I have a whirlpool Calypso washing machine model # GVW9959KT2, we changed out the control board & are still getiing the error message CE, have checked all the other electric parts & seem to be working ok repair man can't figure it out
  • hicksgranny Aug 01, 2009
    Thank you I will have my tech check these things or see if he has & go from there
    Thank yiu
  • 10,515 Answers
CE refers to :-
CE communications - Error If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display.
Check all the check points above mentioned. I believe the above one is self explanatory.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 14, 2009
  • 3,037 Answers
I have seen shorts in the lower wire harness causing the board to blow, inspect or test for continuity in the lower harness. Also, see if the fuse is blown on the board, this will be because of a short. Let me know what you find.
Benjamin
Posted on Aug 02, 2009
  • Washing Mach... Master
  • 19,396 Answers
CE error stands for “Communications Error” and refers to a broken communication between the timer control board and the motor control unit.
If replacing the main control board did not help, then test wiring harness to motor control unit, and then test and eventually replace MCU.
There is a fuse on the motor control board and , if it blows the board may be faulty.
Posted on Aug 01, 2009
Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
Whirlpool Calypso Washing Machine diagnostics & Error ...
applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
[PDF]Fault Code Bible v1.2.pdf - ResearchGate
Dec 02, 2015 | Washing Machines
Error message CE displaying. Machine will not run.
Hi, concerning the CE error, the tech sheets indicate this is a problem with the motor control board with a blown fuse on the board. The solution is to replace the board....
Oct 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
CE code?
Communication error between the Motor control board and the Machine control board. They are both inside the console just behind the key pad. It is usually a **** shoot as to which one has failed with this error code, but for one reason or another they are not talking to each other.
Apr 21, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Whirlpool Calypso washing machine, model
communication error. changing the MCU. sometimes a bad pump could be the problem
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K washer CE error
Communications Error. If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once. All of the possible causes require service of some kind. You can google for the service manual of your model # if you are so inclined to try self-service repairs but you need to be comfortable working with electronic circuit boards (behind the control panel). I would not attempt any of this kind of repair unless you had some experience, for you can make the problem worse if you do not handle the electronics correctly.
Mar 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have a calypso whirlpool washer code ce came up and it wont drain
CE is a communication error between the control board on the control panel, and the motor control board. in most cases this is covered under the warranty from whirlpool but in some cases it is not. in any event the motor control board must be replaced.
Nov 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
CE ERROR CODE
ce is communication error could be a bad connection between the 2 boards.( i doubt that) or the drive motor protection open. or the motor controller is bad. there is a notn replacable fuse on some of thos boards. check to see if it is open. Make sure you unplug machine.if it is open replace motor control board. Part #8541034
Oct 25, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Got a LD then a CE error
CE Communications Error If there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
This can be caused by corroded pins on the control card or motor control. Most of the time this relates to a faulty machine control card.
Dec 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Code CE
CE stands for Communication error. The Calypso has 2 circuit boards inside that touchpad area. One is the motor control board and the other is the machine control board. They are not "talking" to each other for some reason. The boards are warranted for 5 years on most machines. This machine is the subject of a class action lawsuit. Just Google Whirlpool Calypso sit back and start reading.
Dec 06, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
