SOURCE: Unable to get head of whipper snipper
After much mucking around I noticed a hole in the top shroud of the shaft. I placed a narrow screw driver through the hole until it made contact with the rotating part of the head and pushed until the head would not turn. I thern applied pressure clockwise until the head became loose. I did the reverse to tighten. The head of the unit will rotate anti clockwise to tighten as the shaft rotates clockwise during operation. I hope this explains the method.
Thank you any way for your interest.
Greg
SOURCE: my fs 45 whipper snipper is starting but running
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
SOURCE: homelite whipper snipper is hard to start and its
I took mine back to Bunnings and the guy there said they had a number with this problem and have found that priming the bulb 20 times not 10 as per the manual, is the fix.
It certainly fixed mine
Testimonial: "Thanks, will try it!!!"
SOURCE: i have a petrol black
50:1
Farmerbear
Testimonial: "Thanks for the info. I've been trying to get the right mix for ages."
SOURCE: stihl whipper snipper wont start..
I have a Sthil and the wiper snipper it starts but when I increase the power it seen to either stall or flood plesae help
