We've changed the filter twice, but the ice is what tastes bad, water is fine. I've emptied ice maker 6 times. I've cleaned each area of the fridge, including the lower freezer. Im thinking it's refrigerant. But ice maker and freezer are frozen. HELP
I have the same issue with my Samsung fridge. Water tastes fine, but the ice has a bitter chemical taste - as if there was dishwasher detergent residue in the cup. All the water lines are plastic, I've changed the filter three times in the last four months, I've cleaned out the ice maker and the fridge and even replaced the bin and the ice maker itself and still have nasty ice. We still use the water from the fridge door dispenser but we buy ice. Makes me wonder why we got such an expensive refrigerator!
SOURCE: ice maker's ice taste funny
You may consider pulling out the ice maker and tossing it in the trash if you look at it and see that where the ice sits it's corroded or its close to a 10 year old in age (IT'S DUE TO GO OUT ANYWAY).Other than that:you have a 3% chance that the tube that goes to your ice maker is bad. Please Rate This !
SOURCE: Bad water & ice cube taste
the feed line of the water source is bad replace it you will also need to clean the ice makers insides to remove the rest of the contamination
and 2 more suggestions:1) change the filter - older refers have the filter in the water line serving the ice maker - newer refers have the water filter in the refer (it looks much like an auto oil filter); 2) do not store ice for extended periods when ice use is not high e.g. during cooler months. Unless you use a full basket of ice over say a few weeks you should dump all and start over periodically.
thanks.
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You
replaced the copper tubing which delivers the water to the fridge and
that didn't help. You replaced the copper tubing again with plastic
tubing...no better. Any suggestions? Your tap water doesn't taste this
bad.You bought a Kenmore french door fridge with water dispenser in the
door in July 2008. The fridge has a filter. A few weeks after the
fridge came the water and ice started tasting really bad, unlike any
bad water taste I have ever tasted. And your tap water is fine. The bad
taste appears to be random. Sometimes you get a cup full of nasty water
and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
SOURCE: Ice tastes bad even after I changed the filter?
allow your ice maker to dispose old water that is still stucked on its hoses, just throw those unpleasant ices's and water would simply replenishes with a a fres and good supply
SOURCE: ice maker water taste like chlorine but tap tastes fine
Put a in-line water filter on the water line if you want. The taste is from the food and items you have in the refrigerator. Clean it out and keep your items in proper storage. Ice collects the smells in the line and the fridge. Change your ice that is sitting in the bin, wask out the bin with water and baking soda. Hope this helps.
