Question about Philips HTS-6500/37 System
DVD loaded into player,system says no disc and cannot eject and cannot play
I had this same problem and fixed it by unplugging main power cord from back of unit for 30 minutes and voila, seems fine again
Posted on Aug 01, 2009
Clarion ohm107vd in car DVD won't eject disc
It not the disc, it won't take a disc ...... if I go to put one in it Makes noise but won't actually take the disc. Would this be the loading gear and can it be fixed or?
Jan 08, 2012 | Clarion Car Audio & Video
My dvd wont eject. when i press open it blinks for a minute then goes to loading! then dvd will then play. I can hear it running but it will not eject the dvd.
unplug it for 10 - 15 mins... when you plug it back press the stop/eject quickly (player will automatic try to load disc)
Aug 09, 2011 | Toshiba SD-6000
My sony dvd player will not allow the tray to eject. when the eject button is presses "tray locked" appears on the screen
Follow this procedure to lock and unlock the disc tray.
IMPORTANT: This procedure will only work while a disc is inserted in the player and when the disc is playing.
While a disc is playing in the Blu-ray Disc player, press the SYSTEM MENU button on the remote control.
After the System Menu screen appears, slowly press 0 0 0 0 7 6 6 9 using the number pad on the remote control. NOTES:
If the procedure has been performed correctly, the disc will stop playing and the player will go in the Resume mode. Each time this procedure is performed the disc tray will either lock or unlock.
Jan 02, 2011 | Sony BDP-S300 Blu-Ray Disc Player
My factory dvd player in my 2003 Mercury Mountaineer has a dvd stuck in it. The dvd will play, but when I hit eject the screen states the loader is blocked. Nothing is jammed or in the loading slot. ...
Unfortunately there isn't an easy fix for an issue like this other than taking it in for service. Some dvd players lock the disc onto a spindle, some use a vacuum type loading system and some use a gear type system for loading and ejecting. Regardless of which type of loading mechanism you have, the only way to fix the problem is to disassemble the dvd player and either fix or replace the bad parts. Sorry to be the bearer of bad news, I wish you the best with it though.
Dec 01, 2010 | Car Audio & Video
When I insert a DVD to play it will not play. On the dvd screen it only shows "LOAD" and after a while it will eject the disc.
If it happens with all discs, the motor "spin-up" system is broken. Best to buy a new one.
Aug 19, 2010 | Samsung DVD-R135
DvD disc won play
the lazer might not be seeing the disc properly try a disc cleaner which has nylon string on it and they clean the lazer lens
Jul 06, 2010 | Onkyo DV-SP800 DVD Player
LG DVD player Disc Error message even when playing lens cleaners!
LG DVD Player Disc Tray opens & closes automatically & unnecesarrily
Apr 29, 2009 | LG LXD5230 System
DVD player will not open
Hi, I think the DVD disc was not positioned properly (since yo udid mention that the disc did not play) adn that it has jammed the tray. Please avoid furtherusing the unit as this may damage the eject gear mechanism. Only recommendation is to bring the unit for service and they can physically rmeove the jammed disc.
Aug 09, 2008 | Bose Lifestyle 18 System
Region free code for power acoustik ptid-5300
Try the following which i managed to get from POWER ACOUSTIK technical support:
Multi-region for PTID4006T, 406T, 4005, 405, 8006T, 8004, 4003, 5000, 5800, 5300, 530.
1. Turn the unit on and insert a DVD disc. The unit will display LOADING.
2. While the DVD player is LOADING press the following keys:
SET-UP, then press 0, 0, 0, 0 key (0 four times), then ARROW DOWN key (to change the zone to region all 0), then BAND/ENTER key and SET-UP
3. To finish the procedure, push the EJECT key. The disc will eject... Wait and the DVD disc will re-load and play.
Jul 13, 2008 | Jensen VM9510 Car DVD Player
Philips HTS-6500/37 System Logo
468 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
