Question about Frigidaire GLTF2940ES Front Load Washer
Water, hair and slimey material gathers within the folds of the flexible gasket of the door glass.
What can I do/
  • 249 Answers
Re: Water, hair and slimey material gathers within the folds of the flexible gasket of the door glass. - Frigidaire...
Not enough info. Please forward more
Posted on Nov 25, 2007
0 characters
3 Points
Ways to stop boot sealer from leaking
Hello. I need the model number AND the serial number to help you accurately. If this is the front loading Neptune, be aware--there are MANY service bulletins associated with it. Depending on the model/serial number, somewhere around 19 to 25 service bulletins exist. When there is a leak in the boot(also called a bellow, the rubber part that seals against the door glass), it must be replaced. Due to vibration/movement/water during agitate and spin, almost no type of adhesive will hold securely. People have tried to patch these parts but it always ends up leaking again after awhile. NOTE: Make sure the door glass is CLEAN at the rear(the area closest to the door itself where the seal is made with the bellow). If pet hair, hardened soap residue, almost any debris gets in-between the rubber seal area and the glass, water will weep through and drizzle down the front of the washer. Pet hair and almost any fibrous material will cause a wicking action that will cause leakage. I hope I helped you!
Sep 11, 2015 | Maytag Neptune Washing Machines
How to clean the inside seal of a frididaire front load washer
Good Afternoon Friend,
I understand you want to know how to clean the inside seal of your Frigidaire washer, model# ATF7000E. Below are instructions for cleaning the inside of your washer, including the seal:
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer, and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum. Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a nonabrasive household cleanser. This prevents dye transfer to future loads.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
Jul 01, 2014 | Frigidaire Affinity ATF7000E Front Load...
Water leaking out from bottom of door during operation
clean the glass real good,, if it still leaks take a hair dryer to the part of the gasket that seals around the door,, heat it while pulling the lip out toward you ( not much just try to get it straight) if the doesnt work you will need to replace your gasket,, also know as the bellows
Jan 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have water seeping out from the door. I don't know if this is the only place. I cleaned the flexible gasket, it had a lot of what I would call mold. I didn't find a puncture in it. The door seems to have...
theres a metal retaining ring that goes around the outside of the boot aka flexible gasket make sure that it is properly seated also u could have a pin hole in that gasket and have it leaking on your floor. You might want to just replace the boot rather then using a magnifying glass to look for the hole
Apr 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Door gasket leaks is it hard to replace ?
Before you go to the expense of replacing the door gasket, try cleaning the glass door itself with a soft plastic scratcher. Scum builds up on the glass and does not allow a tight seal. Be careful not to use a metal scratcher as it might scratch you glass door. If this does'nt work then ispect your gasket for tears or holes in the gasket, and inspect your door hinges to make sure they have not been bent. Good Luck, Appliance Specialists
Mar 25, 2010 | Whirlpool GHW9200L Front Load Washer
Water trickling down front of door when washing
Check no small tare in gasket , check no interference between seal and glass ( small amounts of hair etc.. can build up and break the seal) . Check water is not coming from soap drawer and running down behind door facia.
Nov 01, 2009 | Washing Machines
LG front load washing machine water leaks with heavy loads
If your water is leaking with heavy loads, the first thing you want to check is the gasket (door boot) attached to the tub. Look for holes or rips in the bellows part(where the water settles) and around where it contacts the door. Any nicks or holes will cause leakage. Also, check the glass dome on the door towards the bottom. If it has dirt or hair buildup on it, it will leak with any pressure on the door.
Jul 15, 2009 | Washing Machines
AAA160 Washing Machine
yes most certainly, with leaks it is either the seals or cracks in hoses or rust holes in wash cylinder, but most likely the first too because of being a fairly new model
Jul 01, 2009 | Hoover AAA160 Front Load Washer
Small ammount of water leaks at bottom of door during wash
I have this same problem. What I do is carefully clean the part of the glass door where it meets the rubber gasket when you close the door. Bits of crud tend to accumulate there and break the seal between the smooth glass and the rubber gasket. This causes small amounts of water to leak out.
I don't use an abrasive cleanser. I generally clean it when it is dry and crusty with my hand or with my fingernails if it stubborn. You don't want to scratch the smooth glass surface. fingernails are much softer than glass and won't scratch the glass.
I also take a look at the rubber gasket and see if there is any crud sticking on that and very gently clean it off when it is dry and crusty. If the gasket gets torn, you'll probably need to replace it. I don't know how much that would cost. This should stop the dribbles.
Jan 11, 2009 | LG WM-1832C Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
35 people viewed this question
Top Frigidaire Washing Machines Experts
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
