Question about Netopia (3347NWG-ENT) Router (3347NWGENT)
Laptop cant connect to router
Okay my router is acting weird.First of all, I reset my router to fix a problem but now I cant access my router on my laptop.My laptop keep saying can not connect to the router.Can someone please tell me whats wrong?
    Problem Solver:
  • 6 Answers
Wireless or wired? Can you ping the IP address on your laptop?
Posted on Aug 01, 2009
My access point works fine for about an hour then the act indicator goes off and it becomes undiscoverable for my laptop. what is the solution?
Ensure that your laptop WIFI is correctly setup and specifically turn on the option:
'connect even if the network is not broadcasting its name SSID'.
If it does not help, try the followings in order:
  • Reset the router (make sure that you backup your current router setup or know how to reload i / reconfigure).
  • Change Wifi Channel on your router as the current channel frequency might be clashing with other wireless devices (handsfree?).
May 02, 2011 | Linksys WAP54G (WAP54G-UK) 802.11b/g...
I have a dsl modem from our telecommunication company, it works well though but when I connect my dlink dsl-2640T router, the internet access gets lost. There's this one time that both laptops work using...
I would start by doing a reset of the router to factory using its procedure. Most routers have a reset button that if you hold it down for 10 seconds will reset back to when it was new and erases your settings but might be the trick to get it to work again. After you input your settings again, I'd check the router maker's support site for a firmware update and update the router. These updates can have fixes for just such issues.
I have had older routers that failed and will give weird behavior like you described. I just replaced it with an Apple Airport router and have been delighted with it.
Feb 03, 2011 | Computers & Internet
Well i recently put widnows 7 on my laptop and because i forgot the password of my wireless i reset the router, When i went to turn it back on everything seemed fine i connected to it with the defualt...
Be sure your laptop is on the same network as the router (192.168.1.x) X being different from the routers address. Connect via the Ethernet cable to the routers IP address. Enter the default user/password to configure.
Mar 05, 2010 | NetGear WGR614 Wireless Router
I just reset a belkin g mimo router I cant conect
connect your laptop to your router via patch cord to be able to access the router configuration, then configure it, change the wep keys..etc
hope this thing help
Jan 10, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cant remember passkey for wireless laptop connection
If you hook into the router with a wired connection, youu should be able to get into the router setup menu to find the passkey. If you can't remember the access for the router menu, you may have to reset the router and redo setup.
Nov 14, 2009 | 2wire 2700HG-B Router (2700HGB)
Belkin wireless router reset password problems
You have to connect(wired) through one of the ports on the back of belkin to a laptop(or PC) physically.And this laptop(orPC) should have the software that came in the CD as part of the router packaging.
Then you open the web browser and and type http://192.168.1.1 on the address bar.This should let you access the router from where you can configure your settings..Network name,password,password for the router itself etc.
HTH
Aug 12, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My router DI-624 does not get an IP address assigned to it automatically. I checked all settings as per manual / How can I solve the problem?.Any help is much appreciated.
Is the M2 LED light on? That's a light that tells you if a problem exists with the hardware itself.
If you connect the laptop directly to the modem does it connect okay? That will tell you whether it's your laptop and cable that might be the problem.
If it does connect okay with just the laptop and modem in the mix try these steps:
-disconnect the modem from your laptop
-double check that your laptop has no static IP info on the network card including a gateway or DNS settings
-power off your laptop and the router
-connect the laptop to the router (port 1 on the back)
-disconnect the router from the modem so only the laptop is connected to it
-power on the router
-power on the laptop
-make sure a green light appears on the front for port 1
-type in ipconfig /flushdns at a command prompt
-see if you can ping the default IP address 192.168.0.1
-if you can, see if you can connect to the router console
-if not, hold the reset button in for 10 seconds and release
-wait for the router to come back to green lights
-reboot your laptop
-try to access console menu again
If your laptop doesn't work when connecting directly to the modem, we can take other troubleshooting steps together.
Let me know how it goes and if it works don't forget to rate this solution! :)
Mar 30, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Cant connect to internet from laptop
The network key is stored in the router, and your manual will tell you how to access it.
If you don't have access to the router's web page, you'll need to reset the router and start over.
Dec 20, 2007 | Linksys Wireless-G WRT54G Router
Laptop not connecting to network
Haved u tries Unplagging your Cable or DSL modem and also unplug the router.  Connect them again and this shoud fix your problem.  If not unplug both again but this time also Reset the router after its on.  hope this helps
Oct 27, 2007 | Belkin (F5D7132) 802.11b/g Wireless Access...
Netopia (3347NWG-ENT) Router (3347NWGENT) Logo
172 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
