Question about Maytag MSD2756G Side by Side Refrigerator
Filter will not turn counter-clockwise.
The water filter UKF8001 is in the top right corner of the the refrigerator. It won't turn. Do you have any advice to help make it turn?
  • Anonymous Mar 23, 2014
    cannot unscrew ukf8001 water filter. stuck.
    President:
  • 1,273 Answers
Push in while turning. Some are on a spring-loaded bayonet mount. This should do it.
Regards, --W/D--
Posted on Aug 01, 2009
Water filter is hard to remove.
Hello Marjorie;
My name is Peter. I am a retired field service refrigeration technician.
I have gone on service calls just to remove a water filter.
1.) If the water filter is on the bottom in the front of the refrigerator; you will need to use a tool such as a wrench, channel locks .... Grab the end of the water filter and turn counter clockwise.
2.) If the filter is in the upper right had corner of your fresh food section; you have to push up hard and turn it counter clockwise. You just have to strong arm it.
This will not always be the case. Your next filter should be easier.
Note: You only need to change your water filter when the water coming out of the water dispenser is slow or your ice cubes are getting smaller. Your filter light is just a 6 month timer. Your water filter can last you 9 months, 1 year, 18 months?
May 22, 2015 | Refrigerators
How do I install a water filter in a GE refrigerator ZFSB26DRH
Filter is located in the top right corner of the fresh food section. Clear off top shelf to give yourself working room. Filter is a screw in type but it only needs about a1/4 to 1/2 turn. Counter clockwise (left ) to remove and pull down slightly. Push new one up and turn right to reinstall. You will only get a few drips of water during the change AS LONG AS YOU DON'T PRESS DISPENSER FOR WATER. That all there is to it. Your filter number should be MWF.
Mar 29, 2015 | GE Refrigerators
How do you change the water filter on Maytag MF12568AES?
Check top right inside of frig. Filer is inside the housing; open door turn filter counter-clockwise, the housing should allow you to lower filter to change it out. Place new filter, turn clockwise, push back into place and close door.
Apr 19, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Where is the water filter located in back?
On your refrigerator filter is in the ceiling of the refrig. section above the top shelf in the upper right corner
The part number for the filter is ukf8001 its available at your local appliance parts store,Sears,
Lowe's or HomeDepot. Just take in the old one to match it up.
Gene
Aug 15, 2011 | Maytag MZD2669KE Side by Side Refrigerator
Is the water filter internal or external? where is it located?
Most are either in the kick panel at the bottom, or the top right corner of the refrigerator. Either turn counter clockwise and pull to remove.
May 06, 2011 | Refrigerators
Flow from water dispenser has decreased by half- How can we increase this back to normal?
replace the water filter located inside the refrigerator sides upper right hand corner,a quarter turn counter-clockwise will remove it
Jan 01, 2011 | GE Monogram Side by Side Refrigerator
I CANNOT REMOVE THE WATER FILTER LOCATED IN THE UPPER RIGHT INSIDE THE REFRIGERATOR. I TRIED TO TURN IT COUNTER CLOCKWISE BUT IT WILL NOT COME OUT. THE PART NUMBER ON THE FILTER IS UKF8001. ANY...
  1. 1. Look for the water filter cartridge. On some refrigerators it is located in the back, upper right corner of the refrigerator compartment. Some refrigerators have it in a tubular-like slot under the door and accessible from outside.
    2. Remove the old cartridge. On the cartridges that are located inside the refrigerator, the cartridge should be slowly turned to the left. Don't pull down on the cartridge. A small amount of water may drip. On the type that are under the door, follow the arrow labeling for the direction to unscrew it. Slide it outside.
    3. To replace a filter, fill the replacement cartridge with water from the tap. This will speed up water flow after installation. Run water from the dispenser for three minutes after replacing a filter to clear the line. Refrigerators with a filter warning light require you to reset the light. Press and hold the Reset Water Filter button to do that.
Jan 18, 2010 | Refrigerators
Filter needs changing
You don't need a plumber. The filter is located inside the fresh food section, in top-right corner. There is an elongated cover with a tab in front. Press the tab towards the back of the fridge slightly and pull the cover front down. There is your filter. No need to turn the water off either. Just twist the filter counterclockwise and it will pop off.
The part number of the filter is UKF8001, can be purchased in any appliance parts store, for example here. "New10"coupon takes 10% off.
Nov 09, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
How can I change the water filter on a frigidaire fridge
Hi, The filter is in the upper right hand corner of the fresh food section. Turn the filter cup counter clockwise to remove it. There will be a filter cartridge in the cup that you replace.
Please let me know if this has been helpfull or if I can assist you further
Thanks
Vic
Jul 17, 2009 | Frigidaire FRS6R5EMB Side by Side...
How do you changing the water fileter
  • in case you haven't figured it out by now. open rt side door and top right corner is the filter push the little plastic tab and the housing drops down , a quarter turn counter clockwise and the filter should pull out, reinsert the new filter screwing clockwise and close housing, remember to pull water from dispenser right away you will have let air into system so some sputtering will occur till its purged
Feb 18, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MSD2756G Side by Side Refrigerator Logo
98 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
