A balloon appeared that battery was low even though it was connected to the power at that time. I had started to turn off the laptop and at the same checked if the power cable was connected correctly. while I was doing this the cable became unconnected and the screen went dead at the same time. the laptop will not start now, what should I do? RGDS David McCormick
  • dmc_cormick Aug 01, 2009
    the laptop is DELL VOSTRO 1510. I removed the battery as suggested and after 5 minutes replaced battery and connected power switched on - nothing
    anything else I should try
    rgds
    David McCormick
  • 13,433 Answers
Take the battery and the power adapter off from the laptop wait 5 minutes, plug in the power adapter and try turning it on what happens?
Please also include the brand and model in your query.
Posted on Aug 01, 2009
  • Ekse Aug 01, 2009
    Please disconnect the battery and test alone with power adapter, does the DC in led turn on? then connect the battery, does the battery led turn to charging ?
    Do the power leds blink when you attempt to turn it on? does there appear to be a sequence that they blink in?
Flashing yellow light
attery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery c02983514.gif When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
Dec 20, 2013 | HP Pavilion ze4300 Notebook
Our year old Dell Inspiron 1545 currently won't turn on anymore, for the past week it would not charge so we were just keeping it plugged in. It claimed the ac adapter was unknown, even though we had been...
You have a bad or loose DC connector on the system board:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Dell Inspiron 1545 Notebook
3000 c200 is dead and wont start up even though there is power to ac adaptor (warm)
Remove the battery and try to start the laptop. If the battery is totally down it may cause an issue even though it isn't supposed to. Also, check the voltage at the plug that connects to the laptop. A short at the plug will give you a warm power adapter but no power to the laptop.
Oct 12, 2009 | Lenovo 3000 C200 Notebook
Powering off
Actually, if it is beeping as though the battery is low even while it is plugged in, it is because the battery is no longer any good and is sucking all the power from the wall. You need to purchase a new battery. Until you get a new battery, you can simply remove the battery and use the laptop plugged in. That will stop it from turning off. Been there - done that. Hope that helps! ; )
Nov 05, 2008 | Toshiba Satellite A35-S1592 Notebook
Samsung YP-Z5F MP3 player malfunction
I have that kind of Mp3 Player too... that happened to me, but the PC was able to read mine. However, the reason why the message: "Low Battery USB Disabled" appears, is that you still have remaining battery life, but will only last for less than an hour (indicated by low light and red empty battery sign) you have to make sure the Mp3 is completely discharged. (you'll be notified when you turn on the device while it says: "Low Battery") once that it is completely discharged, you can now plug in the USB cable with the device to the PC... if problem persists, check your PC.. can it read the device? Check if a notification balloon appears at the bottom right corner of the monitor screen. It should say, "Found New Hardware... Samsung YP-Z5F..." if it did not appear, try to INSTALL using the Installation CD given when you bought the product. Just insert the disk into the PC and continue on, then when it is already installed and ready for use, plug in the device! This may be a little hard, but this is the only way I know. Feel free to ask me! I am no technician but I know a lot on devices and fine mechanics. Good luck!
Oct 11, 2008 | Samsung YP-Z5 MP3 Player
No juice
Sounds like a battery issue. Try powering up without the battery, just AC. If it powers properly, then the battery needs replaced. If it doesn't then it may be the power supply malfunctioning, or the motherboard.
Jun 19, 2008 | Acer Aspire 5315 Notebook
Ethernet card problem
I have a Dell Inspiron and when it operates on batteries it automatically (by default) shuts down the wired network adapter when not in use. The solution may be to insure the network cable is plugged in before starting the laptop or to learn where in the power management utilities to turn on the wired network adapter -- I believe it can be done permanently at the cost of reducing battery operating time overall. It can probably also be done on a when needed basis. My Dell currently does not have windows on it and the operation on my machine may not be the same as on a Latitude. When this happened I used to get little balloon notices from a systool bar icon, however I also modified the default configuration to show my network devices in the systool bar when connected as well as when disconnected.
Jan 03, 2008 | Dell Latitude D600 Notebook
Compaq Presario Laptop lost power
the battery charger board, is what I would swap first.
Good luck, keep us posted.
Nov 15, 2007 | Computers & Internet
jasbo
jasbo
