I have a out side on the ground A/C and the mowing crew pulled a little brown wire inside the wire is re and white I dont know where it goes and I cant get heating guy out any time soon?
  • 1 more comment
  • Timothy Nierescher Aug 01, 2009
    inside the brown wire there is only two wires a red and white and inside the a/c ther is two blue wires I tried to hook those wires up and got nothing and last if the red and white wire touch will it shrt out the furnace and if it does what do I do next?
    can u help?
    President:
  • 1,124 Answers
The answer to you question is - yes..
There are many ac repair companies that will come out 24/7..
Just do a Google search - type in air condition repair & your zip code
Several will come up in your area..
Also - that what ever the charge is - you might consider back-charging the lawn service company to recover your costs for the repair..
Note;
Thank you for posting your question on FixYa.com
We are helping people on a points system.
If the information provided here was at all helpful,
please be kind - rate well and close the post.
If you have further questions please open a new post
with your new question.
Thank you – and enjoy your day ;o)
Posted on Aug 01, 2009
  • 10,865 Answers
The "little brown wire" is the thermostat wire. If you look carefully at the wire you will see that there is a red wire, a black wire and a white wire.
Inside your outdoor AC unit you will see where the wire was connected to a block where the screw labeled B gets the black wire, W gets the white wire and Y gets the yellow wire
  • Joe Hogan Aug 01, 2009
    the thermostat system operates on low voltage so u don't have to worry about shorting it out. if you have the manual go to the wiring diagram and see how to proceed. if you don t have a manual get back with the brand and model of A/C you have out doors.
    what brand and what model of ac do u have. what is the brand and model of your condenser, the big outdoor part?
How to wire air compressor motor to 220v
Insulate brown means cap and tape.
240Volt should not have neutral wire
http://waterheatertimer.org/Basic-house-wiring.html#basic-wire
http://waterheatertimer.org/images/Inside-Main-Breaker-Box-12.jpg
240Volt coming from breaker box will have 2 hot wires... and either hot wire is same no matter wire color
http://waterheatertimer.org/Color-codewire.html#motor
Gene
Oct 07, 2014 | Hardware & Accessories
Hook up black white and green ground
hooking up 120 volt you must change the brown and white wires to different positions see the side of the motor for the low voltage schematic then your black wire goes to F1 and white wire goes to F2 with other white wire then green goes to the metal case under the green csrew
Jun 20, 2014 | Pentair One - Speed 1.5hp 115/230v Dynamo...
Im hooking my pool pump up to a 220 and I dont know what wires go where. On the motor there is a A and B and a L1 and L2. What do I put my brown wire on and what does the white one go on. Can u help me...
There should be a diagram on the side of the motor showing you where to put the brown and white for 110/220 volt operation. Most new motors of this size are shipped strapped for 220v. The two hot wires will go to L1 and L2 and it doesn't matter which wire goes to which lug. For 220v you will usually have 2 black or 2 red wires and a green ground wire. If it is 110v supply, you will usually have a white and a black wire, and a green for ground. Hope this helps. Since you said you are hooking to 220v the brown and white should be on the correct lugs if this is a new motor.
Jul 19, 2011 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
There are four differently color coded cables coming from my 2002 daewoo lanos that WOULD connect to a 4 wire heated downstream oxygen sensor but the connector has been severed and is nowhere to be found. ...
red/white is 12v goes to pink (12 v for heater). black goes to black (ground)..... brown/white goes to brown/white (signal from ecm) purple/white to purple/white for (signal to ecm).
Jun 12, 2010 | Daewoo Lanos Cars & Trucks
I need a steering column wiring diagram for a 1979 cj5. On the column side of the plug that goes to the steering column there are 8 wires. White, Black, Yellow, Green, Purple, Brown, Light Blue, and Dark...
Black horn ground
lt.blue left front turn
blue right front turn
brown hazard power
purple turn signal power
yellow left rear turn
green right rear turn
white brake light input
Feb 12, 2010 | 1983 Jeep CJ5
Need a wiring diagram for emerson k55hweym 3739
green is ground. white is common. blue and orange are hi speed/low speed. brown goes to the capacitor.
Both motors should have the wire diagram on the side of the motor.
Jul 03, 2009 | Emerson Quiet Kool 10MW42K Air Conditioner
Cannot restart after power outage
SAVE YOURSELF $800 by reading this.
Well guess what...?
We were gone for the weekend and came home and our superba was on but not cooling. Prayed about it . (always the first solution) then I looked on this web site, it said compressors go out on this model. Then went down to our local appliance guy who is actually honest. He said I was about the 5th person that day. He said there was a power surge. HERE IS THE KEY.... Apparently there is a surge protector on the compressor that fries in order to protect it. DING DING DING The compressor is not shot but a little 40 dollar part that you can replace easily. ( im an idiot and it took me 5 minutes when I got the part.
