Question about Ryobi Garden
RYOBI weed eater.hard to start. starts then stops
I have replaced the fuel lines cleaned the carb.and filter and air cleaner and it still won't keep running. if i keep pumoing the primer it will run. it just won'tkeep running . IT IS A RYOBI 31cc WEEDEATER
I have a ryobi doule line bought in 1997..Had same problem put new gas cap on and problem solved..could not get air in....
Posted on Aug 02, 2009
I have a psa 225 echo weed eater. The engine readily starts but will only rev up using the choke lever back and forth. No power. What's my problem?
Carb or filter
. replace fuel filter in tank while checking both pickup and return fuel lines.
remove carb and disassemble cleaning all parts with carb cleaner and some soft air blow . look for small screen its round and about 1/4 round in carb these are so small that the gas that's available gells and plugs the openings . try to use non-ethonal high octane gas and use echo 2cycle oil .
Jan 26, 2017 | Echo Garden
I have a Ryobi weed eater. It's sat up for about 3 years.I'm trying to get it running again. I can get it started but it dies every time and I've got fresh fuel and cleaned the carburetor what do I do
well if it starts but soon dies then you can be sure its not an ignition problem, your problem is gas flow , ck the filter inside the tank , blow air thru it to see its clogged , also if it sat 4 that long ck hoses , I bet they dried up and cracked , this allows air instead of gas in carb
how did u "clean" the carb these things are tiny inside and have lots of little passages that can get stopped up , just a spray or two of carb cleaner is not gonna do it .
Apr 16, 2015 | Ryobi Garden
Why won't my McColluch weed eater create a vacuum
Did you check the muffler exhaust or spark arrester, to see if it is clogged from using to rich a oil/gas mixture ? Did you replace the diaphragm in correct position ? Find a new carb online, possibly ebay ?
May 16, 2014 | McCulloch 5pcs General Snap-In Primer Bulb...
Weed eater shut down once I began to trim
Youwill need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to seedaylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jul 01, 2009 | Ryobi Garden
My ryobi weed eater starts great but when I put the button in the run potions it dies. Please help
First, check the fuel lines for cracks/breaks.
If they are o.k., then you will need to disassemble the carburetor and spray with carb. cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit abd replace all appropriate parts.)
Jim
Jun 12, 2009 | Ryobi Garden
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
Ryobi weed trimmer
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. also check the primer bulb for pin holes and proper seating/seal. i
Jul 06, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
2,815 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
