Question about Cameras
My 4gb sdhc card will not work in my vivitar 3315.
  • 10,594 Answers
First format 4GB card in camera by camera menu format option and if still that card does not work then camera hardware does not support such big capacity card and please use 2GB card.
Posted on Aug 01, 2009
2 Suggested Answers
Jeff the TV
  • 82 Answers
SOURCE: THE 4GB SDHC CARD WILL
it is most likely not SDHC compatible it will only use SD cards, or try to format using your computer
Vivitar itwist610dvr won't save files to my sd card
Unless you've found a VERY rare 4GB SD card, your 4GB card is actually an SDHC card. The 610 will not work with SDHC cards. Try using an SD card, 2GB and smaller.
Aug 16, 2012 | Cameras
Can you use SDHC when manual says SD?
An SDHC card is not an SDHC card. While it fits into the same slot, it will not work unless the device is designed to also work with SDHC cards. SD cards go up to 2GB in size, SDHC cards go from 4GB to 32GB in size. Unfortunately, Vivitar seems to be a little fuzzy on the distinction between the two.
In your particular case, you should be able to use any SD card, or any SDHC card up to 16GB in size.
Dec 03, 2011 | Vivitar Cameras
I have the vivitar 3315 digital camera and i keep getting a card error message. Its not locked because i have double checked... please help
Probably the first thing to try is formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then there may be an issue with the connectors in the card slot or the card may be incompatible.
If this is a new card, maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. It is often difficult to find out the maximum capacity a camera will use, as today's memory cards are much larger that those available when the manuals for the camera was written.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 09, 2010 | Vivitar ViviCam 3315 Digital Camera
Can I use a 4GB SDHC memory card with Vivitar 5385 camera
No. The 5385 works with SD cards, not with SDHC cards. You're limited to cards 2GB and smaller.
Nov 07, 2010 | Vivitar ViviCam 5385 Digital Camera
Can a 4gb memory card be used in a vivicam 6324 and if so how do i formatt it it keeps saying memory full?
If it's actually a 4GB SD card and not an SDHC card then it can be used. However, the SD specifications actually only go to 2GB, so almost all cards larger than that are SDHC cards. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work.
Given that the camera isn't formatting it, I'd say that the card is an SDHC card. I suggest using SD cards 2GB and smaller.
Oct 11, 2010 | Vivitar ViviCam 8018 Digital Camera
Just wondering what memory card i need as a 4gb sdhc card doesnt work it saying card fail
Your camera may not be able to use SDHC cards. Try an SD card instead (they only go up to 2GB).
Mar 16, 2010 | Vivitar ViviCam 5150s Digital Camera
THE 4GB SDHC CARD WILL NOT WORK IN MY VIVITAR 3315 CAMERA. CAN YOU TELL ME WHY OR WHAT TO DO
Aug 01, 2009 | Cameras
What memory card do you use for vivitar vivicam 4100? i tried putting in a 4gb sd card, and then the camera wouldnt load up with it in.
The new 4GB card is likely an SDHC card (see if SDHC is printed on the card). Although it looks the exact same as a standard SD card, its file format is different. Your camera was designed before the SDHC format came out. Unfortunately your camera is not compatible with this card, and there is no way to make it work. Instead consider the wide availability these days of low-cost 2GB standard SD cards. These will work with your camera, and happily only cost about $7 including shipping: http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Delectronics&field-keywords=sd+card+2GB&x=21&y=22
And hang onto that 4GB SDHC card. It will be compatible with all future cameras that you may purchase.
Jul 19, 2009 | Cameras
Vivitar 5010 camera SD Card Support
Yes this camera supports the SDHC card the difference is more space.
1gb and 2gb are considered regular SD cards. Anything 4gb and above is considered "High Capacity".
Mar 31, 2009 | Vivitar ViviCam 5010 5MP CMOS, 2.48" LCD,...
Cameras Logo
14 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
