Question about Motorola Mobility RAZR2 v9 Cell Phone
Razr v9 won't charge
When I plug the charger in the green charging light comes on but as soon as the screen lights up it goes out. It's brand new.
    Brigadier General:
  • 7,752 Answers
Well take it back to where you purchased it from..
Posted on Aug 01, 2009
My new luggie scooter won't charge
I have to ask, did you ever figure out what the issue was? My mother's scooter is having the same issue.
Feb 26, 2013 | Free Rider 2 Freerider Luggie Compact...
Brand new out of the box Volitation 9053 wont take a charge. Charger never goes green to indicate full charge. At most I get 5-10 seconds of weak spin and then the red light on the ECS board flashes. ...
  • If this is a brand new item out of the box, if this were my item, I would send it back for an exchange. The charger never turns green because the battery never gets a full charge. Because of that you won't get a 7.4volt reading out of the battery, Either the battery is not taking the charge or the charger is malfunctioning and not charging proper. The lights may work for a bit while the motor won't spin because a light takes far less voltage than turning a motor. Because you don't know if it is the battery or charger and it is new I have to suggest to take it back. The sooner the better. Messing with it will just void the warranty.
Regards, Tony
May 22, 2011 | xheli 9053 Outdoor Volitation Metal...
Charging Problem once i plug my phone to the charger it shows th green light but immediately my phone would come on and then the green light goes off and the phone stops charging
I had the same problem with my Razr V9,... and Motorola and AT&T were of no help!... They both claimed that it was a result of physical damage to the charge connector!... I find this hard to believe, since I used a USB connector to charge my phone via my computer, and that seemed to cure my charging woes!... I've been charging my phone in this fashion since then, and it seems to have no problem, thus far!... How can Motorola and AT&T make a claim that it's due to physical damage to the charge connector?... If that were the case, wouldn't one have the same end result by trying to charge it via a USB connection???... It's still a physical connection!!!... Hope this helps!
Mar 07, 2010 | Motorola Mobility MOTORAZR2 V9 Cellular...
Charging problem
I think the charging port is bad and this could be as a result of factory error since the fault is not from you. The phone restarts probably because the charging ports is bridging.
I will advice that you purchase a desktop charger that will enable you charge the battery seperately and when the battery gets full, you insert it into the phone. You could get another battery so that while you charge one, you use the other.
Or if you can look for a repairer, that will help you fix the fault of your phone.
Best wishes
Nov 16, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
Motorola V9 will not charge
try to clean the surface connection on the phone using very little screwdriver
Aug 22, 2009 | Apple iPhone Smartphone
My brand new motorola razr v9 would not charge, the moment you remove the charger the phone goes dead. And when charger is plugged- in the following message appears ''battery low cannot program''. Thank...
If it is a brand new phone, it will not cause this problem. You should return it or exchange it for a better phone ( if you still have the warranty card). The problem here is your phone's battery. Your phone's battery is not functioning well either it's old or corrupted. The solution is to change your battery.
Jul 27, 2009 | Motorola Mobility RAZR2 v9 Cell Phone
Motorola Rarz V9 won't charge...pllzzz hellp mee!!
I have the exact same problem as yours for the last couple days, and FINALLY IT IS CHARGED last night using the USB data connection cable. I don't know the exact problem with other chargers, including car and regular outlet chargers, but it works with the USB connection from a computer. GOOD LUCK!!!
Jun 09, 2009 | Motorola Mobility MOTORAZR2 V9 Cellular...
Motorola RAZR2 V9 new phone wont charge
Spare Battery Charger - Motorola RAZR V8 /V9 - $14.95
will need also a USA/Uk power adaptor /converter to use in Uk.100% works by charging battery separately from mobile
Jan 29, 2009 | AT&T Motorola RAZR2 V9 Cell Phone - Purple
'Unable to Charge'?
COULD BE THE PHONE BUT MOST LIKELY ITS THE CHARGER, IF ITS AFTERMARKET GET RID OF IT AND BUY OEM, TRY AND TEST IT OUT WOULD A FREINDS MOTOROLA CHARGER SINCE THEY'RE MOSTLY THE SAME CHARGERS AND SEE IF YOU STILL GET THE MESSAGE.
Apr 06, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
Motorola Mobility RAZR2 v9 Cell Phone Logo
556 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
