair.
Posted @ 09.20 AM ( G.M.T )
Mar 05, 2008 | IBM ThinkPad R50e Notebook
IBM ThinkPad R50e Notebook Logo
483 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
