Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
Wifi quite working after hibernation
Code 10 device could not start. Orange light comes on as son as the power is turned on.
    Problem Solver:
  • 11 Answers
Common problem with the f500 series. The manufacter's warrenty has been increased to 2 years because of this probelm. The wifi needs to be replaced.
Posted on Aug 13, 2009
  • 97 Answers
What u could do is go to system restore and it will restore it to an earlier date and that should fix it the same thing happended to gfs dell laptop
Posted on Aug 02, 2009
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
I BOUGHT ACER NOTEBOOK 4740 FROM MICRO ZONE SCO 40 SECTOR 20C CHANDIGARH ON 12 MARCH 2010 AND SENT IT TO MY SON IN MELBOURNE AUSTRALIA . TODAY ON 27TH MARCH I GOT CALL FROM MY SON ROBIN THAT INTERNET ON...
Sounds like he does not have the wifi switch on. There are 2 buttons below the mouse pad on the front. The 2nd clear button when pushed in should turn orange letting you know the wifi 802g is active and searching as it blinks. When the orange light is solid it has locked onto a network. Hope this helps Acer sucks with this wifi funtion light.
Mar 28, 2010 | Acer Computers & Internet
Compaq Presario laptop C300 - issues (orange light)
Sometimes when a PC gets stuck in hibernation mode, the only way to reset it is to remove the CMOS battery for 10 minutes and replacing it. It resembles a large watch battery and is usually located near the center of the motherboard.
Dec 16, 2009 | HP 435768-001 - Compaq Presario C300...
My dell dimension e310 doesn't come on the orange light just blinks when it is plugged to the power
here are a few things to try.
remove the power lead from the computer, for 5-10 minutes then reconnect.
press and hold the power button, for more than 3-5 seconds, incase the system has gone into hibernation/standby mode.
Remove any un-necessary connected devices ( usb powered Printers-cameras et,c )
Mike @ Compurepair.
Jun 11, 2009 | Dell Dimension E310 PC Desktop
Compaq presario V2000 doesn't start
you might have shot out your battery because if electrical curent is goging in to the computer (te orange light is going on) but the computer wont turn on it might be a problem with your battey
please rate
May 30, 2009 | HP Compaq Presario V2000 Notebook
Monitor will not turn on- was working fine a week ago!
Replace it as they are so inexpensive.
Fleabay has a lot of choice.
Feb 27, 2017 | Acer AL1703 17" LCD Monitor
Dell 5160 orange light
I have never found hibernation to work successfully.
Disable hibernation if you ever get it started.
Try reading the manual on how to restart for hibernation, press "spacebar", "enter" or something.
Oct 10, 2008 | Computers & Internet
Screen went black
When you close the lid, there is a small pin that engages the case and flips a switch to tell the laptop the case has been closed. The monitor will ALWAYS turn off then, because otherwise, the heat build up would burn the screen! Do not try to defeat this, replacing an LCD screen is usually more expensive than the value of the laptop!
Now, that all being said (and please remember), the situation you have now is (hopefully) just that the laptop tried/succeeded in going into ACPI "suspend" or "hibernate" mode.
1. Remove all cables and 10/100. Remove all USB devices. Just leave the PSU (AC power supply) connected.
2. Press the power button firmly, JUST once. Wait. And I mean WAIT, because some laptops can take 2 minutes or more to come out of suspend/hibernate, if they were very busy at the time it was shut down.
3. If the LCD screen lights up. you are done. But if it does not light up now, then proceed to step 4.
4. Press and HOLD the power button down for 10 seconds. This forces the laptop to shut down completely, even from suspend/hibernation. Some unsaved files may be lost, but tghe laptop goes cold, so you can start ACPI over again.
5. After a few minutes, press the power button again, firmly, just ONCE and for 1 second max. Laptop should start up OK.
6. Once it starts up, go to START MENU/SETTINGS/CONTROL PANEL/POWER SETTINGS and search for the "hibernation" tab. Turn hibernation OFF. your laptop obviously has some problems or lack of responsiveness with hibernation (most do). Use suspend, instead. It is much safer,. faster, and still does a good job of saving HDD and LCD wear. Please let me know how this goes for you, there are other more detailed problems that may be involved here, but I suspect this is most likely.
Feb 11, 2008 | Dell Inspiron 710m Notebook
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
257 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
