Question about Bazooka ELA300.1 Car Audio Amplifier
Csa300.1 bazooka 500 watts
It was working okay until I turned up the volume. It got very loud and I guess it just automatically died. I checked all wires and fuse. I have no clue because the light went to red. It was suppose to be green, but I think it still works. When I turn off the speaker and listen to the sub to see if the amp is working, the amp works but you can only hear the sub jumping couple of times...I think the amp if fried...Not sure because there's still noise...It's red the whole time, I uninstalled the amp and put it back on and it still wont work.
    Problem Solver:
  • 10 Answers
Sounds like you may have blown your sub...sheck the spyder inside of it and see if it is stiff..if the speaker doesnt seem too responsive when you press on it, its probably blown...
Posted on Aug 01, 2009
Will a Pyle PT530A 350watt receiver work with a pair of 4ohm 200wattRMS per speaker
Yes they will, but alway be careful with audio gear.
There are 30 watt speakers that can handle peaks of 500 watts for a short time. There are also 500 watt speakers I can "kill" with a peak less than 500 watt.
Most amplifier manufactures like to boost about the power an amplifier can deliver and their speakers can handle. But as long as they don't tell how long the speaker can handle the power and at what frequencies the value does not say anything.
Whit high power amplifiers, never switch over while the volume if at maximum.
You know what I mean. I can't hear my CD player. first turn the volume to the max and then press the CD button, and the speakers will explode. Always when you preaa any button on the pre amp juts lower de volume first and you won't destroy your speakers.
My old Kef Concerto's are almost 40 years of age. 30 watt and are running on a 500 watt Yamaha amplifier for years now. And believe me my chidden know how to punish a speaker. Never any problem, nr with the speakers, nor with the amplifiers.
Jul 28, 2014 | Car Audio & Video
I have troubles with a to little speakersound i have checked the fuse and its okay its a new one for me this pmp5000 can you tell me i have 1000 watt speakers do they not play loud with this
These can develop around 500 Wattts or so into speakerss that are 4 ohm.
If your speakers are 8 ohm the max power to each is around 250 Watts.
The efficiency of your speakers may reduce the loudness . The power rating of your speakers really has nothing to do with the loudness, only the power that can safely be sent to the speaker.
Sep 15, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Can you use a bazooka ba1150 to power up an infinity 1230w sub? not a techie just happened to have these two items and was wondering if i can use them together. thanks.
This is an 150 RMS amp, but the ratings say it'll push 2 10's.
You probably won't get much out of that amp with a 1230 watt subwoofer.
The subwoofer you are wanting to run is 300 RMS, so you'll get half the power you could be pulling. But it would do okay I guess. Nothing like what you could get with a different amp though. You need like a 1000 watt amp to get the most out of your sub. But "YES" you can use them together.
Aug 01, 2010 | Bazooka BA1150 150 Watt Monoblock...
Subs stop producing sound when stero volume is turned up
make sure your wiring is correct.. negative to negative positive to positive.
Oct 24, 2009 | Jl Audio 500/1 Car Audio Amplifier
Its now getting any power
i need more information to help you with this 1 do you have the remote (typicaly blue) wire connected? if so what guadge wire are you running to it and where are you connecting your ground
Sep 24, 2009 | Bazooka 500-Watt Monoblock Amplifier...
I'm having problems getting full power to my sub.
you can only bridge it if your amp is made for it......the only other way is to have another of the same amp.......tell me what you come up with
Mar 05, 2009 | Bazooka 500-Watt Monoblock Amplifier...
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
Amp turns off after a couple minutes of playing
That's a new one on me.
The only electrical difference is the battery voltage on ACC is 12 volts. When you start the truck the alternator should put out about 13.7 volts. That would make me suspect a bad power supply in the amp or the output transistors, something in the amp is getting hot at the higher voltage and shutting it down
That would explain why you get two minutes ,and than when you turn the truck off the voltage drops back to 12 volts and the amp comes out of protect mode. Try a amp swap or if it's a self amplified tube, hook it up to a friends system.
Never hurts to put a voltmeter on the battery with the truck running, and off, to make sure the alternators voltage regulator
is not faulty and exceeding the rated voltage.
Good luck, let me know what happens, I'll ad it to the book.
Regards Paul
Jun 12, 2008 | Bazooka CSA150.1 Car Audio Amplifier
Stops working
THEY MIGHT BE DRAWING MORE CURRENT THEN UR ALTERNATOR CAN HANDLE.TRY CONNECTING A CAPACITOR FOR THE SUBS.
Feb 01, 2008 | Bazooka EL1204 Car Subwoofer
Watts
The advertised wattage for your amp is:
300 watts RMS X 2 @ 4 ohms
600 watts RMS X 2 @ 2 ohms
The actual wattage you will be using will depend on what type/impedence speakers you are using, and how they are wired. Here's a link to some more of the specs of your amp:
http://www.bazooka.com/productAutoAmplifiersRS.asp?id=199
I hope this helps.
Nov 30, 2007 | Bazooka RSA75.2HC Car Audio Amplifier
Bazooka ELA300.1 Car Audio Amplifier Logo
144 people viewed this question
Top Bazooka Car Audio & Video Experts
Radames Pagan
Radames Pagan
Mark Skinner
Tygh Duval
Tygh Duval
Are you a Bazooka Car Audio and Video Expert? Answer questions, earn points and help others
