Question about Epson Stylus Photo R1800 InkJet Printer
Getting "ink pads full" type message. How can I get replacement for pads; heads cleaned; other service?
    Sergeant:
    Champion:
  • Epson Expert
  • 387 Answers
Get a Waste Ink Container. http://www.inkproducts.com/ink-store/
Posted on Aug 05, 2009
Connon mp210 error message "ink absorber is full"
When the print head parks there is an absorbent pad directly under the cartridge. It is there to catch the ink when you do a head clean operation. Take out the ink cartridge and remove the pad with a tooth pick so you don't get ink all over yourself. Run it under a water faucet to clean the ink off the pad. Use a paper towel to dry out the pad and then reinstall in the printer.
Oct 21, 2014 | Office Equipment & Supplies
Canon Printer Pixma MX700 All-In-One/ Alert message received. Ink absorber almost full. Contact service. How to get to? Have to replace?
Ink Absorber Full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
Aug 19, 2012 | Office Equipment & Supplies
We're getting this Service Required message - Parts inside your printer are near the end of their service life. See your printer documentation. What part are we needing to replace?
the parts most likely to be replaced with such a message are the waste ink pads. (sponge pads that collect the ink that is used for print head cleanings). these pads are difficult to reach inside the printer (full dissassembly is necessary) and doing so is a VERY dirty job. i suggest contacting a repair center near you.
Sep 11, 2010 | Epson Stylus Photo RX600 All-In-One InkJet...
Stopped printing after 'waste ink full message' how to I fix it.
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 20, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Canoni350 - printer won't print, message "used ink tank full" - how do i rectify this ?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "used ink tank full" error.
May 19, 2009 | Canon Office Equipment & Supplies
How do you find the waste ink collector on a printer/scanner ?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
The waste ink absorption pads are inside the printer, in the very bottom. They are usually soaked with ink when full and are very messy.
May 18, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Message "wasted ink tank near full" on Canon Multipass F80
May 17, 2009 | Canon MultiPASS F80 All-In-One InkJet...
When I try to print, an error message comes up and says ''Waste obsorbsion field is full'' In wording similar to this
May 17, 2009 | Canon Office Equipment & Supplies
Its appear " The ink absorber is full. Contact the service center."
May 11, 2009 | Office Equipment & Supplies
Error message parts need servicing
The error message you are getting is because the printer thinks you have gone through too many cleaning cycles and assumes the waste ink pads at the bottom of the printer are full. sometimes this is correct but not always. the only way to know for shure is to remove the cover and physically look inside at the waste ink pads. if they are saturated with ink you can do one of three things
1 remove pads and clean in water and dry (very messy)
2 get replacement pads (probably not economical)
3 take a chance and use utility (printer don't work anyway)
If waste ink pads are full and you leave them it may cause problems later when you run more cleaning cycles as the surplus ink now has nowhere to go.
hope this helps
Nov 26, 2007 | Epson Stylus C46 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
65 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