Im not responsible for you doing this but I will tell you what I did. FIRST I unplugged the fridge! Then pulled it out from the wall so i could get behind it. Then at the bottom is a card board cover. It comes off with screws. You dont even have to take it all off just the left side and pull it back. Then right there you will see a compressor ( it looks like a litte tank with some copper tubes going to it and , connected to the compressor is this little plastic cover, box sort of thing. Has some wires coming out of it. The directions on how to remove this cover is facing the side of the fridge IMPOSSIBLE to read because you cant see it because the angle is to the side not facing you.
Now go into your kids room and grab some playdoh or clay or silly puddy, flatten it out and spread it and press it over the diagram directions pull it off and look at the impression of the diagram it will be backwards but it gave me enough of an idea to get it off. Break this plastic cover if need be it is worth it to get to the part you need.
Once off you will see this little white part and little brown part with wires going to it. DO NOT PANIC! this is easier than you think. trust me . Okay go grab a digital camera try to get a couple picts of how it is sitting in there. ( not a big deal but we will want to take a pict of it once you pull it out)
Okay there are only 3 wires connected to those things. You dont have to know what they are for just WHAT CLIPS THEY ARE CONNECTED TO. So these brown and white things are not connected they just sit on top of each other so do be confused. These things have little holes in them like an electrical outlet ( but they are round not flat) these brown and white things are plugged into the compressor.
NOW Still do not panic. START With the brown one. You will need to pry these off the pins off the compressor like you are unplugging an cord. it will be tough to pull off. See if you can get a flat screw driver and pry it carefully away. You may need strong fingers. Remember this will save you atleast 300 bucks that sears will charge for just coming to your house.
Once it comes off do not pull off the wires. Take pictures of how the wires fit onto it. Also mark on the piece itself where the colored wires fit on which little connector. shake the little brown piece around does it jingle? It is not supposed to you found the problem! DO NOT PANIC Rejoice! Apparently there is a little disk in there that will shatter when there is a power surge.
Then pull off the white one also take pictures mark what wires goe where on that little part. Okay now grab some pliers and firmly grip the wire slide connector end and pull off the wires from their slide parts on the brown and white thingy. Congrats you are 80 % done.
Take a digital picture of the lable of the compressor so if you need it for reference. Find your local appliance parts place and take your model number with you just incase they dont know what they are talking about. I bought my little brown and white parts for 40 bucks for both. SAVE your old parts so incase they do not look exactly alike you can see how they go back together.BEFORE you leave the appliance store pick up a little refidgerator lint brush, they have them for 8 - 10 bucks. Trust me on getting this.
Now go home, Reattach the wires they way they did on the old parts. ( DO NOT REINSTALL OLD PARTS) Put the white one back on the little plugger first then the brown one on top.
Good as long as you got the wires in the right place and the pieces firmly seated you should be done BUT WAIT. Look in the bottom of the fridge behind the compressor. See all those tiny black tubes covered in hair and dust bunnies? You got to clean that. Get that brush I told you about. Grab your vaccuum hose and put it under those coils and carefully push and brush all that gunk off into the vaccuum. this will make your compressor last years longer and save on electricity. try to clean it every day light savings time.
Okay plug in your fridge. It should begin cooling again. Remember it takes a while to cool all that food again. If you want to check put a thermometer in it and see if it is cooling enough.
SEE now if this worked, Go and spend $ 400 bucks on a nice weekend somewhere because you would have had to replace it with a decent fridge and you will remember a nice weekend 20 years from now not saving 800 bucks on a fridge repair.
Best to you all
Scott
Walkingfeather dot com
Mar 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
Replacing blower motor in furnace w/Fasco brand #D727
Some one missed the wiring diagram. I believe its like this:
L1 = Line 1 = (Hot all are same thing)
Black Hi
Blue Med
Red LO
Now usually the black is for AC and connects to a normally Open (NO) contact on the blower relay.
The heater speed (either red or blue) go the the normally Closed (NC) on the blower relay and on one side of this wire or contact on the relay it goes to the heating blower thermostat on the furnace.
The remaining wire (blue or red) you tape off.
L1 also feeds the Run Capacitor on 1 side and the Brown wire feeds the opposite side
The white wire is Neutral and goes to the neutral on the main line.
If this helps you please rate me accordingly and good luck.
Mar 13, 2009 | Kitchen Appliances - Others
Bmw e46 electric wing mirror wiring diagram
your mirror control switch has 9 wires.,your drivers door mirror has 5 wires color coded .from your mirror control switch to your drivers siide mirror / 0.5 black .0.5 brown. 0.5 brown. 0.5 black. 0.5 black.
your passenger mirror wires are 0.5 blue/black .0.5 blue/grey. 0.5 blue/white. the passenger mirror has a ground cable 0.5 brown.
the passenger mirror wire 0.5 green/white connects to a 5amp fuse/F25 onto F31 5amp to a wire 0.75 green/yellow.back to the mirror control switch.
Jan 20, 2009 | 1999 BMW 318 ti
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
