SOURCE: Epson scanner 1240U
needle3000:
The Epson "Perfection" 1240U Scanner won't work with Mac OS X 10.4.11 possibly due to the program it is being run from. Like you, I had the same problem: it wasn't being recognized. Epson's drivers installed and ran correctly. Scanner even appeared under Bus in USB Device Tree in System Profile. Finally, I discovered that the Scanner runs if opened directly from EPSON Scan.app under Applications. The problem, in my case, was my ancient version of Photoshop (5.5.) from which I was running it.
Hope that helps!
SOURCE: Scanner dirver
i need be@rpaw scanner driver which give the option to scanned light files not heavey.
SOURCE: scanner driver for Mac (psc 2410)
Hi there
iplease go to radarsync.com and install it this is a totally free utility that will help you find and install your driver for free
SOURCE: ION Audio VCR 2 PC USB VHS Video to Computer Converter it record
hi, friend, the aHisoft Video Converter is just prepared for you, It is a Total Video Converter that can convert video to MP4/MKV/WMV/AVI and other popular formats such as: AVC, FLV, MP-1, MP-2, 3GP, 3GPP, Mov, M4V, ASF, SWF, VOB, DV, Super VCD, VCD, DVD and HD video.
so i think it will be helpful, you can search it on google
or visit http://www.asharer.com/
Have a nice day, my friend!
1. Turn on the computer.
2. Insert the installation CD into the CDROM
drive and the installation menu will appear. *
3. When you see the installation menu, click Install Driver.
4. Follow the on-screen instructions.
5. When the driver installation is complete, click BlazePhoto to install the software.
6. Follow the on-screen instructions.
7. If your computer does not have DirectX 9.0 or greater or Adobe Reader, click those items to install them. (If your
computer is using Windows XP Service Pack 2 or higher, Windows Vista, or Windows XP Professional, this is not
necessary.)
8. Click Exit to close the window.
Note: The first time you connect PICS 2 PC to your computer, wait a few seconds until you see a dialog box
that says "Found New Hardware" (this means the computer recognizes the PICS 2 PC). After you see this,
PICS 2 PC is ready to use.
If you followed the above instruction and still have a problem, reinstall (first, Remove from Add/Remove Programs) the software and be certain that the USB cable is snug.
If your computer is not recognizing the ION PIC2, be certain that your computer has a USB 2.0 port. Check your Device Manager to verify what USB port.
If still a problem, what error message(s) are you getting ? What operating system software (Vista, Windows 7, etc.) ?
Hope this helps.
