Question about ASUS AiLifestyle P5KC Motherboard
Put a e7400 2.93 cpu will start bios but no keyboard what other processor will fit.its a asus p5kc motherboard
May be way too late, but yes, have solution.
Trouble is that as shipped bios cannot properly run e7400.
You must look at support processor for sipped bios, install opjne of those (in my case an e6600 I had in another computer), run ez flash 2 from the usb with the .rom file of the latest bios (1201 at the time of this writing), shutdown, reinstal the e7400, and proceed with windows,install, driver updates, etc.
Kind of a catch 22, does require you to have a processor supported by the installed bios, not necessarily the intended processor.
Once updared though, decent board.
Posted on Dec 24, 2009
    Sergeant:
  • 263 Answers
Try reflashing your bios with latest version check usb is enabled in BIOS if your using a usb keyboard otherwise maybe a dodgy board. Good luck
Posted on Aug 02, 2009
ASUS K8V-MX motherboard "UNKNOWN PROCESSOR"
There is a processor installed that the BIOS cannot recognize. Update the BIOS in the motherboard.
http://www.asus.com/Motherboards/AMD_Socket_754/K8VMX/#download
Also make sure the CPU is in the CPU support list, on the same page. If it is not a supprted CPU, you will get that error.
Apr 21, 2011 | ASUS K8V-MX Motherboard
AGGIORNAMENTI BIOS
You can find the BIOS updates right here:
http://www.asus.com/product.aspx?P_ID=fFZ8oUIGmLpwNMjj
Go to download. select "others" in "operating systems". Go to BIOS, expand that. The first one is the last update.
Mar 04, 2011 | ASUS AiLifestyle P5KC Motherboard
Hi i my computer suddenly started to shutdown and turn on again after a fev seconds.some times it goes in to windows but soon after crashes.it has wrked for over a year and this was a home built...
Try these....
Overheating problem in your PROCESSOR!
Check the temp in your BiOS and the setting of your processor!
Check also the power supply and upgrade it to hifgher wattage!
Clean your processor HEAT SiNK, dust and dirt might have acumulated!
Check the HEAT sink position, if its flatly fitted on top of procie, and scrape the old silicon paste between ur proci and heat sink and put a NEW ONE!
Encountered this kind of prob.. the prob is in the PSU unit(Power Supply Unit)!
These might help you!
Nov 07, 2010 | ASUS P5QL PRO Motherboard
CPU is not supported
The following link loads the overview of the ASUS M4N78-AM board. To get to the CPU support list, click the "CPU Support List" Tab:
ASUS M4N78-AM CPU Support
Note: BIOS revision 0901 is not correct for Phenom processors. Nor can I find your exact cpu listed.
Mar 09, 2010 | Computers & Internet
Trying to upgrade a Compaq SR1020NX computer. The HP website still has old info, likely based on the original bios. The motherboard is an Asus A8M2N-LA. What CPU upgrades will run on that board? Is there...
The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details:
Motherboard manufacturer's name: ASUS A8M2N-LA
HP/Compaq name: Nodus-GL8E
CPU/Processor  Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
Front-side bus (FSB)  2000 MegaTransfers/second
Chipset  GeForce 6150 LE chipset
BIOS features  Award brand system BIOS Keyboard combination to used to enter BIOS: F1
Form factor  Micro-ATX: 9.6 in X 9.6 in
Memory  Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
Feb 15, 2010 | AMD Athlon 64 X2 5400+ Processor...
BIOS WON'T START OR LOAD, ANYONE CAN HELP ME? Mainboard: P5S-MX SE Having troubled my CPU, it works for 2 years but now this is what happened. It won't start. First, i detached all the hardware attached...
Remove The CMOS Battery, For 10-15 seconds to reset The Bios to it,s default settings.
Try the memory Module/Ram in a different Slot.
Re-seat the CPU.
Mike @ Compurepair.
Oct 16, 2009 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Can I use a Amd athlon 64x2 dual core processor 4200+ 2.2 ghz on my A8V deluxe motherboard . socket 939
Yes, according to the Asus website specifications on the A8V Deluxe you are able to run the CPU. You just have to make sure that the CPU you buy is for Socket 939 and not AM2.
Please rate!
Cheers
Oct 04, 2009 | ASUS A8V Deluxe Motherboard
ASUS p5kc front panel connector
all motherboard front side audio connector is equal so if you compair with onther motherboard
connector
Feb 02, 2009 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Ucode error
The bios needs to load a patch table that supports your processor. Go to the ASUS website and ensure that processor capatibility with your MB, and if there is a BIOS update for it.
Jan 18, 2008 | ASUS P5VD2-MX SE Motherboard
ASUS AiLifestyle P5KC  Motherboard Logo
232 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
