If I can see how it works, I may be able to free up the mechanism with some Blaster or Liquid Wrench. If you have any other ideas pls let me know.
SOURCE: hubcaps
yes you can you can gnerally find then at the auto parts counter at the dealership or at NAPA, Oreillys, or AutoZone. please rate this. thanks
SOURCE: Need to replace brakepads but have lost the original wheel removal tools
If you go to a GOOD auto parts and equipment supply store, you will be able to purchase what is known as a "nut splitter". This is a device that you use to cut nuts along their axis when they cannot be otherwise removed safely.
A correctly sized nut splitter (there are many styles and sizes, so choose wisely) will be able to remove a non-recessed wheel lock nut easily.
If the wheel lock lugs are recessed, you will have to drill the lugs and use an appropriately-sized extractor to remove them from the studs (be careful of left-hand threaded studs on some vehicles--marked with bands or notches).
SOURCE: I need to know the torque wrench settings for
The small bolts holding the caliper to the bracket are 20 ft/lbs
The larger bolts holding the bracket to the hub are 79 ft/lbs
SOURCE: how does one remove the fan clutch assembly?
need to hold assembly so it wont turn and than wrench right to loosen
SOURCE: a light on dash with
http://www.extendedgmwarranty.com/owners-manual/chevrolet/2006-Chevrolet-Trailblazer.pdf
Sorry, couldn't find the error light you are talking about but maybe this maunual will help you 3-30 is the area for warning lights.
