Question about Garden
Need exploded view/parts list for string feeder head on Stihl FSE 60 electric lawn trimmer. I think the ''bump'' feeder head has a spring missing, and can't find an Exploded view to check on which part(s) may be missing. Any ideas? Thanks, ~Bill~
    Novelist:
  • 133 Answers
Check of www.stihlusa.com they have downloadable manuals.
roundo4
Posted on Aug 02, 2009
What is the proper configuration of the ryobi p2200 string trimmer head assembly?
Ryobi P2200 18 Volt Hybird String Trimmer Parts
Find Part By Symptom on right side
Select "Trimmer line feeds too much / continuous"
Will show you list of parts to hopefully fix you problem
Jul 22, 2017 | Ryobi Garden
WHAT SIZE TRIMMER LINE FOR STIHL FSE 60
You should use .95 diameter line or larger but it is not critical.
Aug 07, 2014 | Stihl Fse 60 Electric String Trimmer
Where can I get a parts breakdown ( exploded view ) for a Ryobi 775R 16" string trimmer.
here's the link. http://www.partstree.com/parts/?lc=mtd&mn=775r+41AD775A034
Mar 17, 2013 | Garden
Need to view schematic for Stihl FS130 String Trimmer
there isn't really any schematic we can give for a list of part numbers but any dealer anywhere should be able to find what you need. Just give them a call and tell them what you have and what you are looking for
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Mar 08, 2013 | Garden
Missing the user's manual for Homelite ut20635r trimmer sold by sears
within the bump head (once opened) you will see add arrows, this indicates which direction you add the line, usually opposite to each other, you will have line hold points (4) within the cup. once you have fulled the cup head with line (octupus needed), thread each line through feeder holes and push line into housing making sure you pull line out through the feeder at same time as pushing into head. pold the hell out of everthing or it will go haywire. Vrey difficult, but after about 300 tries at it, you will still go to the dealer to do it. If you can make any heads or tales of my solution..good luck but its how you do it. Regards Russ
Jul 03, 2012 | Homelite Mighty Lite Lawn Trimmer
Need new bump head or full bump and feed unit
You can find some string heads and string head parts for your machine at Home Depot. They have a universal type head and heads made especially for Ryobis and Homelites (I think). Otherwise, several online vendors sell parts for your machine (but you have to pay shipping).
Jul 23, 2011 | Homelite Mighty Lite Lawn Trimmer
How do I replace the nylon cord on the Stihl FSE 60 - manuel does not give instructions.
Howdy, depending on which head you have, there are different loading options. Here is a diagram of the types of head you might have on your FSE 60: <br /><br />http://www.stihlusa.com/trimmers/blades.html <br /><br /> (just copy this into your browser's address window and hit return to go to site)<br /><br />You might really like the prefilled spools as they are the easiest to use, but the head that just takes 2 pencil lengths jammed in holes is nice for more rugged cutting jobs, and is still pretty easy to refill.<br />Hope this helps some:)<br /><br />
Aug 25, 2010 | Garden
Too Much String from my Troy Bilt
The majority of the time excessive string feed is caused by one or a combination of one or more of the following:
String wound backwards. Seems simple enough, but happens to the best of us.
Missing or improper spring.
Lubrication ANYWHERE on the shaft or inside the bump head assembly. This item should be clean and dry..but never lubricated.
If you know the model number on your particular trimmer, that would assist in troubleshooting.
I hope this helps.
DROPNDEAL
Jul 12, 2009 | Troy Bilt Tb70ss Gas Trimmer
Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
May 16, 2009 | Homelite Mighty Lite Lawn Trimmer
The trimmer head on my Black and Decker cordless trimmer/edger seems to fall a few mm and the won't spin unless I push it back up the shaft. This is the second time I've had this happen in a unit after...
You probably have lost your return spring which will hold the head tight to the trimmer.Check to see if you have lost the spring. I would suggest looking on-line for a exploded view with parts list to see if you have any parts missing including the spring I mentioned first!
Aug 06, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
732 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
