Question about Janome Memory Craft 9000 Computerized Sewing Machine
Customiser 2000 will not connect to a laptop as it has a 9 pin serial port (female) and the laptops have a 15 pin (female) I have bought 2 different cables but none work it just says serial port did not open. So I can't transfer any designs to card for my memorycraft 9000. Janome UK said they could not help and were not interested, I asked them if they sold a new cable for the reader with a usb cable on the end rather than the serial port. I am getting rather desperate as my old computer that I used to use for the reader / writer with the old style ports has packed up and the new desktop computers don't have the 9 pin serial port either. Margaret in UK
  • sapphire_dia Aug 02, 2009
    Hiya Sew Creative
    I did this last night and also downloaded the Customiser 2000 upgrade from Janome which increases the ports from 4 to 16. My laptop shows that the port it is using for the customiser is 22 it has something to do with the conversion cable although on a hardware check this is working fine. The customiser is also working ok as I tried it on the old desktop pc today but we are getting rid of that as we are having a smaller desktop and none of them have the 9 pin connections it all seems to be 15 now.
    If I cannot get this sorted it means I am going to have to store rather a large tower pc somewhere to make appearances when I need to do embroidery designs :( I have had my 9000 around 6 years and have hardly used it I have most of the accessories and cards for it and also loads of design cd's and don't want to change it. I have also just bought a Janome 9200D overlocker to compliment it as I got rid of my industrial overlocker when I moved.
All I had to do when I got my customizer was purchase a Serial to USB adapter cable. (Radio Shack carries them but you have to either order them online or go to one of the bigger stores) I installed the cable, then connected the customizer to it. Make sure you download the upgrade for customizer so it will work with XP if that's what you are running. Then you go into your settings or communications menu and pick the one that works. Sometimes you have to do it a couple times til you find the right one. My worked this was for many, many years until the whole thing bit the dust last August. I don't know if it's a hardware, software, or ownerware issue and neither does Janome or anyone else. I ended up having to by a new machine for embroidery. Good luck, I hope I helped some.
Posted on Sep 06, 2009
  • 3 Answers
I have the same problem as sapphire. I don't have a 9 pin serial port on my laptop so I bought a 9 pin cable that converts to usb off ebay and the disk that has the drivers on it won't work, so I downloaded drivers from dell and now it says the cable works and I have it set to com 4 but when you are in easy edit customizer 2000 and try to import anything off the reader/writer you can't find it as the laptop won't recognize it. HELP!!
Posted on Aug 26, 2009
    Problem Solver:
  • 15 Answers
Are you using a USB-to-serial adapter?
I *think* what the problem might be is that the COM port's not been set in Customizer. Within either of the Easy/Customizer apps, go to ScanCard>Communication Settings ... you'll open up a dialog box within which you can set which COM port your cable's going to use.
If you're compie savvy, you can go to the Windows Start button on Task bar>Control Panel>System>Device Manager>COM ports and SEE which COM port your cable's using.
But until your software knows what COM port your cable's using it will NOT recognize that you have one installed.
Please let me know if this doesn't help! Or if there's anything I can help with!! :)
Posted on Aug 01, 2009
  • SewCreative
    SewCreative Aug 08, 2009
    Okay, let's try this.
    Go back to the Device Manager, go to the Adapter and right click on it. That should bring up the contextual menu ~ choose "Properties."
    Within the Properties dialog box, click on the "Port Settings" tab and you should see an option to manually assign the Adapter the COM port of **YOUR** choosing.
    Personally, I'd set that for COM Port 4. But that's my preference (mainly because it seems to be what Customizer "wants").
    If that doesn't work, holler at me again. We WILL get this figured out!!!
Can't get null modem usb to 9 pin cable to transmit designs to machine.
First, to transmit to your machine using a USB to serial converter, it should have a FTDI chip. Second, you should be transmitting on Com 1 or 2 -- preferably Com1. You can change the port it transmits on in the Device Manager in computer properties on your computer. Third, check on your machine which port it's looking for -- they must match.
Sep 29, 2015 | Singer Quantum XL-5000 Computerized Sewing...
How do I connect a 180e serial cable to my usb computer when Artlink and CPS software specify serial port?
I've not successfully managed this ... trouble-is that although you can get USB-to-serial converters, most computers that only have USB ports do not properly 'recognise' COM ports, which is what your Artlink software expects to talk to. I still use an old PC with a 'proper' 9-pin serial port on the back in order to talk to the old Artista range of machines. One of the drawbacks of a 'throwaway' PC industry that expects the rest of the world to continually update everything in response to new interface standards!
