I have a problem with my hp officejet 6100 all in one printer. I replaced the color ink cartridges and the message I receive is "scanner has failed, please turn off the printer and then turn on again." I have tried that numerous times,however,it does not work.
  • 724 Answers
Try the self test
try the software scan save to memory
Posted on Aug 01, 2009
I bought all new cartridges, inserted them the way they were removed, but message board still says defected cartridges. how to install ink properly and make error message disappear?
Here is a video from HP explaining the process. IF you followed this procedure and are getting errors, then you may have bigger issues. I am assuming you are using genuine HP ink, not remanufactured or refilled cartridges.
Replacing Cartridges for HP Officejet Pro 8600 All in One Printer Series...
Aug 31, 2016 | HP Officejet Pro 8600 Plus e-All-in-One -...
Problem with printer or ink system
PDF]HP Officejet Pro X476 and X576 MFP Series ... - Parts Now
www.partsnow.com/.../Officejet%20Pro%20X476%20X5...
Parts Now LLCFigure 2-6 Printer status report-determining genuine HP ink usage . ..... Thesecartridges are linked by flow connections to the rest of the printbar and supply the ink..... The left door can be opened for jam clearance and has a hall effect .... The document feeder will not function when the document feeder cover is open.
db:: 4.32::Printer door will not close after printing 8p - Hivmr
www.hivmr.com/db/8p83f78d97fk8c883x9p9za3mf993scf
On the 50.8 error message, if power cycling doesn't fix the issue you may need to ...Opened printer cartridge access door and removed paper. ... HP Officejet Pro L7580, the latch to the ink cartidges broke, so the door won't close. ... Can not close the printer door on my HP B210a, after cartridge replacement need help?
Re: Do u need Help? -HP All-in-One's(Officejet,Psc's)
www.fixyourownprinter.com/posts/28357
Also, when reinstalling the HP it does print a test page, but will not print from ...Encoder Strip has been cleaned with water (had some ink residue). ..... when opening the door the cartridge does not move to the middle so i can remove it, clean it ...... Iopened the covering part of the scanner (with the glass) nad cleaned all the ...
HP Officejet 6210- repeated ' FixYourOwnPrinter
Dec 28, 2015 | HP Officejet 6600 e-All-in-One -...
After replacing 901 black cartridge printer keeps saying aligning cartridges please wait
every time replacing an ink cartridge, printers asking for alignment.do it once , following instuctions which appears in printers monitor.after,look at printed page and saw if is asking to scan once this page.
Feb 15, 2015 | HP Officejet 4500 All-in-One -...
I have HP Officejet 6310 All-in-One I replaced black ink cartridge No 98 just recently, and since then I have problems to print anything. When I try to print I get this message on printer?s...
hello, some of the time the color ink cartridge can cause the problem, especially if its a refilled ink, but at same time, i do know some of the new inks right out of the box will fail. so try with a new color cartridge first.
Sep 30, 2010 | HP Officejet 6310 All-In-One InkJet...
Have all-in-one HP 7130. get error message stating alignment failed. Problem started after I replaced cartridge ink.
Whenever you replace inks it will want to do alignment. Before installing new inks you should dab the bottom gently on a damp paper towel and see that all colors make a stripe on the towel. If any colors are missing during alignment it will always fail.
Nov 03, 2009 | HP Officejet 7130 All-In-One InkJet...
HP J4500 color cartridge error
Take the cartridge out and clean the contacts off with something (ie: pencil eraser, your thumb...) That worked for me! I couldn't find a solution anywhere even after chatting with online tech support from HP. Quick and painless! I hope this helps...
May 31, 2009 | HP OfficeJet J4580 All-In-One Laser...
I just installed a new black ink. The error message keeps on saying wrong color cartridge installed. I replaced with the correct one for my officejet v40. Black 15.
did you try changing the color cartridge too? I had problems with ink cartridges that were not HP cartridges.( not made by HP but some other co.)
Dec 05, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Remove & Check Cartridge message
Hi Scallag,
Please check with the ink cartridge numbers given below.
HP Officejet 6100 series All-in-One model Black cartridge Color cartridge Photo cartridge HP Officejet 6110, HP Officejet 6110xi, HP Officejet 6110v HP 56 HP 57 HP 58
Click on the web link given below and perform the steps carefully.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01299067&cc=us&lc=en&dlc=en&product=79477
Here is the other web link.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01300415&cc=us&lc=en&dlc=en&product=79477
Have a great day!
Mar 20, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Message: Remove and check ink cartridge
hi just fixed my 6110 hp by pulling out spring wire that is on right hand side where black ink cartridge gets inserted i think it was preventing a good contact
i did this after following all other help hints including cleaning heads etc and replacing with new ink now it works perfect hope this works for you too
Oct 14, 2007 | HP OfficeJet 6110 All-In-One InkJet...
270 people viewed this question
jasbo
jasbo
