Question about Kohler Home
Toilet Bowl Water Level Slowly Drops
I recently replaced my toilet's fill valve and flapper to resolve some running water/leaking issues - which were fixed.
But now my problem is that as soon as the bowl is finished filling (which seems to be at a normal level initially) - the water level immediately drops about 1-1.5 inches.
Then after letting the toilet sit overnight, the water level drops even more, down to where there is just enough water cover the trap. So the loss of water level seems to be fairly slow after the initial 1-2 inch drop.
Here's the things I've tried from other research without much success:
I don't see any external leaks around the toilet.
I’ve checked that the flapper chain has enough play for the flapper.
I've checked that the fill valve hose is positioned correctly.
I've raised the fill valve floater to as high is it can be while maintaining the water line to where it should be.
I've tried ''slowing'' down the water fill by turning down water pressure. Some say a tank that fills to fast won't allow the bowl to fill to normal capacity.
I've checked the little holes along the toilet rim and they seem to not be clogged/blocked.
I've forced the trap to clear by turning off the water while pouring multiple gallons of water down the toilet which flushes with good amount of force so there doesn't seem to be any clogs there - but not certain.
I have not checked the vent on the roof to see if it blocked which would might cause siphoning in the toilets?
I used the Fluidmaster 400A fill valve kit and flapper and the toilet is a Kohler 1.6 gpf model.
I'm running out of ideas, any suggestions on what else to check or what could be the cause?
Thanks
  • 117 Answers
Check the fill tube in your toilet one easy way to see if it's leaking is get food coloring and pour in your tank to color the water this makes it easier to see and squeeze the tube in the tank when it's full if you see the colored water running down the middle of it you have a winner! if not you can look around for it sometimes the plastic under the flapper gets cracked too
Posted on Aug 01, 2009
Ive replaced 3 toilet fill valve with 440a Fluid master fill valves height is good water level good.After a while it sounds like there is leak by from all toilet.Flappers have been replaced. What coul
check the overflow pipe in the cistern tank as some fill valves do not stop completely but allow input of water after the noise has stopped. This allows the water level to rise up and the water to flow out into the toilet bowl. Reduce the water level height by adjusting the cut off level and when the water rises past the new level the increase pressure on the valve will shut it off.
Sep 16, 2014 | Fluidmaster 400A Toilet Tank Repair Fill...
I can see water trickeling on the bottom of the overflow tube. Already replaced gasket and removed the fill tube. Very slow, about every 20 min. the fill valve kicks on for about 5 sec.
The problem is your flapper. It is leaking water into the bowl, causing the valve to kick in as the water level slowly drops in the tank. It will also solve most condensation issues as well.
Aug 23, 2011 | Kohler Persuade Two-Piece Elongated Toilet...
Korky anti-siphon. Tank water slowly drops, accompanied by a hissing sound. Then, after dropping about 1/2 inch, it refills. Wha?
either the fill valve is running and water is draining into the bowl via the overflow tube in the tank or the flapper is bad (or foreign matter) and it is allowing water to escape into the bowl slowly...causing the fill valve to run every few minutes or so. hope this helps but if you need anything else just text me here:)
Jul 29, 2011 | Lavelle Industries Korky& Universal Toilet...
I have a new American Standard Cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl slowly drains away and is nearly gone....
Sorry for problem with new toilet.
You say water is leaking out of the bowl?
Toilets have 2 parts:
1) Tank: where water is stored for the flush and is sealed with a flapper.
2) Bowl: where water flushes down.
a) If tank is leaking water, then flapper is suspect. Replace flapper and see if that works.
Lift up flapper and run finger around rim to see if there is a rough spot that would indicate flush valve is defective, and needs replacement.
See typical flush valve
b) If bowl is leaking, that is very unusual and would indicate a crack in the porcelain.
If installer sold you the toilet, it is his responsibility to make good on product.
All products are guarantee against workmanship flaws.
Feb 26, 2011 | American Standard Cadet 3 Right Height...
Toilet tank looses water over time
As long as there is no water leaking from the tank to bowl connection, you are OK. You would know if it was leaking here, because you would have water dripping out onto the floor.
Verify that the water level in your tank is below the top of your new flush valve's overflow tube. If the water level comes to the top, it will overflow into the toilet bowl. This can be easily fixed with an adjustment to the fill valve.
If the water is not overflowing into this tube, then the only way you can lose water is through the flapper. You said you changed the flush valve, which would have come with a new flapper attached to it, but maybe buy a new flapper and see what happens???
Jan 19, 2010 | Eljer Aqua-Saver 12" Two-Piece...
Tank not holding fill level...
Most likely, you do not have a good seal on the flapper valve at the bottom of the tank. To confirm, try this:
Turn off water and flush toilet. Then lift up the flapper valve and put a light coating of vaseline on the mating surface where it contacts the toilet tank when closed.
Turn water back on and see if it continues misbehaving. If that fixes it, it was a bad seal. Usually that is all it takes.
Dec 15, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Replaced toilet fill valve - now bowl water level a bit lower
First off,If the air vent was clogged the toilet would back up and overflow and when it did flush, it would make a gurgling sound.
secondly the water level in the bowl is not important as long as it covers the opening,The water is only there to keep out sewer gases so they don't enter your home and the shape of the trap will always maintain the proper amount of water needed to prevent this.
The previous water level may have been due to a partial clog that has since been removed.
Jul 26, 2009 | Home
Toilet makes noise as though it has been running and quickly tops up the tank. I cannot take the top off to see what is going on because of the dual flow system.
The flapper is leaking and needs to be replaced. Different toilets have different style flappers, but they all forma seal from the tank to the bowl at the flush valve. When the flapper is lifted, the water rushes into the toilet bowl.
When they develop leaks, the tank slowly drains, (often unoticable) and eventually the fill valve senses the tank is not completely full and "tops off" the tank.
Buy the best quality flapper available, as the cheap low quality ones often leak right out of the package.
Jul 03, 2009 | Home
Water continues to drip from fill tube after the fill.
Chances are the flapper is leaking. Thats causing the random refilling as the tank slowly loses water into the bowl.
Replace the flapper with only the best available at your supply house. the cheap ones tend to leak even when new. The good ones are less than 8 bucks most places.
If your fill valve has the float ball, there should be a screw right on top of the fill valve at the end of the rod holding the ball to adjust the water level.
Closckwise lowers the level.
Be carefull not to break the plastic ones. If the adjustment is all the way in or does not work, you will need to replace the fill valve.
You could also try bending the metal rod holding the ball, but only as a last resort.
Nov 25, 2008 | Home
Home Logo
1,341 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
