Question about Sony Televison & Video
TV turns on but no video
No video
  • scpeck4 Aug 01, 2009
    Cables are plugged in... the stand-by LED is blinking and you cannot turn the TV on or off nor can i see a display
  • Sony Master
  • 13,433 Answers
Are the cables plugged in properly? Can you clarify the question?
Posted on Aug 01, 2009
  • Ekse Aug 01, 2009
    you should have included that information in the original query I can not help you with that, take it to a repairer or repost the question.
My 32inch lcd tv keeps flickering it started all the sudden
TRY THIS
    • 1 Turn the TV off with the front-mounted power button, not the remote. Unplug the TV's power cord from the wall outlet. Let an hour pass before plugging the cord back into the wall outlet. Turn the TV back on with the front-mounted power button and wait until it has fully restarted. Bring up a TV channel to see if the image being presented on the LCD screen is no longer flickering. A momentary power surge can cause the circuitry inside the LG-brand LCD TV to function erratically.
    • 2 Unplug the video cable from the video connection on the back or side panel of the LG TV. If more than one video cable is connected to the TV, disconnect all of them. Disconnect the other end of the video cable from the video source device that it's attached to -- a DVD or Blu-ray player, or a satellite receiver or cable box. Blow off the connections on the video source device and on the back or side panel of the TV with bursts of compressed air. Reinsert one end of the video cable into the video source device and the other end into the video input that it was connected to. Turn the TV back on with is remote to see if the picture is now free of flickering. A loose or partially connected video cable can cause the LCD TV's screen to flicker when presenting an image.
    • 3 Turn the TV off and unplug its power cord from the wall outlet. Place a power conditioner next to the wall outlet. Plug the power conditioner's power cord into the wall outlet. Plug the TV's power cord into one of the AC sockets on the power conditioner. Turn the power conditioner on. Turn the TV on to see if the picture is now free of flickering. The RF signals in the electric line that the LG TV is drawing power from can cause flicking through interference patterns being generated.
Oct 20, 2012 | Computers & Internet
Msi tv out
If the TV has a VGA port, then you can connect the U100 directly to the TV. Otherwise, you will need a converter depending on the inputs of the TV.
In the case of a VGA port on the TV, turn off the TV and the netbook before connecting the two devices. Then turn on the TV and set it to the VGA input. Then turn on the computer. The monitor should be recognized when the OS boots up. You can press <Fn>+<F2> to force the communication. In the Display properties (right click on the desktop), you should be able to change the display mode.
For composite video, the converter option uses devices like these: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-composite-video/c10000-c11200-c11213-p1.html . Again turn off all devices before connecting them and turn on the computer last. If a TV has only an RF (antenna) input, you can connect the VGA to composite converter to an RF modulator. However, signal losses may degrade the video.
I hope this helps.
Jun 20, 2012 | Computers & Internet
Turning on and off all by itself
Owners Manual, Pg 18, TV Auto Function.
"If a video feed is connected to the TV VIDEO IN jack during the installation, that signal is used to trigger system turn on. Even when the receiver is turned off, the presence of a signal at the TV VIDEO jack will automatically cause the receiver to turn on. As long as the signal is present, the receiver will remain on. When the TV or other source is turned off, the receiver will automatically retrun to a standby mode within five minutes."
Try using a another video input.
Jan 12, 2011 | Harman Kardon AVR 70
Magnavox portable TV
Try hitting VOL UP & VOL DN at the same time.
Your set is in the demo mode.
Stargazer
Dec 27, 2007 | Philips Magnavox 20MT133S 20" TV
Hitachi 43FDX10B rear projection tv
Do you have a cable box which turns on and off with the tv? If so is your cable box input on the video 4 mode? If that is the case look under the video menu for advanced selections, you will see a selection for auto/on/off for video 4, select off. Check manul under video and it will explain also.
Nov 30, 2007 | Hitachi 43FDX01B TV
Watching tapes on TV
To connect your camcorder to a TV (or VCR), you'll need audio/video cables. These need to be run from the VIDEO and AUDIO jacks on the camcorder to the VIDEO and AUDIO inputs on the TV (or VCR). Once cabling is completed, follow either of these scenarios: When connecting the camcorder directly to the TV, turn on the TV and tune it to the video input channel by pressing the INPUT button on your remote control. # When connecting the camcorder to a VCR that is already connected to a TV: Turn on the VCR and place it in the Line or Camera mode. # Operate the TV as you normally do to see the signal coming from the VCR. Select camcorders have an S-VIDEO jack, which offers higher video quality. Provided your TV or VCR has an S-VIDEO input jack, connect the camcorder to the TV or VCR using an S-VIDEO cable. Since the S-VIDEO cable only transfers video, you will also need to use an audio cable. Select the S-VIDEO input on your TV or VCR to view the signal coming from the camcorder.
Sep 06, 2005 | RCA CC-432 Camcorder
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
