Question about Proventure Business Cards for Windows 3.1/95/98 for PC, Unix, Mac, Linux
I have Proventure Business Cards ver 1.0 for Win 3.1/95/98. My problem is that I've upgraded to Vista and no can not assess this program. What are my options?
MY LEGAL FORMS IS NOT COMPATIBLE WITH WINDOWS SEVEN HOW DO I GET IT COMPATIBLE
From what I can find it is a 32 bit program and WIndows VISTA and 7 are 64 bit based. Lotsof 32 bit programs will not run in the 64 bit enviroment. You can try to run it in a "compatible" mode. Go to "control panel" and then "add/remove programs" and then look at the top bar for "run in compatible mode".
Dec 30, 2010 | Clickaction Proventure Smart Business Pack...
I have been using my invices and estimates for years. I got a new computer with Vista and it wont install. What can I do
Get another program - apparently, I did a little research, it wasn't designed for Vista initially.
Dec 29, 2010 | Avanquest ProVenture Invoices...
We just upgraded to Windows 7 and we cant get our old invoice program to load. Its Proventure Invoices & Estimates version 1.0.0B . Can you help us?
Your accounting software may not be compatible with Windows 7. Check the manufacturer's website to see if it is or not.
You can also try the Windows 7 compatibility fix.
To do this, follow Microsoft's suggestions here.
Sep 16, 2010 | Avanquest ProVenture Invoices...
My proventure invoices do not ope in windows 7 starter. All othedr programs from the same programm pack are working fine
Labels, brochures, etc will load, but not invoices in Win 7. Set up a Virtual XP (or ME or whatever you had before) in Win 7 and it should work. I don't know if it works in Win 7 Pro using XP compatibility mode, but downloading a vitual machine (or VM player) works in Win 7 Home.
Feb 07, 2010 | Avanquest ProVenture Invoices...
Is there a version of a Business Card program that will run on Vista 64bit and open files made with a windows 95 program?
There is a program that you can download through the link below. It should work with your prior designs...just save them as pdf.
http://www.bizcardsoftware.com/?gclid=CJj5t66YiJwCFRJM5QodbkdS_A
Aug 02, 2009 | Avanquest Proventure Business Cards...
Getting a Blue Screen after upgrading with Win. Vista Business Upgrade from Win. XP Pro.
Restart the computer is Safe Mode (press F8 when booting to get a menu of options). This will start the computer with the minimum number of drivers and "extras" being loaded. From here you can press Win+R to bring up the Run command and enter 'msconfig' and press Enter. From this tool, you can allow your normal startup programs and device drivers to load. You will want to keep anything related to your DSL drivers disabled for the time being. Then restart the computer normally. If everything loads as it should, you can keep going back to the MS Configuration utility to add other drivers and programs one-by-one and retest (reboot again) to make sure everything is working properly. Once you know what the culprit is, you can uninstall that program and reinstall the Vista version if required. (If it is just software for your DSL modem, it probably is not required under Vista.)
Apr 14, 2009 | Computers & Internet
Cant install pro venture invoice on my new vista computer
proventrue v1.0 is not comparable to latest WIndows OS.
the proventure v4. is the latest listed on their web site. and yet it is only comparable to Windows Xp.
you can try that one. but there is no garrenty it will work. cost for the upgrade is $8.00 cheap enough.
Jan 29, 2009 | Avanquest ProVenture Invoices...
Where can I download the Picture Motion Browser software Ver 1.1 for Win XP MCE
What ever version of picture motion browser you have in PC, you can upgrade it by ver.3.0.05 at Sony Support for Vista.
If you require ver.1, (for Win XP) contact Sony on above page and place order for ver.1 CD.
For details, check Sony News page.
Oct 20, 2008 | Sony Handycam HDR-UX1 DVD Camcorder
Vista update for Proventure Invoices
The latest is version 4. it is listed as Windows XP. you can try this one, but no guaranty it will work. but it should be better that v3
also it cost $8.00 on line.
Jul 12, 2008 | Avanquest ProVenture Invoices...
Proventure Business Cards for Windows 3.1/95/98 for PC, Unix, Mac, Linux  Logo
139 people viewed this question
Top Proventure Computers & Internet Experts
David Payne
David Payne
Are you a Proventure Computer and Internet Expert? Answer questions, earn points and help others
