Question about Whirlpool Accubake RF362LXTS Electric Kitchen Range
I believe there is a mouse nest in the insulation of my whirlpool ceramic stove top, how do I remove the stove top to clean it out?
  • 5,911 Answers
Open the oven door and locate the screws under the bottom of the front edge of the cook top. Remove the screws and the cook top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
If there is evidence of any rodent infestation, make sure you do a thorough inspection of all internal wiring. Mice love to chew on wire insulation. Any bare wires can result in appliance failure, electric shock, or become a fire hazard. Make sure you do not use the range until repairs are made if there are signs of any wire damage.
NOTE: Ensure you also check the wiring inside the operator console. Remove the back panel to access.
If you have questions, please let me know. I hope this helps you.
Posted on Aug 02, 2009
I have a small, 4-burner gas stove; no wondow in the oven door. I think my stove had a mouse infestation. I think the insulation above the oven has mouse urine in it; I can smell it, although there is no...
It is common for mice to get into the oven box insulation and nest. I had this problem before and its not likely you'll be able to get rid of the odor without replacing the insulation. Another issue is any fecal matter the mice leave behind. This can become a health hazard (expecially in an appliance that you use to prepare food). I would recommend replacing the insulation. If the model oven is correct, the insulation can be purchased for around $20 at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The part number will depend upon your COMPLETE model number (located on a nameplate around the oven door opening, or lower drawer opening (if equipped). On some models, the model number will appear on the back of the operator console. The first three sites on the list include exploded view parts illustrations to assist you with locating and properly indentifying any parts you may need. The insulation for the Magic Chef 31000 series is listed under the "Body" parts list.
To replace the insulation on MOST ranges, all you should have to do is lift the range top to access the oven box. The top on most ranges can be lifted by removing a series of screws that are usually holding it secure under the bottom of the front edge. You will need to open the oven door to see them. CAUTION: Do not lean on the oven door as this may cause damage to the door hinges and springs.
On the Magic Chef 31000 series, it appears that you will need to remove the burner control knobs, followed by screws holding the burner control control panel in place. You should also remove all the orifice covers and burner grates from the top of the range. Once the burner control is removed, remove the top panel, followed by the burner box top panel. The insulation will be wrapped around the oven box. It should just lift out. Depending on the potential infestation, you may want to wear a dust mask and use a vaccum to **** up any loose debris. CAUTION: Turn off the gas supply BEFORE attempting any repairs - if this is a gas range.
If you have questions, please post back and let me know. I hope this helps you.
Apr 28, 2011 | Magic Chef 31000 Gas Kitchen Range
Have a friend that needs to replace insulation on stove whats the best way?
Believe it or not, this is standard owens corning fiberglass wall insulation. It's rather inexpensive, and works great on these stoves. Just remove the outer shell, strip clean and replace it. I replace the insulation when grease, dirt and roaches build up and produce an odor.
You will be surprised how basic the disassembly is on these. Don't forget to do the oven door as well, it usually gets the most dirty over time.
Mar 23, 2010 | Whirlpool GR460 Electric Kitchen Range
Discoloration on ceramic top
Hi- High temps make for tricky maintenance of glass or ceramic tops. The heat element must pass its heat energy through the glass or ceramic and into the pan. Water droplets will steam away, while a spatter of oil or even a few grains of sugar will melt and burn to a tough film of carbon on the surface. The obvious preventitive measures of checking pan bottoms thoroughly before contact with clean (yes- very clean) cooktop surface mean most spots may be small, they can be annoying to look at and tough to remove. My best cleaning results for these spots came from using a VERY small amount of OVEN cleaner (use gloves) on a paper towel placed on spot for a few minutes. A clean, new razor blade may be used to scrape off film. Hope this helps. - Thanks- ED
Feb 25, 2010 | Kitchen Ranges
Whirlpool super capacity 465 cracked ceramic element
You are looking at approx. $450.
Jan 01, 2010 | Ovens
Rat Nest in oven insulation
No the insulation must be replaced . the insulation makes the oven cycle on and off less frequently and also keeps the exposed metal surfaces cooler.
Dec 19, 2008 | Tappan TGF320 Gas Kitchen Range
Hot poinbt gas stove , mouse inside,
We had this happen recently. The smell of urine got to be too much. My wife wouldn't even go into the kitchen. I took the stove apart. the insulation under the range, which is where he was living, was soaked in urine and **** .I removed all the insulation. Spoke to a repair man. Replaced insulation with pink house fiberglas insuation and gave it a good cleaning. Smeel is gone. Repairman said this happens all the time and is a an easy but labor-intensive job. Call someone to do it if you aren't comfortable taking your stove apart.
Oct 22, 2008 | Kitchen Ranges
Whirlpool 465 large capacity electric ceramic top oven failure
How much time I need to set to do the oven self cleaning ?
I have electric Whirpool oven 465 automatic
Oct 18, 2008 | Maytag MES5870A Electric Kitchen Range
Whirlpool electric stove
the sensor is built on to the top of the surface element if it was me id replace both the element and switch so you only have to go in once but its probably the element
Jan 19, 2008 | Kitchen Ranges
Whirlpool Accubake RF362LXTS Electric Kitchen Range Logo
358 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
