Question about Craftsman Garden
Craftsman bushwacker 32cc, i need to replace pull
Craftsman bushwacker 32cc, i need to replace pull cord. i need a disassembly breakdown.
5 Suggested Answers
  • 279 Answers
SOURCE: 32cc Craftsman Brushwacker
You have to take the machine apart. The first thing is to separate the shaft from the engine. Then take off the shaft driver. There is a screw in the end. It takes a #15 TORX screwdriver. Once that is off, you have to spin off the clutch. To do that, hold the engine somehow and remove the clutch counter-clockwise. With that off, you can then remove the engine from the molding at the other end. The spool will be sitting on the rewind spring so BE CAREFUL. If the spring comes out it will be a big pain! Just lift the spool off, replace the rope and attach as the old one was. Now, you have the rope connected. Place the spool on the spring. Place the rope in the notch at the edge of the spool and slowly wind the spool on the spring. When you have it wound as far as you want, take the rope from the notch and into the spool. Allow the rope to rewind onto the spool. Put everything back as it was before you started and you have finished...Good luck...Lee
Posted on Sep 09, 2009
Testimonial: "thanks so much."
  • 398 Answers
SOURCE: Need to replace entire head of Craftsman Bushwacker
there should be a little alignment hole where you can stick a small screwdriver thru to hold it from spinning then turn clockwise(its reverse thread). let me know if there isnt an alignment hole
Posted on Mar 26, 2009
  • 27 Answers
SOURCE: broken pull cord
ur going to have to unmount the the motor from the shaft
step 1. Unbolt throttle housing
step 2. now with that out of the way u should see a clamp holding the motor to the shaft, loosen and pull the shaft out, there will be a cable, so make sure u have it lined up so it goes back into place
step 3, look at the back of the motor, u should see screws going into the plastic housing (coming in from back going into plastic)
step 4. once that is off pull the broken part of the cord out
step 5. wind up the starter coil, (it will only wind up one way) its spring loaded so be carful, once it stops back it off 1 full turn
step 6. u will see a hole for the cord in the housing and in the coil, make sure they are lined up
step 7. insert the cord through both holes, tie it as tighttttt as possible, then let the spring do the rest
step 8. put it back together
Posted on May 31, 2009
SOURCE: repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Posted on Sep 05, 2009
How to replace starter pull cord on model no. 358791580
I'm sure i've seen a video showing you the process on youtube of how to replace the recoil.
May 09, 2016 | Craftsman 32cc* 4-Cycle Straight Shaft...
How do I change the fuel line on a craftsman bushwacker
Videos are so easy to learn from.
Fuel line and fuel filter are located IN the gas tank.
Take a look here...
May 17, 2015 | Craftsman Garden
How do i fix a cord not going back in on a craftsman weed eater/blower combo 32cc
The one way clutch could be broken or jammed. Take off the starter for a closer look.
May 10, 2014 | Craftsman Garden
I am looking for the spark plug gap for my Craftsman 32cc Bushwacker model 358.795822
The correct gap is .013 . You may find it at ebay or other online store .
May 05, 2014 | Craftsman Science & Laboratory
I have an 18" Craftsman Bushwacker hedge trimmer
The wire into the handle may have been pulled and come loose. You will have to take the handle apart to check. They are simple.
Sep 28, 2017 | Craftsman Garden
I operate a 32cc Weed Wacker from Craftsman. It was working just fine, but all of a sudden stopped running and somehow I cannot pull the start cord, it got stuck. Where should I look first before opening...
The first thing I would do is remove the housing for the pull cord and spring to find out why it isn't pulling. That may be the same reason as to why it stopped and appeared to lock up.
Jun 19, 2011 | Craftsman Garden
The cord pulled out of my 32cc craftsman blower.
slow and steady, there is no shortcut for that machine, find a clean work space and start at the top. They will never win an engineering award for that one
Nov 16, 2009 | Craftsman Garden
Craftsman 32cc weed eater wont start. Push in the primer bulb and it does not refill, stays stuck in!
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner. Makesure the small screen is free of debris.(Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Jun 27, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
1,494 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
