Question about Frigidaire GLTF2940ES Front Load Washer
Recently replaced the electrical control for my Frigidaire GLTF2940ES Front Load Washer. Now the settings dial is not properly aligned; that is, the selection on the knob does not correspond to the wash program that is running. How can I synchronize them again?
    President:
  • 1,714 Answers
The dial knob itself has slipped on the shaft. You need to remove knob from timer switch shaft and realign it. to current running cycle.
Posted on Aug 01, 2009
Why want the water wont come into machine
Hi friend, thank you for your inquiry!
I understand that water will not come into your Frigidaire washer, GLTF2940ES, and you have recently changed your door lock. It could be a possible issue within your water inlet valve, switch, or control. Since it could be any one of these underlying issues I would recommend having a professional come out to properly diagnose and repair the appliance to avoid any unnecessary part purchases. Best of luck. -Matt
Aug 18, 2014 | Frigidaire GLTF2940ES Front Load Washer
Filter replacement for frigidaire gltf2940es
Hello - The error code "E20" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Nov 05, 2012 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Front load washer with ''ddo'' code
The DDO trouble code means that the detergent(D) dispenser(D) door is not closed properly((O)open).
The door uses a reed switch and a magnet to send the door closed signal to the control card.If the
magnet becomes dislodged you will get this code.You will need to have the magnet replaced in
its proper position to clear this code.
Apr 05, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Isn't Filling Properly.
How old is this washer? You maybe looking at a defective fill valve (where the hoses on the back connect to), or an obstruction in the pressure hose that leads from the Load Size selector to the fill valve. Also, unplug the unit and check the electric connections on the valve as well as the Load Size selector.
Dec 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
Front load washer
check holes under cover for obstruction in dispenser drawer. then check valve operation. there is a handy diagnostic for this. find techsheet on wall on lower left side. set dial to touch up, make sure all leds are off, then press/hold pause/cancel and options within 5 secs of turning off. refer to tech sheet for dial functions, each dial positon back turns on different function.
Apr 23, 2008 | Frigidaire GLTF2940ES Front Load Washer
Dial won't turn to delicate or handwash...
Is it brand new?? if it is the factory did not align the knob (dial assy) properly with the main computer, and on top of that all the cycles you think you are selecting really isnt that cycle at all!! It is two back from full left or right whichever way is not fully extending. It is quite frustrating for me to get it back right when i replace the main computer! The first one or two took me a while to get it right again. PLEASE rate my solution as solved if you feel I answered your question accurately. Thank you
Oct 02, 2007 | Frigidaire GLTF2940ES Front Load Washer
LOC ERR
The control panel may in *LOCKED* mode. Press the *OPTIONS* and *SELECT* buttons at the same time and hold for about three seconds to unlock the control panel. Make sure the detergent tray is fully closed too.
Feb 23, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
140 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
