Question about GE Microwave Ovens
How to remove modle jvm57-001 there 4 bolts but dose not free it from the wall
    President:
  • 1,273 Answers
Look for bolts going up into the cabinet above. Most can be removed from the cabinet side.
--Regards--W/D--
Posted on Aug 01, 2009
Removing unit
To remove, you will need to remove four bolts on the top of the unit.
Unplug it first, then remove the two bolts nearest the wall first. It would help to place something under the front of the unit about two inches shorter, to catch the unit as you remove the front bolts. The bolts are long, so be prepared for a lot of turns. A ratchet helps. The unit will lower in the front as you remove the last bolt. There is a bracket screwed to the wall behind the unit, with a lip at the bottom that holds the back of the unit. After the front has lowered, lift the back up about an inch, and pull the whole unit away from the wall. Remember to pull the power cord out of the cabinet before moving the unit away. Hope this helps.
Jun 14, 2014 | Kenmore 62702 Microwave Oven
Removed my wall mounted microwave and could not get the microwave off the wall bracket. I now have some holes where the toggle bolts were. Will this interfere with the new installation
It's impossible to say without knowing the old model number and the new model number.
But since you posted under GE, I'll assume that's your brand.
You can download GE owner's manuals and installation instructions here.
Nov 30, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave is a Whirlpool modle #GH9176XMS1. The 1100watt inverter is bad. I have taken the control cover off, but the access to the inverter looks to small to remove it.
You may very well have to remove the oven from the wall, then remove the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting, & testing.
Jan 17, 2011 | Microwave Ovens
Can't remove old spacemaker from wall
Apr 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do I remove an over the range Sharp R-1490? I have no user guide and can't find a free one online.
Here's a link to the instructions for mounting the unit on the wall. Take a look at the section that shows 2 arms protruding out into the microwave2_bing.gif where the microwave is secured by a bolt. Have you removed these bolts? If so, the microwave should pull out. Here's the link to the guide:
http://www.microwavedisplay.com/r1490_r1600_r1750_r1870_r1871_r1872_r1874_hood_inst.pdf
Mar 07, 2010 | Sharp R-1490 Microwave Oven
How do i take microwave off wall i took 2 bolts off in cupboard above microwave and microwave did not budge at akk.
There should be two or three bolts inside of the cabinet above the microwave. Remove all bolts and then pull top edge of microwave forward (away from wall). It pivots on a mounting plate which is secured on the wall. Pivot forward and lift microwave up a little bit off of the ledge of the rear mounting plate.
Make sure to feed the electric wire (plug) through the hole in the cabinet as you pivot and remove the microwave. Sometimes cooking grease will make the microwave stick to the cabinet. So after removing the bolts use gentle force when pulling on the microwave.fce1346.jpg
I hope this helps and good Luck!
Feb 16, 2010 | Magic Chef CMV1000B Microwave Oven
Remove a whirlpool over the range microwave oven
Jim here. In cabinet above microwave, locate 2 mounting bolts.
Place a box on the stove top to support the microwave once the mounting bolts are removed (you may wish to cover the box with a thick towel or small throw rug).
Procedure:
1. Unplug microwave.
2. Remove both mounting bolts from top of microwave (they secure it to the overhead cabinet).
3. With microwave front angled down onto box, pull some of power cord out of hole (to provide some moving space).
4. With microwave hand supported, remove box from stove top (a second set of hands would be helpful here).
5. HARD PART- detach top of microwave back from wall mounting plate by placing a hand under the bottom rear of the microwave and pushing up. (Wall mounting plate is screwed into the wall behind the microwave and provides both top and bottom support to the back of the microwave.)
6. Lower front of microwave until you can see about a 1-inch clearance between the top-rear of the microwave and the cabinet above it.
7. Firmly lift the microwave straight up and then bring forward. It should be free of the wall mounting plate.
Sep 30, 2009 | Maytag MMV4205 Microwave Oven
How to remove from wall for remodel project
There are 4 bolts or should be 4 holding the microwave top to the cabinet. Open the doors to the upper cabinets and you should see the bolt heads unplug the microwave unscrew the bolts while holding the microwave. After the bolts are out tilt microwave towards you and pick up from the bottom next to the wall to remove oven from mounting plate and thats it.
Sep 16, 2009 | Sharp R-1505 Microwave Oven
Need to know how to remove Advantium 120 convection/microwave oven Model SCA1000DWW03 from mounting above stove so that it can be taken to repair shop - problem is completely dead after power surge during...
Usually there are 3 or 4 mounting bolts located in the floor of the cabinet above. First you will have to disconnect the power and then the duck work if the unit is ventde to the outside. To remove the unit requires two people, one to support the unit and the other to remove the bolts. If you are doing it alone, quite difficult, you'll have to juryrig a deadman support. Ther is a wall plate behind the unit that has a lip that the back bottom of the microwve is locked into. After the bolts are removed slowly lower the front until you are able free the unit from the lip of the support plate.
Jun 28, 2009 | GE Advantium 120 Convection/Microwave Oven
Removal of unit from wall bracket
You can download GE installation instructions here.
Then you can see how it went up to help you get it down.
Nov 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
