SOURCE: riding moweer wont charge the battery when mower
Hello davidturner:
>>From your Description it Sounds like the Stator/Charging Coils are Not Charging Correctly.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
SOURCE: Is there a deck switch on a YTH180
brake shutoff isn't working properly it is located on opposite side of brake about 3inches past steel plate unplug and put jumper wire from white to white wire this will disable brake shut off.this is only a suggestion but it will work.
SOURCE: I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
