KP-53HS10 TV has the stand-by LED blinking and can't turn TV on or off, no video or display
  • 3 more comments
  • scpeck4 Aug 01, 2009
    the blinking is constant, there is no set number of blinks.
  • scpeck4 Aug 02, 2009
    The standby blinking is constant there is no pause to determine the number of blink after each pause. I'm aware that the blink counts determine the error code but with constant blinking and no pause, its difficult to determine the number of blinks between pauses.
    Would this board be also know as the HV flyback or D board? The replacement flyback is manufactured by ASTI magnetics as P# AI-2305 and sells for 18 to 30 dollars. I just wanted to verify if this was the same thing?
    Power supply board can be order under following part number..
    A-1316-513-A G BOARD - who manufactures this board and where can I buy it at what cost?
  • scpeck4 Aug 03, 2009
    No, thats not the solution. The TV doesnt turn on at all there is only a standby light blinking which means there is an internal problem and its likley the power supply or the G board.
  • 4,472 Answers
First off how long have you owned the unit, and secondly does it blink for a certain number of times? If so can you count them, if there are pauses count then count again after the pause. Thank you. This will give you a general idea of what is wrong. It is definitely be an internal problem. So you should prepare yourself for considering repair or replacement options. I can gladly give you the sony repair information the link is here:
http://eservice.sony.com/webrma/web/index.do?SR=nav:service_support:electronics:repair:esup&ref=http%3A//www.sony.com/index.php
Once I have more information I can continue to assist you further.
Thank you,
Lee
Posted on Aug 03, 2009
    President:
  • 563 Answers
The first thing to check is the lamp. When the lamp on a projection TV goes out, you will get any display whatsoever. Even if you have a lamp light and it isn't blinking, it could still be the lamp. I hope the TV is under warranty or isn't far out of warranty because it sounds like a definite repair issue. It is very doubtful that you'll be able to solve the problem with any type of troubleshooting in the home. If you're under warranty, any repair other than the lamp will be covered. Some manufacturers don't cover lamps under warranty, but I believe Sony will as long as you purchased the TV within the last year. If you have an extended warranty and you need a new lamp, you'll likely be paying out of pocket for it. However, if you need a circuit board or a part to repair one of your circuit boards, that would be covered. If you're not in warranty or you need to replace a lamp, the cost will be a minimum of $200, but could be much higher depending on the part needed to complete the repair.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Posted on Aug 02, 2009
  • 10,594 Answers
Let me know how many times standby light is blinking in KP-53HS10
There would be interval of 3 seconds between blinks.
Thanks.
Posted on Aug 01, 2009
  • 2 more comments
  • Shahid Electronics
    Shahid Electronics Aug 01, 2009
    Please check again, manual says standby light can blink 2 to 8 times with 3 seconds interval as error code.
    standby light blink count will tell me the problem section in TV
    Shahid Electronics Aug 02, 2009
    OK, then check power supply board, it calls G board and located at left side in TV if you look from back of TV.
    AC cord will take you to power supply board that seems bad and does not provide proper volts so TV system can boot up.
    A-1316-513-A G BOARD, COMPLETE
    Thanks.
    Shahid Electronics Aug 03, 2009
    Though my assistance got rejected yet I would say check G board that is available in Part Store.
    Make sure G board is bad before ordering it by testing its output volt supplies, that requires fair knowledge of electronics, experience of TV repair and repair / service manual in hand.
    Good luck.
    Shahid Electronics Aug 08, 2009
    A-1316-513-A G BOARD seems problem in your TV and it is available in Part Store.
It just keeps blinking in stand by and it wont stop kp53hs10 sony 53 inch tv
I have the same problem- please help- no power- just continuous blinking- tv 10 tears old
May 24, 2011 | Sony KP-53HS10 TV
My Sony tv screen blinks off and on and timer/standby blinks 5
Yes....this blinking code is a diagnostic fault code which is a good thing, you count the number of blinks and it tells you where the problem is.....you also can see it by pressing the buttons, DISPLAY,CHANNEL,5,volume - not + ,then power....In your case it blinks 5 times,its in the video out,you need a desoldering iron,solder,rosin core 60%tin and 40%lead...remove and replace these,Q761,Q705,Q732 on the C board also Q218,Q219,Q220 on the A board.hope this helps.......
Feb 26, 2010 | Sony KP-53HS10 TV
KP-53HS10 blinking light
Ok I solved my own problem and posted the results here,
http://www.fixya.com/support/t1692655-sony_kp_53hs10
Mike
Dec 13, 2008 | Sony KP-53HS10 TV
Repair inquiry
     According to the LED BLINKING there must be some problem that are given below:
Diagnosis item:  Video out abnormality detection
TIMER/STANDBY
Indicater
Number of blinks:
5 times
Supposed malfunction:  Video out, IC7101, 7201, 7301 and others in C board circuit.
Q510,516,524 (A board)
Condition:TIMER/STANDBY LED blinks approx. 30 seconds,
and then blinks for the self diagnosis.
Self-diagnosis
screen display,
Diagnosis item: Results:   5 : AKB 000
So, This was the result of 5 times led blinking.I would suggest you to please contact any expert or strongly recommend to contact any SONY SERVICE CENTRE for repair because it's not an easy job to rectify this problem. Hope you better understand my sayings.
Thank you for using fixya.
Nov 29, 2008 | Sony KP-53HS10 TV
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-53HS10
five times indicate white balance failure and video problem one of the picture tubes may be giving that problem
Mar 31, 2008 | Sony KP-53HS10 TV
No video - Blinking code 5
yes im a tech unknown business i cant say what business or my name could lose my job but her you go, Fix the blinking light code 5 blinks turn down your picture vivid and your contrast ive makde plent of money fixing this issue for the company.
Feb 01, 2008 | Sony KP-53HS10 TV
KP-53HS10 has a blinking red light on
Try getting a new power supply. Replacement SOny flyback 859882800. That part costs $18 and would be the most inexpensive solution. Unfortunately your probably gonna have to do it yourself unless you want to pay huge handling/service fees. Just google the part number and it should come up. Part# : 8-598-828-00
SONY FLYBACK 8-598-828-00
Dec 19, 2007 | Sony KP-53HS10 TV
Sony kp-53hs10
does the timer light blink? how many times pause then blink again?
Dec 07, 2007 | Sony KP-53HS10 TV
Sony KP-53HS10
I've had my T.V for about 5 years, and the other day the screen just died and I have no audio, but the when I plug it in the red light in the front flashes, have any idea on what to do.
Nov 21, 2007 | Sony KP-53HS10 TV
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
Electro Med Services...
