Computer motherboard is ESC PT800CE-A when i turn on no power in the mother board what is the problem and causes
  • daburks Dec 07, 2007
    I have a Sony PCV-RS411 with no power. I replaced the power supply with one purchased from Sony with same results. Suggestions?
    Problem Solver:
  • 5 Answers
Thank you for your time.
I have a Sony Desktop VGC-RB42G. When I connect the power cord the GREED ligth on the power supply blinks fast, also there is a green LED on the MotherBoard wich also blinks fast.
Computer will not turn on!
Please help.
Thank you.
Posted on Oct 21, 2008
  • 57 Answers
Try to replace your power supply.
Posted on Nov 25, 2007
My unit won't power up - power supply is good and not sure about the on switch any help would be appreciated -- motherboard is in an old HP Pavlion 700 case
Remove the little watch type battery from the mother board check the voltage with a meter should be about 3.5 volts. Then replace the battery on the mother board. This battery holds memory within the Bio chips on the mother board, if there was a problem that it sensed for turn on it will be in the Bio's memory, and maybe not allowing the computer to turn on, by removing the battery for a few minutes, the Bio's forget they had a problem, if you will. and the computer might turn on.
If you have all the voltages to the mother board from the power supply, it should turn on.
unless there is some reset circuit interfearing with it turning on. Or you might have a blown fuse on the mother board, I would check everything I could, and try everything I could, and if you still cannot get it to turn on take it to a computer shop and spend a few bucks for them to fix it.
Nov 11, 2010 | Mach Speed Matrix P4MSD-800 (P4MSD-800 D2)...
depends on the case that it is in. for the physical size. but normally any ATX power supply of 350watts or better is a good selection.
i need a picture of the case to be sure
Aug 12, 2010 | EliteGroup ECS PT800CE-A...
Mother got jumper problem
sounds like a failty north chip not much to do about it somtimes the chip can cost more than the board mybe time for a new mother board used 10 pound from ebay new on ebay 30 to 40 pounds
Mar 15, 2010 | Intel Motherboard
Dear sir, my computer asus sis961 is not working, power is not showing in mother board, technician is telling in mother board short sirkit
Do u know how to assemble a pc
if yes take the mother baord out of cabinet . place the mother bord on an insulating surface with proceesor . then connect smps ... poweron the board by shortin the frnt panel connectors . connect all peripehrals like monitor , kb and mouse etc ..... if this seems to be working try to insulate the cabin whre mother board is fixed ................ SMPS can also cause no power try chekin with another smps too
Aug 05, 2009 | ASUS P4SE Motherboard
Will not boot
You can goto BIOS setup be pressing DEL, ESC, or one of the "F" [function} keys just before " memory count " finishes.To see what is turn 'on' or 'off' look through the menus & submenus.look for video [ ON if you have 'on board' video and off if you have a EXTERNAL video card.]
temperaty take EVERYTHING out by unpluging the wires going to computer (mother board) [cd's, h/d, floppy drive, and any other extras] You can keep them 'dangling' from e.i. floppy, cds [rom,ram,dvd etc.] keep the memory, display adapter (if you have a EXTERNAL video card) and boot up the computer.You must see the memory "count up" in DOS (black screen with numbers running on left side of screen) .At first if the machine does not turn on, replace the video card.Then after UNPLUGING a/c power put back ONE piece of equipment at a time (of cause you will replug a/c power)and rebooting.
Dec 13, 2008 | Computers & Internet
The power led and reset was both on
We have to open the system unit where the motherboard is located, but first pull off the power of your computer so that there will be no ground.
Removed the cover, before touching any part inside the system unit (motherboard) touch first the casing or chas-is of the system unit to removed the static in our body.
Let us first remove the reset wire usually the color is red and black it has a name reset at the connection pin at the mother board usually found at the bottom of the mother board, or follow the reset botton wire found infront of your system unit.
After you have removed, try to plug the power of your computer and turn it on. We can open our computer if the reset connection is off.
That will be the first step to know the cause of the problem. Try also to clean the motherboard using vacuum cleaner the portable only or clean paint brush, cause some of those problem due to dust.
Oct 18, 2008 | ASUS P5P800S Motherboard
PT800CE-A building
Hi jeff, here is the list of CPU's that the ECS PT800CE-A motherboard supports. Click on this link:
Main ECS web page:
The last CPU on the bottom of the list is the Celeron 2.5GHz.
Good Luck!
Jun 09, 2008 | EliteGroup PT800CE-A Motherboard
Computers & Internet Logo
863 people viewed this question
David Payne
David Payne
