To Remove Moen Kitchen Faucet.
Regardless of the type of faucet being installed, there are a few basics steps everyone will follow.
First, shut off the water supply to the old faucet using valves typically located under the sink. Then remove those supply lines and the old faucet.
Before installing the new faucet, check the area around the sink and clean up any gunk or old caulk that you couldn't see before, Simons says.
SOURCE: dripping faucet
Moen is a cartridge style unit. They make two different cartridges that you can buy at Home Depot. Turn the water off under the sink and then remove the handle. You will see the the cartridge. It has a U shaped retaining clip that pulls out. Once you remove it, then take a pair of pliers and pull the cartridge out. Take it up to HD and match the one you have. The new one will slide right back in and you will reverse the process.
SOURCE: Own a Moen 87888 kitchen faucet. The handle has
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
Thanks and Please Rate jj505
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
SOURCE: handle on moen kitchen faucet is loose after
SOURCE: Moen kitchen faucet model 7430 leak
cartridge does not stop that type of leak. If it is leaking from around the base of the spout it is o-rings that are the problem that are onthe valve after you pull the spout all the way off.
SOURCE: How do I remove the aerator on a moen pull out
It should just unscrew. You might need some needle nose pliers as the aerator may be slightly recessed.
