Question about Xantrex Technology Heart Freedom 25 Inverter/Charger 12v, 2500w 130a, 81-2511-12
My 2003 unit as above simply stopped working.Green power light is on .But mechanic recharged batteries to no avail..
  • ron laporte Aug 01, 2009
    i beleive yes we have ac at the plug
    President:
  • 1,714 Answers
More info on unit and guides for troubleshooting here:
http://www.xantrex.com/support/web/id/997/support1.asp
Are there any faults that have occurred at all? Your unit has:
Protection Features
  • Battery over-voltage and under-voltage protection
  • Over-temperature shutdown
  • Automatic overload protection
  • Short-circuit protection
  • Ground-fault protection
  • ETL listed for use in mobile RV and marine applic
Any of these?
do you have AC at the plug?
Posted on Aug 01, 2009
  • Craig Butler
    Craig Butler Aug 01, 2009
    If there is AC at the plugs, the inverter is working, what seems to be the trouble?
Our cordless hedge trimmer will start but keeps stopping after about I minute it won't cut bushes have tried to recharge. How long does it take and should a light show to indicate it is recharging. Th
Most chargers will show a green light when charged
That could take an hour
You have to or I do,charge all my items every 3 months
Not uncommon to have a failed battery in less than a year
Ideally four years & fair amount of use,but some do fail
Oct 29, 2014 | Bosch ASB Cordless Hedge Trimmer/Grass...
The little box inside my rechargeable lamp gets very hot when i try to recharge it. what is the problem?
The "little box" to which you're referring is one of two things, both of which are designed to get warm (but not burning hot) when your flashlight is recharging. The first, obviously, is the battery; it will naturally warm as it recharges. The second, and perhaps what you're referring to, is a voltage regulator designed to make sure that the battery is getting proper voltage. That second box is also designed to get warm, but over time, as heat sink compound shifts and/or components inside start to age, that can get much warmer while still properly functioning.
Neither of these components is user-serviceable, though either can be replaced if it is defective. A hot battery indicates the possibility of some internal short-circuiting, though if the lamp continues to work, it could simply the be result of increased internal resistance in the battery due to lead plate sulfation.
The bottom line is that you might as well keep using the light as-is until it stops working. At that point, if it's the battery that's been getting hot, you might want to see whether you can get an affordable replacement battery for your light. Otherwise, sad to say, the unit has reached the end of its useful life. I hate throwing items like this away, but without the availability of affordable replacement parts (replacement batteries sometimes cost more than an entire new light!), that may be the only reasonable way to go.
Dec 20, 2012 | Vector 1 Million Rechargeable Spotlight
How long do i have to charge the stanley j309 300 amp battery booster
Before the first use, the unit must be charged for 24 hours with a connection to an AC outlet (120V). Make sure that all of the switches are off. After that, stop charging when two red and one green LED Battery Status Indicators light.
If you are recharging the unit from a 12V battery, do not charge for more than 6 hours. (Check for a full charge by disconnecting the DC charging adapter and then press the Battery Power Level button.)
The manual for the Stanley J309 battery jump starter is available on the product page here: http://www.baccusglobal.com/stanley/j309.php . The direct link to the manual is http://www.baccusglobal.com/stanley/manuals/JUMPERS/J309%20MANUAL.pdf .
I hope this helps.
Dec 29, 2011 | Garden
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
Speedo aquabeat 3g mp3 player is not charging. The LED light turns to green, but when I unplug it it won't work.
You are plugging the headphones into the unit and then trying to power up the unit, correct? The Aquabeat will not power up unless the headphones are connected to the unit and disconnecting them will shut the unit off.
Feb 19, 2010 | Speedo Aquabeat MP3 Player i
Controller wont hook up with console ?
Is this a new controller?
Are the batteries new/recharged?
This is the sequence summary on where you are going to focus:
Step 1 - Controller
Step 2 - Console
Step 3 - Console
Step 4 - Controller
Step 5 - Both
Assuming your controller is a wireless version, Lets start!
Step 1 | Press and hold the Xbox Guide button until the controller turns on. The Xbox Guide button is the round button with the green "X" near the center of the controller.
Step 2 | Make sure that your Xbox 360 console is turned on. If your Xbox 360 console is not turned on, press the power button. The power button is the large round button on your Xbox 360 console.
Step 3 | On the Xbox 360 console, press and release the Connect button. The Connect button is the small round button on the Xbox 360 console.
Step 4 | On the controller, press and release the Connect button. The Connect button is the small button on the front edge of the controller, between the left bumper button and the charging port.
Step 5 | After the Ring of Light spins and flashes one time on the controller and on the console, the controller is connected. The quadrant on the Ring of Light that remains lit indicates the position in which the controller is connected.
Light indicator on console
Green light in the center- power is on
Green light on one quadrant - controller is connected
Four green lights rotating on four quadrants - ready to connect with controller
Light indicator on wireless controllers
No lights - no batteries
Green steady light on one quadrant - connected
Blinking green lights - its either its ready to connect or the batteries are dying
*Make sure that you have a fully recharged rechargeable batteries
*Make sure that you have a functioning/new non-rechargeable batteries
*If the steps above aren't working use another Xbox360 controller and follow the same steps.
If the new/working controller is connecting with the console this means that the previous controller is faulty - needs replacement.
If the new/working controller is not connecting with the console this may mean that the console is faulty - needs repair.
*NEVER TAMPER WITH ANY OF THE TWO AS TAMPERING WILL VOID EXISTING WARRANTY.
Nov 23, 2009 | Microsoft Xbox 360 Console
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Blades stopped on my 02 cool fan.
I love the 02 Cool rechargeable/battery operated fans and have them running in my home and office daily. However, they do have a limited lifespan. I get about 6-9 months of daily use before the fan motor goes dead and the blades stop turning. However, I'll keep buying them. I live in an area where we frequently lose power and the rechargeable/battery operated feature pays off when it does so on a hot day.
Jun 25, 2009 | Panasonic Dryers
Red flashing light
Find a new supply of "Duracell Ultra with M3 Technology" batteries and give them a try. The flashing red light is usually an indication that the batteries you have in the unit are not producing sufficient power to run the camera. Rechargable batteries are should have a rating of 2500mAh or above in order to provide enough power to maintain the draw from the camera.
Hope this helps!
OpenSource13
Apr 05, 2009 | Sanyo Xacti VPC-S60 Digital Camera
Battery flashes between orange and green
The rechargable batteries have life and will go bad like any other batery. The battery needs to be replaced. Some of the older units are discontinued so parts are no longer available. New nebulizers can be obtained for as cheap as $100.
Mar 31, 2009 | Invacare Supply Group Invacare Corp...
Xantrex Technology Heart Freedom 25 Inverter/Charger 12v, 2500w 130a, 81-2511-12 Logo
52 people viewed this question
Top Xantrex Technology Boating Experts
Tre Elkins
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
