That means there is something wrong with the mechanism of the CD. The best thing you can do is look inside and see if anything is damaged or stuck in the CD unit. If the drawer doesn't come out at all, it could be that the belt that makes it move is off or broken. I should imagine that could trigger that error message.
SOURCE: nokia 6600 system error
see budy either some of the starting files must have gone courrupted of your OS in ur handset or there is a Virus in ur mobile which is stoping ur startup file to get executed, so what u can do is either scan it once with any AV or after taking the backup make a flash updation,,,,, it will sort out the prob...... best of luck
SOURCE: BENQ DC E610 SYSTEM ERROR ON START UP
I got the same problem with that model. Please let me know if you were able to solve yours.
SOURCE: Error Message
The F61 indicates a problem detected in the output amp stage and the unit us shutdown to prevent further damage. If you can supply the model number, I can give you the part required and the approximate cost.
Dan
SOURCE: my sony mini hi-fi component model HCD-RV7, stereo wont come out
how can i remove push power protect
