Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-52525 tv goes on but with a honeycomb like picture
  • 934 Answers
By "honeycomb" do you mean it looks something like 96 colums with horizontal lines running across them, left to right, alternating in intensity from top to bottom and side to side?? If so that's a common failure of the FMT board Mitsubishi p/n# 930b924002 and a spendy little board it is... Average cost approximately $425.00 dollars plus shipping...
Another alternative is to have it rebuilt at PTS Electronics for about $350.00 dollars plus shipping.
Any qualified shop might use one of these alternatives or bench repair it instead. A lot would depend on the findings of their tests.
Good Luck!
And please don't kill the messenger...
Posted on Nov 25, 2007
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 picture problem
you didnt mention which two boards you replaced the caps on however each board in the chassis has the same capacitor issue. Sounds like you need either of the four V26 Repair kits. The FMT repair kit, The signal Repair kit, The Terminal 1 or the terminal 2 repair kit
Jun 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525
Normal 0 The Mitsubishi WD-52525 has a serious capacitor problem as discussed in this forum overseen by a Mitsubishi certified repair technician: There has been a worldwide problem in computers and TVs over thepast several years with faulty electrolytic capacitors (from Taiwan) thatdecay, dry out, swell and die. The power supply is often the firstcomponent to go bad, but other systems also degrade over time. As theforum explains , this problem is widespread in these sets causing multipletypes of display problems after several years of use. On my set, I also got a blue screen with a lighter blue ball in the middle. Mitsubishi is awareof the problem and will cover most of the cost of repairing the chassis, evenyears out of warranty, but apparently ONLY if you get an estimate from aMitsubishi certified repair station and contact their customer support BEFOREdoing any work on the set. I just followed the recommended procedure onthat forum and Mitsubishi is covering half the cost of my $700+ repair when my3+ year-old set recently died and showed only this blue screen on all inputs.
Mar 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi Wd-57733 TV 57"
lamp is out call mits and order a new one do not use any other lamp but OEM
Apr 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wd 62525 honeycomb pictues
The DM board wont cause that symptom. The DM only directs power that is recieved from the PWB to the ballast fans and etc. That sounds like a problem with the FMT. capacitors 1000uf @16volts numbers C8F21, C8F22, C8F19, and C8F27. those will cause distortions in the video on the V26 chassis. Let me know if you need more info
Mar 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525-Code 34-Sound OK-No picture!
I had another problem kinda the same and emailed and they gave the fix.
Nov 02, 2007 | Mitsubishi WD-52525 52" Rear Projection...
No picture
When I first turn the tv on the picture comes on for a few seconds then the screen goes to green but I still have perfect sound
Oct 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 too much green and picture is not clear...what can i do to fix it
. Suspect the FMT PCB part # 930B924002. Supect the DM PCB part # 934C116002 if green tint
Aug 04, 2007 | Mitsubishi WD-52525 52" Rear Projection...
42" Mitsubishi 52525
You may have bad capacitors in the DM board.
Mar 05, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