Oct 08, 2011 | Bernina Artista 180
I was just given a 180e embroidery machine ( I am a total novice) and I am not sure how to connect the dongle and get designs that are in my computer. Thank you so much cat
I am not exactly sure of this particular model. But the dongle should just plug into the computers port on the back of the computer.
Jan 19, 2011 | Bernina Artista 180
Trying to connect a USB to the serial port of a Bernina Sewing Machine (Bernina 170). Has been working for a couple of years and has stopped all of a sudden. Does not work on and XP PC, Vista or win 7....
The Dynex adapter does not have any numbers on it. It was the one that is only about a foot in length and has a square center piece that houses the conversion electronics. Standard 9 pin RS-232 male plug on one end and the standard USB plug on the other end. I purchased it within the last month at BestBuy here in Austin TX.
Oct 28, 2010 | Bernina Artista 170
My Janome customizer 2000 will not write to the scan card. It says that it will not recognize the serial port.
Hi, I have the same problem with mine. Janome have not been very helpful. I didn't know if it was the card or the card reader/writer. I have a Janome CX500. Have you solved any of the problems?
Louise
May 14, 2010 | Janome Memory Craft 9000 Computerized...
I need to hook up my bernina 180e sewing machine to my new laptop with windows 7. There is no connection port to plug in my dongle. Does anyone have any ideas on how I can make this system work?
I am assuming that you are talking about the cable from the sewing machine to the computer...
Here is the disappointing answer. You cannot hook the 180e up to a Windows System 7 computer or Vista. I have an older computer with XP on it just for my sewing machine. If you want to hook up the sewing machine to a computer that does not have a 9-pin, you will need to buy an adapter that goes from 9-pin to USB. I bought one from Belkin, and you may need to buy it online. It costs about $30.
I have the embroidary software version 4 that has a dongle. It will also not work on Vista or System 7 and the Bernina dealer says I can upgrade for $400.
Jan 02, 2010 | Bernina Artista 180
To hook up my laptop computer to my bernina, I need to use a USB to serial 9pin cable but it 'talk' to the sewing machine. I used a 9pin 9pin cable to hook up from my old desk top PC. What am I doing...
You need to get an adapter to convert the 9-pin to a USB port. I have one from Belkin. Once you get that set up, you will need to check the com port for the driver and make sure it is 1, 2, 3, or 4. If you have Vista or Windows 7, your softwware will not work. My dealer wants $400 to upgrade. I kept my old computer just for my sewing machine.
Mary
Dec 08, 2009 | Bernina Artista 180
Cable
i use a prolific PL2303 usb to serial adapter for my bernina 165 i got mine from frys but I'm sure you can find them online too
Mar 28, 2009 | Bernina Artista 180
Pfaff 7570 connection to new XP laptop
In this FAQ list (from PFAFF web) you find 100 times the same question and answer:
H402 My new computer does not have any serial COM ports, so how does it communicate with my Pfaff creative 7570?
You will need to obtain a USB Serial Adapter, which adds a serial port to your computer by plugging it into a USB port. Suitable adapters can be obtained from Belkin [http://www.belkin.com] and Keyspan [http://www.keyspan.com].
The following USB Serial Adapters are known to work with the Pfaff creative 7570:
• Belkin F5U103
• Keyspan USA-19QW
Please note that the Belkin F5U109 is listed as working with the Pfaff creative 2140/2144 (FAQ #H405), but it does not work the Pfaff creative 7570.
Jan 06, 2009 | PfaFF Creative 7570
Can't connect my Bernina 170 Embroidery unit to my computer
I just bought a new laptop and upgraded to V.6. Since I have always used a magic box I didn't know how to attach my bernina 170 directly to the laptop. My bernina dealer said that I would first need a serial to usb adapter since my machine is old enough that it doesn't have a usb port on it. Make sure it doesn't have the screws on the serial part because they will not allow you to attach it to the machine. He also said that I may have to make a new com port as most pc laptops only show 4. I did a search of the computer and found how to make a new com port. A little more fiddleing around with the laptop and cables and restarting both then it somehow recognized that I had made a new com port. Voila. It now works. (I am a Mac person). Hope this helps. margaret
Jan 04, 2008 | Bernina Artista 170
Janome Memory Craft 9000 Computerized Sewing Machine Logo
438 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
