Question about Craftsman Garden
Engine starts fine, runs for about 1 minute, sputters and then quits. if i wait a while it will start again and repeats problem
  • dbfelton Aug 02, 2009
    I replaced fuel filter and sparkplug and engine began running much longer, almost 10 minutes. Unfortunately the engine then made loud noise and produced huge cloud of white smoke. looks like i have a valve/piston problem now. i think sputtering was better :-)
  • 339 Answers
Check your fuel filter to see if it is clogged.
Posted on Aug 01, 2009
My car is sputtering and dying. If I try to restart it, it will immediately go into sputtering/dying mode. If I wait a while an hour or so it will start up and drive fine.
When was the last time that the carburetor was stripped and cleaned? Also have you checked the fuel filter? Finally, the problem seems to come and go as the engine is run (and it gets hot) check that the fuel line and any electrical cables are well away from the hot engine as far as is possible.
Jun 16, 2015 | Cars & Trucks
What does the MIL code "PO 320" mean, please?
code p0320 refers to cam shaft position (CKP) sensor/engine speed (RPM) sensor--circuit malfunction=== causes --wiring--CKP/RPM sensor ---ECM
because the engine runs ok until it is on cruise control I would be investigating the RPM sensor for a fault
The cruise control takes its control from the RPM sensor and if that circuit is interminable the the cruise control doesn't know what rpms to maintain.
Jan 29, 2015 | Cars & Trucks
My 2004 Honda shadow vt600 vlx quits running after approximately 10 minutes of riding. It just shuts off and won't start. Has a new battery, plugs and changed oil & filter. What will fix this prob
How does it quit? Just suddenly stops, or coughs and sputters (probably gas), or gets jerky (ignition). Does it run just fine and then just stops, or does it run crappy and then stop? How long do you have to wait until it starts again? Is there a choke? Do you turn it off?
Sep 27, 2014 | Motorcycles
I have a JD Z-225 zero turn lawn mower about 4 years old. Has been maintained. It will run fine for a period of time after initial start-up (5 minutes or maybe 20 minutes) but then will begin to start...
My name is Dane and I'll try to help you with your problem.
I think you have a bad coil. A coil will operate fine on initial startup, but go bad after warming up. Get a cheap coil tester from an auto parts store an install it between the spark plug and the plug wire. Be careful on the next step because the engine can start. Turn the engine over and check for a bright light on your tester. If the light is dim or not producing at all, replace the coil. If the engine starts, allow it to run until it dies then recheck. If your coil checks ok, The other possibility is that your float isn't allowing the fuel to enter the carb fast enough to keep up with the demand of the engine. Thus, the engine sits idle, the carb bowl fills and it will run for a while until it goes dry again. This is caused from bad gas and deposits in your carb.You will probably need to remove, dissasemble, soak, and use compressed air to blow out the jet's in your carb. Pay close attention to how the carb is attached to the engine. Make a drawing if you need to or take some pictures. Disassemble the carb as far as possible and put it in the cleaning solution. Do not place rubber parts in the solution.Allow it to soak in cleaner overnight, and then blow out the ports and jets with compressed air before you assemble and reinstall it.
I hope I've helped. Thanks! Dane
Dec 03, 2010 | John Deere Garden
Shadow Aero Stalling Out While Riding
make sure your carb float level heights are good. make sure fuel pump is working properly. could be a fuel or temperature problem. slim chance it could be valves.
Dec 30, 2009 | Honda VT 750 Shadow Aero Motorcycles
Craftsman 7.0 HP Briggs & Stratton mower stalling
Check the muffler, if the muffler is clogged it could cause overheating of the engine, and could keep the engine from getting the necessary fuel-gas mixture.
Aug 09, 2009 | Garden
Engine Quits
sounds like a tipical crankshaft position sensor will fix your car
Sep 26, 2008 | 1993 Chrysler Concorde
Sputtering, chugging, black smoke - won't restart when hot
check your tail pipe for a "clog" engine not breathing correctly.
Jun 22, 2008 | 1993 GMC Sierra K1500
Garden Logo
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
