Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Conection of equipment
I need help hooking my equipment up
  • 1,030 Answers
Re: conection of equipment - RCA D52W20 52" Rear Projection HDTV-Ready Television Projection Televisions
What type of equipment .. to what?
Posted on Dec 07, 2007
0 characters
3 Points
Can I plug an antenna into my KP43T70 and get a signal from the local tower or do I need special equipment? Do I need a special antenna???
You are most likely going to need a special antenna. Like a DTV converter. To just hook up a antenna and pick up local channels you will need a newer LCD or LED flat-screen.
Sep 13, 2013 | Sony KP-43T70 43" Rear Projection...
I have the JVC 52g886 model and every time i hook high def green, blue, and red cables i have no sound just picture
you need to conect an other lead with red and white ends into tv audio input and the other end into audio out on the equiptment
hope this helps and merry christmas
Dec 05, 2009 | JVC HD-52G886 52" Rear Projection HDTV
Hitachi tv problem
I'm going to say you have a VCR or something hooked up, if so turn it off and if not its probably the television companies equipment
Jul 25, 2009 | Hitachi 46F510 46" Projection HDTV
Panasonic PT-51HX40 Wont stay on
could possible be bad conections
I had a set that was doing that the bad conection was at the relay but you always check all conections
hope this helps
Jan 31, 2009 | Panasonic PT-51HX40 51" Rear Projection...
Is the HD52W59 HD ready or do you have to buy a seperate antenna?
if you are hooking it to a coaxial conection there are 2. try the digital coax input.
Jan 28, 2009 | RCA HD52W59 HDTV Projection Television
Phillips hdtv
to switch that you need rca 3 color red, blue, green to view
more that 480i , or HDMI conection
Jan 20, 2008 | Philips 55PW9363 55" Rear Projection...
hook connector to right IF outlet .check menu make sure your on tv mode not video1 ect,,,, then find auto programing press vol+
Nov 17, 2007 | Philips 60PL9200D Projection Televisions
RCA p46813BL with no picture but good sound
The good news is your set has a picture therefore is not an output transistor,the problem your set has is a signal processing problem,no video of any source is being processed,is just a different kind of problem and for that you will need the assistance of a servicer to diagnose,try taping where the cables conect to the tv if the set reacts the loose conection is close to that imput panel but if it does not be safe and call for help.
Oct 01, 2006 | RCA P46812BL 46" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Projection Televisions Experts
The Wyzzyrd
D. E. Hev
Ron Dufek
Ron Dufek
Are you a RCA Projection Television Expert? Answer questions, earn points and help others
