Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Where can I order parts for my kitchenaid pro 600?
I can't find anywhere that sells more the 5 different parts for kitchenaid, I need the main shaft that is connected rotating disc that you put the main attacments on. Mine is bent.
  • kuehnefamily Dec 13, 2007
    I need the shaft that you don't see (planetary shaft) and the planetary.
    Doesn't seem to be available any longer.
  • 3 Answers sells a lot of internals for those machines
Posted on Nov 29, 2008
McNichols Electric in Detroit. Web site NA.
Posted on Jan 08, 2008
How do I reattach a planetary that was pulled off?
I haven't seen enough of that model to remember, look up a local service agent and ask them is probably your best option. Whoever does the warranty repairs for Kitchen Aid would be the best person.
Dec 18, 2015 | KitchenAid KP2671 Professional 6 Series...
Does kitchenaide have different bowls for the Pro 600?
Kitchen Aid does have different bowls for several different models. You can also contact Kitchen Aid direct to get information about your model. Here is a link with information about your model mixer.
Jul 21, 2014 | KitchenAid Food Mixers
Kitchenaid 600 pro
After many years dealing with Kitchen Aid mixers I purchased a pro 600 for my wife as an early Xmas gift. After just a few usages it started making a clunking noise in the gear housing. I removed the housing and discovered the casting is of very poor tolerances and the main drive assembly was lifting from the torque of the motor and causing the gear assembly to lift out of the casting and skipping on the worm gear. I am sure it is going to happen to many more of these units as the casting area that holds the bearing in is to large obviously an overdue mold in the casting process. Time for a recall Kitchen Aid.
Jan 31, 2014 | KitchenAid ProLine 600 Stand Mixer
Kitchenaid 4ksm900b
you have an internal gear problem if you continue to us it you can damage other gears and increase your repair parts needs. go here to get a parts list for your model and start the tear down to find the culprit
then order your part from eBay or several site on the internet that sell KA parts like "Seneca River Trading or mending shed" then re-assemble. Parts will be anywhere from $6.00 to $20.00 USD. hope this helps
May 23, 2013 | Food Mixers
Professional 600 575 watts beater shaft is loose
If the beater shaft that you attach the beater to is loose in it's housing, then you will need a new planetary for your mixer, it is a relatively easy fix to make, but you will have to order the part before you can effect a fix.
The 600 model has the center shaft attached to the planetary by means of a heat pressure press in. Which means that when the colored rotating part starts to come loose that you have to replace the whole planetary piecec994bebd-6a21-41c8-821e-a90ec9e3ea14.jpg
the piece that the beater attaches to is called the agitator shaft and it will need to be removed and put on to the new planetary when you install the new one. If the agitator is actually the piece that is loose then you need a gear at the top, a pin underneath of the gear, or a snap ring that holds the shaft together in the planetary housing. Go to the kitchenaid address listed here>>
when the page opens look on the left side of page and fill in the proper model number (it is on the bottom of your mixer on a white tag), the page will give several choices go to the parts list section and click on that choice for your model number, (you will need the proper part number to order the correct color for your mixer, by following the parts list diagram you will see that there is a very understandable process that you can follow to open up the mixer and replace the planetary, hope that this helps, let us know if you need assistance or if this answered your question
Apr 17, 2013 | Food Mixers
Head falls off
we need more info and clarity first we will need a model number for your mixer before we give any advise, next what head falls off, the planetary if so then i will assume that you have an accolade professional or pro series or pro 600 mixer, in which case you need to order a new planetary for your mixer. (planetary is the part that the beater is attached to) please send us more info so that we can help you
Jan 30, 2013 | KitchenAid Food Mixers
Piezas para reemplazo de mixer pro 600
Hola de nuevo PASTELERIARU. Haga clic en este enlace al sitio web del KitchenAid Internacional para México. Espero que sean capaces de señalar a los vendedores de partes en México.
Buena suerte otra vez, Howard, Burke, Inc. EE.UU.
Si esta solución ha sido de ayuda, por favor vota, gracias!
- Hslincoln
Feb 18, 2010 | KitchenAid KP2671 Professional 6 Series...
Kitchenaid pro 600 KP26M1X looking for a printed circuit
Hi VIC. The PC board you’re looking to replace is called the “Control Assembly” inside your mixer’s head, and yes you can order and replace it yourself. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at:
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case: KP26M1, and select one of the first two files listed under Parts List (47) (The first file, KP26M1XAZ4.pdf (304.18 KB), is for a -4 series model and the second file, KP26M1XAZ5.pdf (724.41 KB) is for a -5 series with slightly different insides, so make sure you have the correct Parts List manual.)
For a series -4 mixer, turn to pgs. 2 & 3, titled Case, Gearing And Planetary Unit that shows an exploded view for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. No. 8, Control Assembly. This is where I suspect your problem lies. (For a series -5 mixer, turn to Pgs 4 & 5, and locate Illus. No. 18, which is the Control Assembly). You just decide if you need to order a Black Knob or Grey Knob Control Assembly
As far as parts go, here are four potential vendors in no particular order:;;; Prices for the same part can vary widely between vendors, so do your comparison shopping. I don’t know if these vendors mail internationally, but you should be able to check their websites and find out.
Once apart you can check your mixer for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Jan 12, 2010 | Food Mixers
Thumping Noise Under Duress
Hi. Your problem probably lies in the plastic transmission housing. This cheap piece of plastic has no business in a high priced mixer, as it has two important shafts that depend on the integrity of this housing for their bearing seats
Remove the top cover from the mixer. At the front top of the mixer is the trans. housing. Examine this housing carefully for cracks. If you find cracks, then you have new damage inside the mixer. If, when you replaced the three gears, I suspect that you did not discover the cracks in the trans. housing and reinstalled it after you replaced the gears, or you may have missed internal damage from the first breakdown.
When this cheap plastic part fails, it can destroy the worm gear, it's bearings and the bearing seats and possibly more.
Kitchenaid's replacement housing is made of metal. Kitchenaid markets these mixers saying it can handle bread dough. The ugly truth is they cannot!
You must open the unit up, remove and save the grease if it's relatively new. You must check every moving part in the mixer's transmission. You have to remove grease from these parts in order to find the damage. When you have the unit repaired, sell it!
I had the same problem with my mixer. I replaced all of the broken parts, and sold it. Since then, I bought a used Hobart N50 ( 5 quart), and an A200 (20 quart) mixers, both of which are commercial mixers. Both of these can handle heavy dough and they do so with ease.
Kitchenaid, to this date, have refused to recall these trans. housings, even though thousands of these cheap plastic housings have failed. Good luck with this saga!
If this solution has assisted you, please rate it. ricardok45
Mar 31, 2009 | KitchenAid KP2671 Professional 6 Series...
Kitchenaid pro 600
It sounds like you may have broken the gear in the head of the mixer. I would call this a Advanced fix since you need to press the pin out of the shaft to put the new gear on. The parts are available from online parts stores, and the manuals and part lists are available from KitchenAid HERE.
Oct 25, 2008 | KitchenAid KP2671 Professional 6 Series...
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
1,664 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
