Question about Sewing Machines
Thread comes off needle after first stitch - Sewing Machines
  • Sewing Machines Master
  • 1,388 Answers
Make sure the tails of your thread are long enough not to pull out of the needle in the first stitch.
Posted on Aug 02, 2009
Skipping right side stitch on a zigzag stitch, so when i am running a zigzag stitch when the needle goes through the fabric and comes back up it pulls the stitch back with it ??
check your bobbin and is the needle good and sharp and the proper length.make sure its not bentthe tiniest defectt n a needle can mess up any stitch.
how does it work on regular stitching.
most problems with machines involve.bad needles incorrect threading of bobbin or spool,dirty bobbin,incorrect needle.
it sounds like the needle isnt catching the bobbin thread.
hope this helps
Apr 05, 2017 | Sewing Machines
Thread keeps coming out of the needle
you need to make sure there is sufficient thread out before starting to stitch again and the arm is UP
Nov 27, 2016 | Sewing Machines
Wont sew thread keeps coming out of needle
you have to hold the loose end for a couple stitches when starting off
Dec 16, 2015 | Sewing Machines
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
12 wt thread
12 wt thread generally will not work well in the bobbin...
"Aurifil 12wt Thread
Aurifil 12 wt thread is ideal for hand quilting, big stitch hand quilting and machine quilting. 12 weight thread creates a more defined and often primitive look. It's great for designs that use a longer stitch length if using a machine. When machine quilting with 12 wt thread, use 40 wt in the bobbin, increase your stitch length, lower your tension, use Topstitch size 90 needles and stitch slowly."
May 08, 2017 | Bernina Activa 140
Thread coming out of eye of right needle on huskylock 910
Hi:
Are you sure it's coming out? Or is it breaking at the needle?
Try replacing the right needle and do a test stitch. If it still comes out of the needle... loosen that threads tension a little.
Aug 01, 2012 | Husqvarna Huskylock Computerized 910
Problems threading my janome serger
One critical hint:
You must thread the loopers BEFORE the needles, otherwise it won't stitch. Begin with upper looper, lower looper, right needle then left needle.
Jan 16, 2010 | Sewing Machines
Stitch is uneven, not straight, and tension off on top and bottom
on my industrial machine this was caused by the wrong size needle. the length was off just a fraction. just an idea, in case you bought generic needles or something.
Nov 24, 2008 | Singer 3116 Simple
Instructions for threading Baby lock eclipse BLE1LX for 2 thread sergering
I have just learned this :)
Either needle thread may be engaged for 2-thread serging.
1. Open the front cover and cutting blade cover, cut the upper looper thread just above the threading guide ( this is plate that has two holes for the threads) Raise the presser foot and pull out the clipped thread from under the foot. Remove upper thread from the machine (or you can leave the cone thread on, it doesn't matter).
2. Rotate the handwheel to bring the upper looper to its lowest position.
3. Rotate the subsidiary looper up and to the left, then slip the end into the upper looper thread eye from backside.(this sounds complicated, yes? but it is very simple : the looper has a counter part that is spring-locked to move from left to right and right to left. This is the little claw-looking part of the looper that when in the postion to serg with four threads is to the right side of the looper. It looks like a scorpion's tale. If you can't figure which part it is, use your finger to probe the looper and you'll feel it give a little. This part needs to be moved to the left - it will not slide over, but swing up and over and down, like an arch. Then, where the thread comes out of the looper is where you want the little claw-like part to hook into.)
4. Close the covers. Decrease the needel tension - this depends on what the stitch length is. Stitch length: 2-3, stitch width: 3.0 = L needle n/a, R needle 1; upper looper n/a, lower looper 5
stitch length: 2-3, stitch width: 5.0 = L needle 0, R needle n/a, upper looper n/a, lower looper 3.5
Those are for a flatlock stitch - for a 2-thread rolled edge :
Stitch length: 0.5, stitch width: M = L needle n/a, R needle 4.5, upper looper n/a, lower looper 3.5
Stitch lenght: 1.0, stitch width: M = L needle n/a, R needle 4, upper lopper n/a, lower looper 3.0
If you have any questions, e-mail me at knowgodnofear@bex.net
Aug 10, 2008 | Baby Lock Eclipse Serger
2nd needle/4th thread - threading confusion
With some sergers, but not many (singer 14u64 comes to mind), the top of the stitch will be an overedge that mates with the right needle thread, and the left needle thread will appear as a separate straight stitch. When you look at the underside of the stitch, the overedge will go all the way over to the left needle (the full width of the stitch). This is normal if you have this type of machine. Another stitch some sergers do (2/4 thread sergers) is a 2 thread chain thal looks like a lone straight stitch on both sides, and a 2 thread separate overedge.
As far as the threading of the takeup, it totally depends on your model. Always post your model number when you have questions as sergers vary greatly in design.
Mar 11, 2007 | Juki MO-644D Mechanical Sewing Machine
Sewing Machines Logo
221 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
