Question about Audiovox Car Audio & Video
Tech Support for CCS-100
Can't get it to work. Do you have a wiring diagram using a GM HEI ignition?
Hi! I've got my Audiovox ccs-100 installed in my Duna Weekend Diesel car. But it just doesn't work. I don't know if it's because I connected the vacuum to the brake servo or what! Can you help?
Posted on Apr 23, 2010
Why my 94 Astro van will not fire
this generation of gm vehicles is easy to troubleshoot. the engine needs 3 things to run: compression, fuel, and spark. since you mention fire, i assume you have no spark.
disconnect any random spark plug wire and connect the end to a hei spark tester. crank engine and observe for spark. if you have no spark, disconnect the center terminal of the distributor cap and use the hei tester in the same manner. spark means cap and rotor bad or bad plug wireset. no spark means make more checks.
check for battery voltage and good ground on distributor. check for open or shorted ignition module or ignition coil windings. if power and ground is present and ignition coil tests ok, check for ignition pulses at coil primary. if you have no ignition pulses feeding the coil, change the distributor.
with that generation of vehicle, the ignition system will operate without help from the computer. don't even troubleshoot the guts of the distributor, if you change the cap, rotor, and anything else, it will be the same price as a remanufactured distributor, and might not fix the problem. if you troubleshoot a low volrage related issue (no pulses, shorted or open circuit, unstable timing, etc), change the whole thing.
Jul 29, 2016 | 1994 Chevrolet Astro
1955 olds 88 hei ignition wiring to key and ignition system
Original system has a resistor wire between coil + and ignition key, to reduce voltage and thus increase amps to give fatter spark and increase fuel mileage. For HEI system, this resistor wire must not be used, so run new primary wire straight from switch "run" to coil +. There should already be a wire from the starter solenoid to the coil + to supply full 12 volts when cranking to give higher voltage spark to plugs to help jump the gap better for use while starting. The MSD web site has much more info.
Jul 05, 2016 | Cars & Trucks
Original Engine wiring conv. to hei schematic?
Dead simple. Old system used a resistor wire between ign. switch and coil. HEI does not need this so you need to run a 10 or 12 guage wire from the ignition switch "ON" position to the new coil with no resistor in between. This also means you no longer need the extra wire from the starter to the coil which was used to bypass the resistor wire in the old system to provide full 12 volts for starting car. The reason for the resistor wire in the circuit was to reduce the voltage to the coil once running so the amps in the spark would be higher to burn more thoughly and increase fuel mileage.
Apr 23, 2015 | Cars & Trucks
INSTALLING HEI IGNITION AND NEED HELP
i have no issues WITH CAPS, used to have a home computer in 70s with ASR33 printing terminal that did all caps..... all the time.
Is this a 1990 jeep? and what engine? you never stated the engine
4.2 L AMC straight-6 engine?
what distributor are you running off what engine, and what year.
is it with full mech, advance and vacuum advance , pre 1986?
the nutter bypass, 4.2L
it cuts the ECU out of spark controls.
this means ECU advance is killed, on now only the dumb
module runs advance.
the stock system had a ballast resistance wire. and the
start wire to the the coil bypasses this wire. for full coil power.
this is not used in HEI.
infact there are many HEI setups. which one. 7wire. ?
here is 7
http://www.msextra.com/doc/ms1extra/MS_Extra_Hardware_Manual_files/ew7hei.gif
if i had your rig, it upgrade it to MSD. sure would. done many.
by doing that , all the mystery of parts, that works ends.
if you need help, spec out your set up, including, schematic
and BOM, parts used, p/n of parts used.
here are 3 HEI ( 4,5,7 pin)
http://brianesser.com/tech/wiring/msd/WDTN_pn9615_Page_030.jpg
The biggest issues is spark timing curves.
getting them right for those Webers.
and standalone spark controls win here.
the right way
http://www.jegs.com/p/MSD-Ignition/MSD-Ignition-Controller-for-GM-EFI-Carbureted-LS-Engines/758329/10002/-1
You tune the spark advance for YOUR engine and setup.
not that funky stock spark box and nutter mod.
my guess, is you burned up the ballast when it hit the real
inside distributor coil primary, that is totally the wrong coil
for a ballast. I hope it dont burn up a good coil,,,,,,,
The coil and all wiring for EFI must be correct
and the bypass for starting , is useless. for that distrubutor
because it runs 12v all the time, so if the ballast did stay good
the HEI would be running way too low , at 8v. running.
and would fail.
here is a great HEI page, under dev. but is good.
http://www.crankshaftcoalition.com/wiki/Hot_rodding_the_HEI_distributor
this link above shows how to get HEI right on a carb car
but fails to show the benefits of true spark advance tuning.
Great fuel economy can be attained under light loads
with large spark advance. and then less under full load.
(no pinging too)
The spark advance , allows the flame front to start at the correct time
to take advantage of piston rod angles.... and not send unburned fuel out the exhaust.
Id put an MSD in there and tune it carefully, I would. (webers a given)_
Feb 03, 2014 | 1990 Jeep Wrangler
WHAT IS HEI ?
GM has offered High Energy Ignition (HEI) systems on vehicles starting with selected '74 models. HEI was standard on '75 and newer vehicles.
Check HERE for additional details.
Hope this helps (remember to rating this answer).
Oct 10, 2011 | Cars & Trucks
Wiring for a small block 350
need to know if its a HEI cap and rotor or not. HEI caps have the coil built into them , an all in one ignition as compared to a external cylindrical coil.
you need to know that. either the distributor cap is a huge hurken thing (HEI) or it has an external coil somewhere or the cap has a ninth distributor hole in the middle of the cap to put a coil. wire.
after you figure out which one it is then you have to either go to www.autozone.com and study chevy wiring or buy a haynes manual for the similar vintage engine. for the external coil I would try a chilton manual for a chev truck before 1972. for HEI anytime thereafter. I may be off by a few years on the age of the engine. but hopefully you got an idea of what to do, or just google chev engine wiring? and study away.
good luck
jm
Jul 27, 2010 | 1980 Chevrolet Corvette
Late for everything...
Do you have any idea what ignition system it has, as there were 2 or 3 used in around those years on the AMC products. If it's the HEI system, I'd suspect (1) pickup coil in distributor, or (2) module in distributor. If it's not HEI, let us know and we can help further.
Nov 10, 2009 | 1983 AMC American Motors Eagle
Where do i connect the green wire on atachometer on a HEI gmc ignition w/the coil seperate from the distributor?
GM HEI
Either go to the TAC terminal on the distributor or to the C- terminal/wire, which is typically a brown wire.
Oct 15, 2009 | 1987 Chevrolet Suburban
Hei distributor on old L6 engiune won't fire coil
'56 engine was likely a "blue flame" engine that had a points type ignition system. If someone installed a HEI setup in there, you need to know what year vehicle it came from. The old system used a hot wire from the ignition switch to the (+) side of an external coil...the (-) lead went to the points. The most common conversion uses the same (+) wire but it then connects to the "batt" terminal on the distributor cap.(coil is inside) There are no other wires involved except for the short harness that goes directly into the distributor that connects the coil, pickup coil and control module to each other..
Sep 18, 2009 | 1999 GMC Sierra 3500
HEI DISTRIBUTOR PROBLEMS
This should help, firing order is counterclockwise, 1,8,4,3,6,5,7,2.c9602d8.jpg
Aug 24, 2009 | 1986 Cadillac DeVille
Car Audio & Video Logo
250 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
