Ken Reenen
SOURCE: code list 6 devicphilips universl CL019
for tv: 0713, 0502, 0606, 0409, 0710, 0415, 0507, 0714, 0405, 0712, 0015, 0916, 0008, 0002, 0115, 0224, 0324, 0126, 0326, 0826, 0228, 0430, 0632, 0043, 0437, 0903, 0505, 0701, 0407. i know, it's a lot to try.
for VCR (you still use VCR?? ;)) 0534, 0326, 0826, 0228, 0430, 0224, 0324, 0435, 0336, 0936, 0339, 0529, 0438, 0925, 0632, 0824, 0239, 0529, 0438, 0925, 0336, 0936, 0437, 0126, 0524, 0632. good luck!
SOURCE: universl rca remote didn't come with dynex code
Dynex is made by Sansui.....try one of its codes
Hope this helps!!
SOURCE: Remote control RM-810
Try 571. If this doesn't work try setting the code via the automatic programming feature.
RM-810 Automatic Searching
1. Turn on the TV
2. Press the “TV” key (*, **, or **) you want to program on the remote. The light should flash once.
3. Press the “Set” and the “Power” button simultaneously for 2 seconds. The indicator light should stay on.
4. Release both buttons. The indicator light will flash constantly indicating the automatic search mode.
5. After the indicator light illuminates, release the two keys simultaneously.
6. If the controller can turn off the device during its auto programming, you can finish programming in 1.5 seconds by pressing any other button on the controller
7. Check whether operation of other buttons is at normal state. If so yor setting is successfully accomplished.
If you cannot control the functions, try steps 2 through 5 again. If you do not press any button, the auto search function will stop after 30 seconds and the indicator light will go out and you will have to restart the auto search.
Let me know if this works for you. Thanks.
SOURCE: Remote no longer works.
Universal remote codes for Phillips:
0025, 0027, 0031, 0153
For Magnavox:
0027
If your RCA converter remote functions as a universal remote one of those codes should work. If not, you should be able to find a basic universal remote for around $10 at any drug store or grocery store. If you have a more complex home theater system and are interested in advanced functionality, Logitech makes an excellent line of universal remotes that range from around $80 to hundreds of dollars.
