Whirlpool washer f30 code
It sounds like no water is entering washer, but I disconnected hoses, cleaned filters and checked that I have adequate water coming from the hoses. The filters entering washer were cleaned and replaced. Please help!!!
Hi there.
We just bought a brand new washer and had the same thing just happen to us. Found out after taking the lid off that the top had pinched down on the mechanism that turns and allows the water to flow in. We were stacking out laundry baskets on top of the washer which did this. After taking the top lid off and touch it it began to move and is working properly now.
Have you tried this?
Hope it helps someone out there in the future if not you now.
Posted on Feb 18, 2008
  • meandron Sep 02, 2010
    I can attest to polaris babe's suggestion. We were "storing" our detergents on the top cover. A new, full bottle of Tide caused problems for us. Cleared the top of it, problem solved.
2 Suggested Answers
SOURCE: Whirlpool washer f30 code
Check this out...
http://www.youtube.com/watch?v=0Iu7lM9bd7c
Here shows how to fix F 30 error on Whirlpool's DUET family.
Posted on Mar 22, 2008
My machine is Kenmore Elite front load It is
Hello Sandra,
The FH error code means the computer on the control board didn't detect any water entering the washer..sometimes it doesnt detect the water entering because the filter screens on the water inlet valve are clogged with sediment and water is having a hard time entering the washer.
The filter screens can be checked by turning off water at the faucets and disconnecting the fill hoses from the back of the machine and pop the screens out of where the hoses connect at the washer and check for blockage in them. If they are found to be clean, check the water coming out of the hoses before connecting them back to the washer...if the screens are clean and water pressure is good out of the hoses the part of the washer called the FLOW METER would need to be replaced.
Thanks for using FIXYA.com
GENE
Jan 10, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool ghw9150pwo flashes FH
The FH error code means the computer on the control board didnt detect any water entering the washer..sometimes it doesnt detect the water entering because the filter screens on the water inlet valve are clogged with sediment and water is having a hard time entering the washer.
GENE
Oct 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine keeps flashing up fh and not working
GENE
Oct 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I am getting an HF reading on my front load washer, water is going in and out. What could be the problem?
GENE
Sep 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The initials FH keeeps comin up on screen when the wash is at 26 minutes Then I have to turn off power and press start button again. What do these initials stand for?
GENE
Sep 12, 2011 | Whirlpool AWM6100 Front Load Washer
My Whirlpool washer flashed F30. Not filling up with water.
"F30" indicates "DISPENSER SYSTEM ERROR" When the dispenser motor cannot be driven to its proper position this error appears in your washer. To fix this problem follow these procedures.
1. Unplug washer or disconnect power. 2. Check mechanical linkage from dispenser motor to the top of the dispenser. 3. Check wire harness connections to the dispenser motor and Central Control Unit (CCU). 4. Check dispenser motor for powered rotations.
Thank you !!
Jun 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does LF means? and what should I do
See the following Whirlpool Service Manual for their Cabrio washer which is basically the same as the Kenmore Oasis.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
6-1
DIAGNOSTICS & TROUBLESHOOTING
DISPLAY FAULT / ERROR CODES
DISPLAY
(Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
(F30)
Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged
the basket but control does not detect a water level change.
• Is water supply connected and turned on?
• Are hose screens plugged?
• Is water entering the tub? If so check pressure hose connection to machine/motor control.
• See TEST #2.
Nov 13, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Very slow cold water fill, why?
First make sure that you have adequate water flow from the hose bib coming from the wall. You can do this by turning off your cold water connection at the wall, then disconnect the cold water hose. Then turn the faucet on and make sure the water flows freely. The most common reason for your problem is a clogged screen where the cold water hose connects to the back of the washer. To check this, disconnect the cold hose from the back of the washer and clean the small screen inside the cold water inlet on the washer.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
Jan 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
373 people viewed this question
Top Washing Machines Experts
