Question about Refrigerators
Freezer o.k., Fridge barely cooling.
GE Profile side by side (TFXB 27FR) Started with ''DE'' defrost system check light blinking, unplug-wait-plug back in fixed, now freezer o.k. but fridge barely cooling.
Expose the coil in the freezer and defrost it with a hair dryer.
Posted on Aug 01, 2009
WHY THE FREEZER FUNCTIONS BUT THE REFRIGERATOR SECTION DOES NOT FUNCTION ON A GE PROFILE BRITA FRIDGE?
Check for failed evaporator (cooling coil) fan motor, located in the freezer or a failed component in the automatic defrost system.
Sep 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
Temprature blinking
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Jul 07, 2013 | Freezers
Hi, our ge profile refrigerator is having temp
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
BLINKING dE(DEFROST) LIGHT ON OUTSIDE DOOR PANEL OF GE TFX27FH.
look for the manual its usually underneath...remove the grille and look inside. sometimes its taped up
i can help you troubleshoot if you find!
Oct 08, 2009 | Freezers
GE Profile side-by-side fridge and freezer not cooling properly
Could be a few things. Condenser coil clean? Is the back panel cover of the compressor panel in place? It could have a bad part in the defrost system and it's built up with frost on the coil. To see if this is the problem, unplug the refrigerator and leave the doors open for 24 - 36 hrs. then plug it back in. It should work normal again for a few days until the frost builds back up. If this is the case the defrost system needs repair.
Aug 21, 2009 | GE Profile¿ Arctica® Energy...
GE Profile - fridge not cooling
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 17, 2009 | Refrigerators
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Have a 2 year old SAMSUNG RS2545SH Side by Side
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
