Question about Dometic Rooftop RV Air Conditioner
Unit shuts off on hot days
It trips the breaker which I have replaced. When it is cool out, it runs fine. On hot days it would trip the breaker. After letting it sit for 10 minutes, I would trip the breaker and it would run well for an hour or so and then trip it again. Now it only runs for 15 minutes on a hot day before it trips the breaker.
Thanks for your help,
Gabriel
    President:
  • 1,273 Answers
It may be low on refrigerant. On hotter days, the compressor has to run longer to reach the temperature you have on your thermostat. Have it checked for the proper refrigerant charge and have them test how many amps that the compressor is pulluig as well. With the proper breaker installed, the unit should not be tripping out. Make sure that the breaker that is in there now is actually the proper one for your unit.
Best regrds, --W/D--
Posted on Aug 01, 2009
I had the same problem but it was the voltage coming in,make sure you have 110 or more coming in
Posted on Jul 18, 2010
Sharp af s125fx overheats and trips circuit breaker.
yes you can wash out fins on codensor. turn off power at breaker wash and let it set a hour before turning back on
Aug 07, 2015 | Sharp Heating & Cooling
HotSprings hot tub trips circuit breaker
Could be a wrong breaker for that circuit or a problem with the tub.
• first see if there are other lines on that circuit- should be only the tub.
• Check the specs for the tub that the circuit is the correct amperage.
• if clear on those items, there is a problem with the unit and that's another question.
Aug 16, 2014 | Electrical Supplies
I HAVE XB10 HVAC SYSTEM TRIPS BREAKER
could need a start assist for compressor or could be weak breaker
Dec 03, 2012 | Heating & Cooling
Have a package unit that is tripping the circuit breaker early in the morning, around 5 a.m. each day for the past few days. The blower fan motor was recently replaced, but it seems to work fine, all day...
Excessive current draw when motor first starts could and most likely does cause this breaker trip. I would check wiring connections to motor, check cold motor start up amperage draw, also breaker may be the issue (weak bimetal spring).
Jul 19, 2017 | Goodman GPC1342H21A Air Conditioner
Central AC unit replaced breaker trips after running 20min
Unit is drawing two may amps for the breaker. Could be compressor sticking.
Jul 22, 2009 | Weather King 10AJA6001AH Air Conditioner
A/C unit turned off- didnt realize we had a mat covering the unit
If the breaker had tripped, you'd detect some looseness in the trip switch, even though it may not appear to be tripped. Once you have identified the correct breaker, trip it to OFF and then back to ON. Also check at the unit; it will either have a service disconnect, a fused disconnect or a circuit breaker at the wall. Compressor units have a thermal relay that causes them to shut down on high temperature. Let the unit cool down thoroughly. If this is the issue, and you are standing close enough, you may hear it reset when it cools. Usually, cool down occurs in 30 minutes or less. Try it again, but don't leave it unattended until it has made it through several cycles and you are confident that the unit is back to nornal. If any further issues develop from this incident, shut the unit down, trip the circuit breaker for the unit to off and call a serviceperson.
I hope this gets you going again!
Best regards, W/D
Jul 11, 2009 | Amana Heating & Cooling
A/c tripping breaker during peak heat of day ,coils clean,filter clean,pulling about 16 amps while running 15000 btu straight cool
Chances are you have a bad breaker or loose wires on the breaker. What size breaker do you have on unit. Heat of the day plus full load on the unit could cause it to trip. Rus
Jun 28, 2009 | Dometic Rooftop RV Air Conditioner
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
332 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
