Question about Toshiba Computers & Internet
I got a cooling fan that works but it still doesn't power up
  • 3 Answers
You may not have fit your wire correctly.
Posted on Aug 03, 2009
Cooling fan inop 1995 mustang gt 5.o
you can check the cooling fan by disconnecting the plug at the motor and run jumper wires from the battery directly to the fan motor it should run if its working if it doesn`t run then the cooling fan motor needs replacing. if it does run then check the plug for a bad connection. other things can cause this like the cooling fan relay, the coolant sensor that sends a signal for the computer to turn on the cooling fan by sending a signal to the relay.
Sep 08, 2014 | Cars & Trucks
System fan
Some cpu cooling fan especially on laptop are basically have sensor. There is a certain temperature in order to make the cooling fan activate, when if it's cool then the cooling fan turn off automatically. Same with the air condition thermostat. Good day.....
Other way is to buy a usb cooling pad that fit the size of your laptop. If keeps cool your laptop though and i tried that already and it's effective to cool down the temperature.
Jun 29, 2013 | Compaq Computers & Internet
2004 mazda mpv engine racing and cooling fan not working
coolant temp sensor tells the computer how hot or cold the engine is so it can regulate the idle and fuel mixture, when it fails there usually is no cooling fan and you will have trouble starting the engine and keeping it running.
Oct 08, 2012 | 2004 Mazda MPV
Cooling fan temp light stays on when air condition is on. fans are not kicking on. Is it the fan module ?
I didn't know it had a light on the dash that said "cooling fan temp".
My 93 doesn't.
The cooling fans are controlled by the computer and turned on when the ac is running or when the engine reaches 220 degrees.
A mechanic would check the fuse and relay for power and the fan motor for power and ground.
Aug 26, 2012 | Cadillac DeVille Cars & Trucks
The fan on my 2004 Grand Prix quit working 2 weeks ago. Checked fuses and that doesn't seem to be the problem. Any ideas?
if its the cooling fan at the rad then your talking about then if you disconnect the plug on the fan and run jumper wires to it directly from the battery it should run.also check the plug connection to make sure its in good condition and no corrosion.if you jump the fan motor and it doesn`t run tap the motor it should run either way if it doesn`t then the cooling fan motor needs replacing.
Nov 03, 2011 | 2004 Pontiac Grand Prix
Air conditioner in my 2004 volkwagon passat blows cool for a few minutes than blows warm. I had dyed ran through for leakes, recharged and filled with freon and that didn't seem to fix it. Help
You need to check and see if the cooling fan (electric) on the radiator is coming on. If this fan does not come on the high side pressure will go over 400psi and turn off the compressor until the press. drops. either the cooling fan motor is bad, the cooling fan relay or the fuse for the cooling fan relay. you can check the cooling fan by removing the cover of the power steering reservoir and pulling the wiring harness out from under the bracket. the fan has two wires in its connector, one red and one brown (there may be a tracer color on either one) these two wires are heavy gauge, like #10. unplug the harness and feed power to the connector on the fan side and see if its spins. If it works your problem is probably the fuse or relay. If it doesn't it may be seized or stuck or burned out. Reed, Aquidenck Motors
Jun 20, 2011 | 2004 Volkswagen Passat
I have a 92 corvette and I have power at the cooling fan relays, but I cann,t get power to the fans. Also the inside heating & air fan doesn,t work either.
mcdevito75 here, At the relays wiggle the wires to see for loose connection, also see if you can jump the fan direct to the battery to see if the fan works., Also the fan relay could be bad, or the temp. Between the relays and fan there is a temp sensor that puts the fan on, jump that and see if the fan works.
Jun 16, 2010 | 1992 Chevrolet Corvette
The cooling fans just work with the a/c on
the cooling fan circuit switches the cooling fan on using a thermo switch ,which is usually mounted in the thermostat housing,it will have 2 x wires ,if u bridge these together and the fan comes on ,then the swiych is faulty, if the fan doesn,t come on u should check the fuses
Mar 07, 2010 | 2000 Buick LeSabre
Cooling fan
Here are the cooling system diagnostic steps...First does the cooling fan kick on (with engine hot)? If not, check the fuse, if good then check the thermoswitch in the radiator (it's about an inch and a half in diameter located on the lower part of the radiator with two wires ) by disconnecting the wires and touching them together (again, with engine hot...at least 190 degrees) if the fan comes on, you have a bad switch. If not connect a 10 gauge jumper wire from the battery to the fan itself (there are three terminals,,, one high, one low and ground). With power direct from the battery (and a ground wire, if necessary) fan should run... if not replace the fan assembly... if it does run then you have a bad cooling fan relay (under the dash, I believe). Hope this helps... ;-)
Apr 19, 2009 | 1995 Volkswagen Passat
A/C FAN NOT WORKING
I presume you are talking about the blower motor and not the cooling fan on the engine?
If you have checked the fuse then ensure there is power at the blower motor when switched on.
Jul 22, 2008 | 2005 Jeep Wrangler
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
